Raspberry Pi 3 and Chromium
10 Posts 4 Posters 7.5k Views 3 Watching
  • F Offline
    Flo-lapin
    Hi guys!
    I am following Xonay Labs tutorial to setup my MagicMirror and I got a problem; I tried to solve it but did not workout…
    In fact in Part V, it shows how to get Chromium automatically start on boot. And so, I have Chromium downloaded, but I can not get it to launch on boot. I copied in the following code into autostart but nothing happens when I save and reboot.
    @xset s off
    @xset -dpms
    @xset s noblank
    @chromium --kiosk --incognito http://localhost
    Am I missing something?
    Thank you!
    P 1 Reply Last reply May 14, 2016, 7:09 PM Reply Quote 0
    • W Offline
      Wilco89
      When you are using the MM2 on github you Can skip that. The New Magic Mirror doesn’t use chromium etc anymore:
      https://github.com/MichMich/MagicMirror
      Look at the readme.
      Succes!!
      • F Offline
        Flo-lapin
        Oh! Thank you :)
        W 1 Reply Last reply May 14, 2016, 7:10 PM Reply Quote 0
        • P Offline
          paviro Admin @Flo-lapin
          @MichMich maybe add a note that the tutorial is outdated?
          We're all stories in the end. Just make it a good one, eh?
          – The Doctor
          M 1 Reply Last reply May 15, 2016, 9:24 AM Reply Quote 0
          • W Offline
            Wilco89 @Flo-lapin
            @Flo-lapin best is to start with a clean install of Raspbian Jessy, and follow the instuctions.
            Within An hour you can Have it Running.
            • F Offline
              Flo-lapin
              I’ve just installed the whole bundle with the Automatic Installer (much easier indeed)!
              I am having another problem running the MagicMirror, apparently the problem is with electro js/electron.js… I will look around on the forum…
              Thank you so much for your fast answers :)
              • W Offline
                Wilco89
                What is the problem?
                • F Offline
                  Flo-lapin
                  @Wilco89 I am having exactly the same problem as @benjee (see Starting MagicMirror v2 beta [solved]). I am following the thread recommandations by updating the electron. It works now!
                  W 1 Reply Last reply May 14, 2016, 7:43 PM Reply Quote 0
                  • W Offline
                    Wilco89 @Flo-lapin
                    @Flo-lapin Nice to Hear! Succes with setting up the Mirror!
                      MichMich Admin @paviro
                      @paviro that message is already there. OP must have missed it.
