    syntax errors
    11 Posts 5 Posters 4.6k Views 5 Watching
    • E Offline
      Egnos
      Hi guys,
      I’m a beginner and I’m setting up the module MMM-AssistantMk2 but I don’t know why if I add this two configuration:
      record: { // Full values are in FOR EXPERTS section.
      recordProgram: “arecord”, // Defaults to “arecord” - also supports “rec” and “sox”
      device: null // recording device (e.g.: “plughw:1”)
      play: { // Full values are in FOR EXPERTS section.
      playProgram: “mpg321”, // recommended.
      the MM show me: WARNING! Could not validate config file. Please correct syntax errors. Starting with default configuration.
      Where am I wrong?
      I attach my config.js
      Thanks everyone.
      [0_1546719570197_config.js](Caricamento 100%)
      idoodlerI 1 Reply Last reply Reply Quote 0
      • idoodlerI Offline
        idoodler Module Developer @Egnos
        @egnos Please show us the full config.js file and mark it as Code by selecting the whole content of the file and click on the </> button.
        You can find a markdown tutorial here: https://commonmark.org/help/
          sdetweil
          Change directory to tests/configs
          And run
          Node config_check.js
          • E Offline
            Egnos
            Sorry, the config.js below:
            /* Magic Mirror Config Sample
             * MIT Licensed.
            var config = {
            	port: 8080,
            	language: "en",
            	timeFormat: 24,
            	units: "metric",
            		  module: "MMM-AssistantMk2",
            		    deviceLocation: {
            					coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
            					latitude: 45.200049, // -90.0 - +90.0
            					longitude: 7.568917, // -180.0 - +180.0
            			profiles: {
            				"default" : { // profile name.
            				profileFile: "default.json", // profile file name.
            				lang: "it-IT"
            				//currently available (estimation, not all tested):
            				//  de-DE, en-AU, en-CA, en-GB, en-US, en-IN
            				// fr-CA, fr-FR, it-IT, ja-JP, es-ES, es-MX, ko-KR, pt-BR
            				// https://developers.google.com/assistant/sdk/reference/rpc/languages
            			record: { // Full values are in `FOR EXPERTS` section.
            				recordProgram: "arecord",  // Defaults to "arecord" - also supports "rec" and "sox"
            				device: null        // recording device (e.g.: "plughw:1")
            			play: { // Full values are in `FOR EXPERTS` section.
            				playProgram: "mpg321", // recommended.
            			module: "alert",
            			module: "updatenotification",
            			position: "top_bar"
            			module: "clock",
            			position: "top_left"
            			header: "US Holidays",
            						symbol: "calendar-check-o ",
            						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
            			module: "compliments",
            			position: "lower_third"
            			module: "currentweather",
            				locationID: "",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
            				appid: "YOUR_OPENWEATHER_API_KEY"
            			module: "weatherforecast",
            			header: "Weather Forecast",
            				locationID: "5128581",  //ID from http://www.openweathermap.org/help/city_list.txt
            			module: "newsfeed",
            			position: "bottom_bar",
            				feeds: [
            						title: "New York Times",
            				showSourceTitle: true,
            				showPublishDate: true
            Thanks.
            • G Offline
              ganget
              Heey i just check your config file and found that there are some differences compared to the config in the readme file. Something i noticed is to check if there is a }, after each { . Example
              deviceLocation: {
              there is twice }, at the end to close both the {
              Can you check for me if this works?
                  // --- ESSENTIALS / modifying for your environment might be needed.
                  deviceLocation: {
                  defaultProfile: "default", // If you have several profiles and want to set one of them as default profile, describe here.
                  profiles: {
                      lang: "it-IT"
              E 1 Reply Last reply Reply Quote 2
              • E Offline
                Egnos @ganget
                Sorry @ganget, but I’m not sure that the configuration you propose can work, because after opening a “{” is closed with a “},” and the “},” is used only for the closure of the entire module and not the single configurations. Correct?
                Is it possible that the problem is on the comma after “mpg321”?
                Thank you all!
                  sdetweil
                  from the MM folder run
                  node tests/configs/check_config.js
                  find and fix all errors, starting from the top of the list
                  • Y Offline
                    yawns Moderator
                    @ganget is right, your { } are mixed up.
                    This passes the test on jshint.com
                     * MIT Licensed.
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 24,
                    	units: "metric",
                    		    deviceLocation: {
                    			profiles: {
                    				lang: "it-IT",
                    			module: "alert",
                    			position: "top_bar"
                    			module: "clock",
                    			module: "newsfeed",
                    				feeds: [
                    Also, if you look at the readme for this module configuration you notice the { } need to be set different.
                    • E Offline
                      Egnos @sdetweil
                      @sdetweil said in syntax errors:
                      Thanks, as soon possible I will try this command.
                      Ok thanks @ganget, but I do not understand why if I remove the comma of the “}” referring to “play” the configuration does not give problems but if I remove the comma from the “}” referring to “record” it goes into error…
                      Sorry for the banalities … but I’m a beginner.:smiling_face_with_open_mouth_cold_sweat:
                      S G 2 Replies Last reply Reply Quote 0
                        sdetweil @Egnos
                        @egnos comma is continuation… its ok to have an EXTRA , after the play group,… it is NOT ok to have a missing , between things
                        • G Offline
                          ganget @Egnos
                          @egnos As @sdetweil already stated the comma’s are for showing the code that there is more to run after the line. It is no problem to have a extra comma at the end. But if you don’t put a comma the code doesn’t run further and gives you a syntax error. The {} are for making a object in JS, if you don’t close the object with a } you will also get a syntax error.
