    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • ? Offline
      A Former User @feverlabs
      @feverlabs
      The icons now show, so that’s great. Do you have a link to a list of the names of icons available in the set?
      https://iconify.design/icon-sets/
      After making those changes, the event details show again.
      add this into your css/custom.css
      .CX2 .agenda .eventSub {
        display:none;
      • F Offline
        feverlabs @Guest
        @Sean Sorry, I should have been more clear. I added that code into the custom css, but I just found an errant closing brace. Thanks.
        Final part: how can I set the width on this?
        Also, should I use a custom class for it?
        Thank you!
        F ? 2 Replies Last reply Reply Quote 0
        • F Offline
          feverlabs @feverlabs
          @feverlabs I think it would be this in custom css:
          .CX2 .agenda .event {
            max-width:var(--column-max-width);
          • ? Offline
            @feverlabs
            You can globally control the basic size metric with this; (Hmmm. I think you’d better first read the GitHub wiki about this topic)
            https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
            .CX2 { /* default values which are used frequently or dependently */
              --row-min-width: 100px;
              --row-max-width: 1000px;
              --column-min-width: 300px;
              --column-max-width: 400px;
              --font-size: 16px;
            For the specific view, you can set className to a specific view, then can control it in css.
            then, in your css/custom.css
            Will show like this; Only specific view has different width;
            But CSS is not so simple how it looks like, so when you modify something, you might need much experience and knowledge.
            • F Offline
              feverlabs @Guest
              @Sean Yes, thank you. I made the following change in custom css:
                  max-width:290px;
              This mad ether changes I was looking for. I’ll modify and try your solution as well as implement a class for it.
              Is there a bottom padding that is specified? I don’t see much for padding in there, but I can experiment.
              Thank you for your help.
              • ? Offline
                @feverlabs
                exactly, what kind of bottom? Image will be a help to understand.
                • F Offline
                  feverlabs @Guest
                  I am just looking to reduce that space on the bottom. Not entirely eliminate it, but reduce it.
                  You’ll also notice that the start time is in 24h format, the end time is in 12h?
                  • ? Offline
                    @feverlabs
                    1. Some footer is reserved for displaying counter of hidden events. (e.g: +1)
                    The red area is slotFooter, so you can control it like this;
                    .CX2 .mySpecificView .slot .slotFooter {
                      display:none;
                    1. For the time format;
                      Read this first;
                      https://github.com/eouia/MMM-CalendarExt2/wiki/Event-Time
                    With your previous config, you’ve set timeFormat: h:mm A, but there be more. :D
                    Upcoming view is somewhat different with other views(e.g: daily view), so the events need date and time together.
                    Usual format in upcoming view is something like this;
                    • If the event starts on a specific day and ends on the same day, it would be good to show like this;
                      start date/time - end time
                    • If the event starts on a specific day and ends on the other day, it would be;
                      start date/time - end date/time
                    • If the event is a fullday event and starts/ends in a day;
                      start date
                    • If the event is a fullday event and ends in another day;
                      start date - end date
                      And those could be combined with relative format, humanized calendar format, … :) Looks so complex!
                    Anyway, so, you need to set dateFormat and dateTimeFormat also with timeFormat
                    Set like this;
                    dateTimeFormat: {
                      sameDay: "[Today] h:mm A",
                      nextDay: "[Tomorrow] h:mm A",
                      nextWeek: "dddd h:mm A",
                      lastDay: "[Yesterday] h:mm A",
                      lastWeek: "[Last] ddd h:mm A",
                      sameElse: "M/D h:mm A"
                    Or simply like this;
                    dateTimeFormat:"M/D h:mm A",
                    It will show like this;
                    Or
                    • F Offline
                      feverlabs @Guest
                      @Sean Beautiful! Thank you very much!
                        jani.karna
                        I’m trying to use local .ics file for two of my calendars. They are holiday calendars that stay the same throughout the year so they don’t need to be fetched from the web. I just can’t get them to work.
                        I get the same error message on both of them:
                        [CALEXT2] calendar: Suomen juhlapyhät >> write EPROTO 1936543760:error:1408F10B:SSL routines:ssl3_get_record:wrong version number:../../vendor/node/deps/openssl/openssl/ssl/record/ssl3:record.c:252:
                        My url looks like this:
                        url: "https://192.168.1.187:8080/Pyhat.ics",
                        I tried using
                        localhost:8080
                        but it tried to force 127.0.0.1 which don’t work.
                        • ? Offline
                          A Former User @jani.karna
                          @jani-karna
                          Well, it’s not the issue of my module, anyway…
                          It seems, your RPI is not available to handle SSL of itself.
                          Can you open “https://192.168.1.187:8080/Pyhat.ics” or “https://localhost:8080/Pyhat.ics” on the browser of your RPI when MM is running?
                          Try “http” instead of “https”
                            jani.karna
                            Have to see if the problem comes back after RPI reinstall. It seems my SD-card just came to the end of its life.
                              jani.karna
                              I finally had a chance trying this. By trying “https://192.168.1.187:8080/Pyhat.ics” with browser while MM is running I get “ERR_SSL_PROTOCOL_ERROR”. I have no idea how to solve this. “Localhost” gives a little different error, but so does MM. But neither of them work. I know it is not about your module, but if you have any suggestions I’d be glad to hear.
                              • ? Offline
                                @jani-karna
                                try http instead of https
                                • ? Offline
                                  @jani-karna
                                  put your ical file into ~/MagicMirror/modules/MMM-CalendarExt2 then, try to use this URL;
                                  http://localhost:8080/modules/MMM-CalendarExt2/Pyhat.ics
                                    jani.karna
                                    @Sean said in MMM-CalendarExt2:
                                    For some reason “localhost” tries to use 127.0.0.1 which gives error, but I tried “http://192.168.1.187:8080/modules/MMM-CalendarExt2/Pyhat.ics” and that worked! Thank you!
                                    • BKeyportB Offline
                                      BKeyport Module Developer
                                      Hey, Just started using this module, and today’s update blew up everything… It and MMM-CalendarExtMinimonth fails now.
                                      Am I doing something wrong?
                                      			module: 'MMM-CalendarExt2',
                                      					calendars : [
                                      							url: "https://calendar.google.com/calendar/ical/mycalendar/info/basic.ics",
                                      							name: "Main Calendar", // Optional, Recommended
                                      							maxItems: 100,
                                      							scanInterval: 1000*60*1, // 1000*Seconds*minutes
                                      							beforeDays: 0,
                                      							afterDays: 999,
                                      							maxIterations: 100,
                                      							forceLocalTZ: false,
                                      					views: [
                                      							mode: "daily",
                                      							position: "top_center",
                                      							slotCount: 20,
                                      					scenes: [
                                      			module: "MMM-CalendarExtMinimonth",
                                      			position: "bottom_right",
                                      			refreshInterval: 60*2.5*1000,
                                      Thanks!
                                      • ? Offline
                                        A Former User @BKeyport
                                        @BKeyport
                                        Sorry, Yesterday I fixed something but it made another bug. I fixed it now.
                                        • BKeyportB Offline
                                          Thanks, that fixed it.
                                          The only thing I can’t figure out then is massive space between the end of the previous day’s activities, and the next day.
                                          Is there a way to solve this? Loving it otherwise.
                                          • ? Offline
                                            @BKeyport
                                            Controll that margin with hideOverflow and slotMaxHeight .
                                            https://github.com/eouia/MMM-CalendarExt2/wiki/2c.-Configuration:View
                                            • 6
                                            • 7
                                            • 8
                                            • 24
                                            • 25
                                            • 6 / 25
