    Problem server client configuration
    21 Posts 6 Posters 10.0k Views 5 Watching
      Akkor
      @idoodler @bhepler
      I Have setup chromium to autostart and it’s ok
      But I would like use Electron to use the voice command on client like this one https://github.com/mykle1/Hello-Lucy or https://github.com/joanaz/MMM-MirrorMirrorOnTheWall but I don’t know if it’s doable in server/client mode
      idoodlerI 1 Reply Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @Akkor
        @akkor I don’t think you can use Hello-Lucy in client mode.
        But I bet the developer @Mykle1 knows it.
          Akkor
          ok so wait for @Mykle1
            macnice
            This post is deleted!
            • idoodlerI Offline
              idoodler Module Developer @macnice
              @macnice Hi, is your issue related to the problem described in this thread? You May want to create a new thread if the issue are not related.
                Mykle1 Project Sponsor Module Developer @idoodler
                @idoodler said in Problem server client configuration:
                @Akkor ok so wait for @Mykle1
                I never even thought about trying it. I just run standard installations. If @idoodler doesn’t think it will work, it probably won’t. However, you could always try for yourself.
                • idoodlerI Offline
                  idoodler Module Developer @Mykle1
                  @mykle1 I am currently unable to test it. I quickly checked your code on my phone, but I didn‘t quite got your code :flushed_face:
                  I am curious, how did you make the voice recognition?
                    Akkor
                    It could be fine if someone really skilled test Hello Lucy server/client mode
                      I didn’t mean that YOU should test it. I meant that @Akkor should test it as it is he that is looking for that functionality.
                      I didn’t. MMM-voice was already written by @strawberry-3-141. It’s a fantastic piece of software. I just made some additions/modifications to original so that I could hide/show individual modules, hide/show pages of modules, hide show all modules, turn the display on and off, audio, all through the use of notifications. I use it every day for a year now. It’s stable, very fast and does exactly what I want it to do.
                        Akkor
                        @Mykle1
                        I could test but I need your assistance 'couse I’m not a programmer
                        I’m just good following guide… :(
                        • 2 / 3
