    error when try to start mm
    3 Posts 2 Posters 1.7k Views 1 Watching
    • L Offline
      lpt2007
      npm info it worked if it ends with ok
      npm info using npm@5.0.3
      npm info using node@v8.1.3
      npm info lifecycle magicmirror@2.6.0~prestart: magicmirror@2.6.0
      npm info lifecycle magicmirror@2.6.0~start: magicmirror@2.6.0
      magicmirror@2.6.0 start /opt/magic_mirror
      sh run-start.sh
      npm info lifecycle magicmirror@2.6.0~start: Failed to exec start script
      npm ERR! code ELIFECYCLE
      npm ERR! errno 1
      npm ERR! magicmirror@2.6.0 start: sh run-start.sh
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.6.0 start script.
      npm ERR! /fakehome/root/.npm/_logs/2019-02-10T00_24_58_360Z-debug.log
      • L Offline
        lpt2007 @lpt2007
        I figured out the error occured when I try to run mm from ssh if I run directly on rpi consol it works?
        But I need to find solution to run mm from ssh. How?
          AxLed Module Developer
          @lpt2007
          Have you read the readme of MagicMirror?
          Also note that:
          npm start does not work via SSH. But you can use DISPLAY=:0 nohup npm start & instead.
          This starts the mirror on the remote display.
          AxLED
