    iFrame module ip camera
    5 Posts 4 Posters 3.4k Views 3 Watching
    • C Offline
      costascontis
      Trying to use MMM-iFrame-Ping module to show the videostream from my out door ip camera.
      i add to my config.js :
      module: 'MMM-iFrame-Ping',
      		position: 'middle_center',	// This can be any of the regions.
      			url: "http://admin:xxxxxxxxx@ipcamera_address:port/videostream.cgi",
      			autoRefresh: false, //set to false for video
      			scrolling: "no",
      and i always get “NOK PING” and no video.
      What am i doing wrong?I tryied an alternative ip format that it is working fine to my openhab/habpanel frame widget :
      http://ipcamera_address:port/videostream.cgi?user=admin&pwd=xxxxxxx
      but no luck also…using both urls at chrome or vlc i get videostream.
        Ramez
        in config file change the lines:
        address: "localhost", to address: "", and ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], to ipWhitelist: [],
        then try…if not then stream it with other MMM-iFrame module…I’ve just tried to stream my mobile camera capture using IP webcam it’s not working in MMM-iFrame-ping module but in MMM-iFrame it’s super awesome :raising_hands:
        • bheplerB Offline
          bhepler Module Developer
          You may wish to look at MMM-RTSPStream.
          • C Offline
            costascontis
            thnx guys for ur answers, i managed to view my cam with MMM-iFrame,My problem is that the frame is too big.My cam is 640x480 and i want a smaller iframe for example 320x280.If i change the iFrame to that heigth and width i loose the half of my ip cam view.Is there a way to make all the frame smaller without decreasing the actual camera’s resolution?
              drx1984 @costascontis
              @costascontis please tell me how you did it with the MMM-iFrame module.
              would you have me an example config ??
              Please help me thank you
