    Error in config file
    5 Posts 4 Posters 1.4k Views 3 Watching
      afrench10
      Hi Folks,
      Can someone please help troubleshoot the error in my config file? I’m not a professional dev, and could use some assistance :) Please reference below:
      var config = {
      	port: 8080,
      	language: "en",
      	timeFormat: 24,
      	units: "imperial",
      			module: "alert",
      			module: "updatenotification",
      			position: "top_bar"
      			module: "clock",
      			position: "top_left"
      			header: "US Holidays",
      						symbol: "calendar-check-o ",
      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
      			module: "compliments",
      			position: "lower_third"
      			module: "currentweather",
      				locationID: "4887398",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
      				appid: "c9306b83172dfaa7dc5c2b72cdcc3ff7"
      			module: "weatherforecast",
      			header: "Weather Forecast",
      				locationID: "4887398",  //ID from http://www.openweathermap.org/help/city_list.txt
      			module: "newsfeed",
      			position: "bottom_bar",
      				feeds: [
      						title: "New York Times",
      				showSourceTitle: true,
      				showPublishDate: true
      			module: "CTA",
      			position: "bottom_left",
      				updateTime: 60000, // 1 minute, the API does not update much more often so going below this is unnecessary
      				//Bus Routes
      				ctaApiKey: "cg4QkprLT9WppdSuJXpDLB9PF",
      				busStopName: "66 - Chicago - Westbound",  // String value, Name your bus stop
      				stopId: 601, // Bus station ID: Chicago and Milwaukee example; go to http://www.transitchicago.com/riding_cta/systemguide/default.aspx to find your stop ID
      				maxResult: 1,  // The maximum number of incoming busses you want to display for bus stops
      				//Train Routes
      				ctaApiKeyTrain: "your-train-APIkey",
      				trainStopName: "Chicago Red Line",  //String value, name your train stop
      				trainStationID: CHIR, //Train station ID:  Chicago Blue line example; http://www.transitchicago.com/developers/ttdocs/default.aspx#_Toc296199909
      				maxResultTrain: 5, // Max number of incoming trains to disply
      				moduleInstance: 3, // To run multiple instances of this module
      I hope this helps. Thanks in advance for your insight!
      • ? Offline
        [[global:former-user]] @afrench10
        @afrench10
        trainStationID: might have string as its value. You missed quotation marks.
        trainStationID: "CHIR",
        A 1 Reply Last reply Reply Quote 3
          afrench10 @Guest
          @sean Thank you so much, Sean!
            bhepler Module Developer @afrench10
            @afrench10 - Glad you got it fixed! Remember to mark the question as solved.
            • cowboysdudeC Offline
              cowboysdude Module Developer
              Ok so before you add ANY new modules make a backup of your config so you will always have a working copy :)
