    MMM-CalendarExt2
    486 Posts 83 Posters 949.3k Views 83 Watching
    • C Offline
      cskenney @Guest
      @Sean said in MMM-CalendarExt2:
      @cskenney said in MMM-CalendarExt2:
      I also want to change the background-color and possibly the (font) color.
      Sorry for the late reply. At weekends, I rarely am in front of computer.
      You can define class in your CSS. then assign it into your transfrom code.
      transform: (event) => {
        if (event.title.search("Recycle") > -1) {
          event.icon = "mdi:recycle"
          event.className = "CLASS_RECYCLE" // in your css/custom.css, define color and bgcolor for this class
        return event
      I figured that out about an hour ago and was coming back to the forums to revise my post. Thanks for confirming what I did works!
      • C Offline
        cskenney @scuppasteve
        @scuppasteve said in MMM-CalendarExt2:
        @Sean That worked perfectly . How would you go about making the slot event background not be a black gradient? I just want the whole thing to be transparent.
        You can adjust the background color in the CSS file.
        Since you already defined the eventName: “CHORES_CAL” you can use it in CSS.
        syntax:
        background-color: rgba(red, green, blue, alpha);
        alpha: 0~1 (0:transparent, 1:opaque)
        Try this in your CSS file.
        .CX2 .event.CHORES_CAL {
        	background-color:rgba(0,0,0,0);
        I believe that will make the background transparent for all the events in that eventName class.
          jani.karna
          @jani-karna
          1. Slightly narrow event’s width is intentional to avoid margin of error on calculation. It is hardcoded. But if you want to modify it by yourself,
            https://github.com/eouia/MMM-CalendarExt2/blob/a5d509ada997034f91e0790ad72e87512cb24c60/CALEXT2_Slot.js#L250
          eventDom.style.width = width - 15 + "px"
          Change 15 to what you want.
          Worked perfectly, thank you!
            jani.karna @Guest
            Can I also shrink the gap between events vertically somehow?
            Tell me more exact details? Even a picture will help.
            What I mean with gap between events is this:
            • ? Offline
              A Former User @jani.karna
              @jani-karna
              Hmmm… in Original CSS, there was no huge gap. It would be only 2px. I think you probably have modified CSS by yourself, but I don’t know what you changed. Sorry, can’t help you.
                jani.karna @Guest
                Thats fine, I’ll figure it out.
                In the upcoming calendar, I have location or additional information in the events and their font is too big. Can I somehow make it smaller? Here’s a pic, the last row being the additional information:
                • ? Offline
                  @jani-karna
                  https://github.com/eouia/MMM-CalendarExt2/wiki/4.-Styling
                  Each event has eventSub (and its sub-elements eventLocation and eventDescription). By default, agenda(upcoming and current) views would reveal eventSub, so, you can use that CSS selector to specify.
                    jani.karna @Guest
                    @jani-karna
                    Missed that styling part… :grimacing_face: got it working, thank you again!
                    • C Offline
                      code999
                      Hello again. is there a way to scroll the events when there are so many on a single day with displaying the (+x).
                      Thanks.
                      ? 2 Replies Last reply Reply Quote 0
                      • ? Offline
                        A Former User @code999
                        @code999
                        no. i was tried scrolling in my older CALEXT but too burden to rpi.
                        • ? Offline
                          @code999
                          Instead, you can sort and filter the order of events to be shown.
                          • C Offline
                            ChickenBeard
                            Did CalendarExt in Weeks (or Month) view automatically adjust the height of the day to accommodate the events?
                            I swear if there was only one or two events for a day (in a given week), the whole row was shorter.
                            • ? Offline
                              A Former User @ChickenBeard
                              @ChickenBeard
                              Not adjusted automatically. you can set the height of the slot manually.
                              • C Offline
                                ChickenBeard
                                Is it CX2 .slot ?
                                • ? Offline
                                  @ChickenBeard
                                  if you mean some table views (month, week), set slotMaxHeight of view configuration.
                                  https://github.com/eouia/MMM-CalendarExt2/wiki/2c4.-View:week,-month
                                  • C Offline
                                    code999 @Guest
                                    @Sean okay. it would be great to have though. not seeing the events is not good. limited space on the screen so i cant just make more room because then i will lose a full week from the month view.
                                    thanks.
                                    • C Offline
                                      code999
                                      @Sean could you help me do that anyway? lol
                                      i would really like it to do that.
                                      Thanks.
                                      • ? Offline
                                        @code999
                                        do what?
                                        • C Offline
                                          code999
                                          @Sean make the events under a date that is not showing scroll.
                                          I am trying to figure it out but I have no coding knowledge at all so I just randomly change things and see what it does but I am not getting anywhere doing that at all.
                                          • ? Offline
                                            @code999
                                            To show more events in a cell, just set bigger slotMaxHeight. And shrinking the font-size and height of event element could be help.
                                            But anyway, Usual MagicMirror Screen has not so enough space to show many events with Table Views(month and week view). Even normal Desktop calendar programs like Google Calendar MS-Office or Apple Calendar couldn’t show too many events in a cell.
                                            Maybe you can make show 5 or 6 events in a day cell. But What about 7 events or 8 events? It could not be solved at last.
                                            Auto-scroll could be the ideal solution, but RPI has not enough power to maintain so many scrolling effects. (Maybe RPI4 could have enough power but many ppl also are using even RPI0)
                                            However, you want it, use MMM-CalendarExt instead. It has that feature but will be very slow.
                                            Another possible approach would be to filter and/or to sort events to show. Some of the events will not be more important than others to show in that view. You can filter unimportant events not to show, Or at least, you can sort them to hide.
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 24
                                            • 25
                                            • 9 / 25
