    Updated to MM v2.6.0 now all I get is only a black Electron screen...
    7 Posts 3 Posters 2.8k Views 1 Watching
    • Cr4z33C
      Cr4z33
      So I did the update and ended up with the black empty screen.
      I then made backup of my config and modules and deleted the whole MagicMirror folder to make a fresh install.
      I keep getting the black empty Electron screen and this with everything default (no custom config, no custom modules added yet)… :disappointed_face:
      Ran also sudo apt-get update and sudo apt-get upgrade
      Here is what comes up from the console:
      > magicmirror@2.6.0 start /home/pi/MagicMirror
      > sh run-start.sh
      Starting MagicMirror: v2.6.0
      Loading config ...
      Loading module helpers ...
      All module helpers loaded.
      Server started ...
      Starting module: newsfeed
      { Error: listen EADDRINUSE 127.0.0.1:8080
          at Object._errnoException (util.js:1024:11)
          at _exceptionWithHostPort (util.js:1046:20)
          at Server.setupListenHandle [as _listen2] (net.js:1351:14)
          at listenInCluster (net.js:1392:12)
          at GetAddrInfoReqWrap.doListen [as callback] (net.js:1501:7)
          at GetAddrInfoReqWrap.onlookup [as oncomplete] (dns.js:97:10)
        code: 'EADDRINUSE',
        errno: 'EADDRINUSE',
        syscall: 'listen',
        address: '127.0.0.1',
        port: 8080 }
      Launching application.
      Please help as my mirror is almost done. :confounded_face:
        sdetweil
        @cr4z33 said in Updated to MM v2.6.0 now all I get is only a black Electron screen...:
        means some other app is using port 8080…
        I would reboot
        Cr4z33C 1 Reply Last reply
        • Cr4z33C
          Cr4z33 @sdetweil
          @sdetweil doh how could I not think about it lol! :rolling_on_the_floor_laughing: :rolling_on_the_floor_laughing:
          Thanks working now!
            sdetweil @Cr4z33
            @cr4z33 great!.. can u mark your problem as closed…
            • Cr4z33C
              Cr4z33 @sdetweil
              @sdetweil done.
              Reply Quote 1
              • michael5rM
                michael5r Module Developer
                In case someone else has this problem, instead of rebooting just run the following in your terminal:
                kill -9 $(lsof -t -i :8080)
                That’ll kill the current process on port 8080.
                Reply Quote 1
                  sdetweil
                  or kill all node related
                  ps -ef | grep node | awk  '{print $2}' | xargs kill -9
