    another question... regarding TV's as MM monitors.
    24 Posts 4 Posters 9.9k Views 4 Watching
      Mykle1 Project Sponsor Module Developer @justjim1220
      @justjim1220
      I’m not understanding what you mean by “the TV cuts off the MM display around all 4 edges”. The MM display is outside the edges of the monitor?
      justjim1220J 2 Replies Last reply Reply Quote 0
      • justjim1220J Offline
        justjim1220 Module Developer @Mykle1
        @mykle1
        yep
        Jim Hallock - 1995
          @mykle1
          I will take a couple pics…
          Jim Hallock - 1995
          Mykle1M 2 Replies Last reply Reply Quote 0
            @justjim1220
            It sounds like a “zoom in” is being deployed. Try this while MM is running:
            Zoom Out = Control and - (That’s a dash/minus sign)
            Default Display Size = Control and 0 (That’s a zero)
            This should survive restart and reboot.
            EDIT
            Just thought of something else. If you played with margins in css already, you may not have cleared those changes. Negative margins would do the same thing
            S justjim1220J 2 Replies Last reply Reply Quote 0
              @justjim1220
              Never mind about the zoom in and out. I just tested both. They both stay within the margins of the display so investigate the css further
                sdetweil @Mykle1
                @mykle1 on one of my tvs this is called overscan in the tv display settings
                Mykle1M justjim1220J 2 Replies Last reply Reply Quote 0
                  Ahhh, ok, I did not know this, never having used a tv with MM. Thanks for the info
                    @mykle1
                    yeah, I don’t have any negative margins set
                    Jim Hallock - 1995
                      @justjim1220
                      Ok, was just touching upon things to try to help
                        justjim1220 Module Developer @sdetweil
                        I don’t see any overscan in my settings…
                        Jim Hallock - 1995
                        • 3 / 3
