SOLVED first installation on RPi3 failed
Folks, this is my first time to install MM, and I never had any prior experience on this.
This is the error I am getting, anyone have idea why?pi@raspberrypi:~/MagicMirror $ npm install
(node:6315) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm WARN package.json current-week-number@1.0.7 license should be a valid SPDX license expression
npm WARN package.json rrule-alt@2.2.8 No license field.
npm WARN package.json valid-url@1.0.9 No license field.
npm ERR! Error: Method Not Allowed
npm ERR! at errorResponse (/usr/share/npm/lib/cache/add-named.js:260:10)
npm ERR! at /usr/share/npm/lib/cache/add-named.js:203:12
npm ERR! at saved (/usr/share/npm/node_modules/npm-registry-client/lib/get.js:167:7)
npm ERR! at FSReqWrap.oncomplete (fs.js:135:15)
npm ERR! If you need help, you may report this entire log,
npm ERR! including the npm and node versions, at:
npm ERR! http://github.com/npm/npm/issuesnpm ERR! System Linux 4.14.79-v7+
npm ERR! command “/usr/bin/node” “/usr/bin/npm” “install”
npm ERR! cwd /home/pi/MagicMirror
npm ERR! node -v v8.11.1
npm ERR! npm -v 1.4.21
npm ERR! code E405
npm ERR!
npm ERR! /home/pi/MagicMirror/npm-debug.log
npm ERR! not ok code 0 -
@lkthomas said in first installation on RPi3 failed:
npm -v 1.4.21
your npm version is very old.
Try to first update npm vianpm install -g npm@latest
Also try to upgrade node, e.g. via the small program “n”
npm install -g n n stable
@lavolp3 said in first installation on RPi3 failed:
n stable
doesn’t help:
pi@raspberrypi:~/MagicMirror $ sudo npm install -g npm@latest
(node:6358) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm WARN package.json path-is-inside@1.0.2 No README data
npm WARN package.json sorted-object@2.0.1 No README data
npm WARN package.json config-chain@1.1.12 No license field.
npm WARN package.json cyclist@0.2.2 No license field.
npm WARN package.json json-schema@0.2.3 No license field.
npm WARN package.json punycode@1.4.1 punycode is also the name of a node core module.
npm WARN package.json qrcode-terminal@0.12.0 No license field.
npm WARN package.json string_decoder@1.1.1 string_decoder is also the name of a node core module.
/usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
/usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
npm@6.5.0 /usr/local/lib/node_modules/npmpi@raspberrypi:~/MagicMirror $ sudo npm install -g n
/usr/bin/n -> /usr/lib/node_modules/n/bin/n-
n@2.1.12
added 1 package from 4 contributors in 1.974s
pi@raspberrypi:~/MagicMirror $ sudo n stableinstall : node-v11.6.0
mkdir : /usr/local/n/versions/node/11.6.0
fetch : https://nodejs.org/dist/v11.6.0/node-v11.6.0-linux-armv7l.tar.gz
######################################################################## 100.0%
installed : v11.6.0
(node:6481) [DEP0022] DeprecationWarning: os.tmpDir() is deprecated. Use os.tmpdir() instead.
npm ERR! code E405
npm ERR!
better reboot after installing new npm and node versions
looking okay after reboot, thanks
