    PM2 does not start the Magic Mirror
    pm2errorenoent
    15 Posts 5 Posters 19.6k Views 4 Watching
      DarioCas
      Hi!
      I recently wanted to build a magicmirror.
      I installed the Magicmirror software and also automatically pm2.
      Everything worked fine. The Magicmirror came up.
      Then i rebooted the Raspberry.
      From there on pm2 didn’t work anymore.
      This was in the log:
      //Error: ENOENT: no such file or directory, open 'package.json'
      Does someone know what i have to do?
      Regards
      Dario Casciato
      • bheplerB Offline
        bhepler Module Developer @DarioCas
        @dariocas - First, check to see if anything pm2 related still exists on your Pi: type pm2 status all. If you get a table in reply, then pm2 is there, you just need to configure it.
        If you get “command not found” then you’ll need to install pm2 manually: npm install pm2 -g. Once that finishes, you’ll want to initalize pm2 with pm2 startup. It will do a mess of things and at the end it will output a command for you to enter. This is important! You need to copy that command from the output and paste it into the command line. That will enable pm2 to start when the Pi reboots.
        Give it a go and let us know what you find.
        • lavolp3L Offline
          lavolp3 Module Developer
          Dario, what was the command that created this error message.
          You need to give us a bit more information
          How to troubleshoot modules
          MMM-soccer v2, MMM-AVStock
            DarioCas @lavolp3
            @lavolp3 this was in the LOG of pm2:
            Error ENOENT no such file or directory, open ‘packages.json’
            I think the command was open packages.json
            • lavolp3L Offline
              lavolp3 Module Developer @DarioCas
              @dariocas So the error message was created on startup of the mirror? And the mirror did not start?
              Can you start the mirror without pm2?
              cd ~/MagicMirror
              npm start dev
              Can you post the complete log of the process?
              Can you post what is inside the file that was created for the pm2 process?
              Still not enough information to help, sorry.
                DarioCas @lavolp3
                @lavolp3 The Mirror does start if i start it manually.
                this is the whole error log:
                    at Object.fs.openSync (fs.js:646:18)
                    at Object.fs.readFileSync (fs.js:551:33)
                    at Object.<anonymous> (/home/pi/MagicMirror/js/app.js:15:32)
                    at Module._compile (module.js:652:30)
                    at Object.Module._extensions..js (module.js:663:10)
                    at Module.load (module.js:565:32)
                    at tryModuleLoad (module.js:505:12)
                    at Function.Module._load (module.js:497:3)
                    at Module.require (module.js:596:17)
                    at require (internal/module.js:11:18)
                and this is the log out:
                > magicmirror@2.6.0 start /home/pi/MagicMirror
                > sh run-start.sh
                Starting MagicMirror: v2.6.0
                Loading config ...
                Loading module helpers ...
                All module helpers loaded.
                Server started ...
                Starting module: newsfeed
                Launching application.
                Create new calendar fetcher for url: http://www.calendarlabs.com/templates/ical/US-Holidays.ics - Interval: 300000
                Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
                Shutting down server...
                Stopping module helper: updatenotification
                Stopping module helper: calendar
                Stopping module helper: newsfeed
                These are the logs of pm2.
                The Mirror does not start if i start it from pm2.
                thanks for helping! :)
                1 Reply Last reply Reply Quote -1
                • K Offline
                  Klinge
                  I have the same problem.
                  I installed a fresh MM with pm2. The MM started. But after a reboot the MM does not start automatically.
                  Unfortunately I have no idea.
                  It would be grateful, if someone could help me.
                  Thank you in advance
                  • lavolp3L Offline
                    I would suggest to both of you to follow the complete guide setting up pm2 and the autostart again. It doesn’t take long.
                    Besides that, what does
                    pm2 status
                    give you after reboot?
                    • K Offline
                      Klinge
                      pm2 status is
                      pi@raspberrypi:~ $ pm2 status
                      │ Name        │ id │ mode  │ status │ ↺      │ cpu │ memory
                      │ MagicMirror │ 0  │ 2.6.0 │ fork   │ online │ 799 │ 0%     │ 16.8 MB   │
                       Use `pm2 show <id|name>` to get more details about an app
                      and in pm2 log I get this every two seconds
                      pi@raspberrypi:~/.pm2 $ tail -f pm2.log
                      2019-02-15T15:36:47: PM2 log: App [MagicMirror:0] online
                      2019-02-15T15:36:48: PM2 log: App [MagicMirror:0] exited with code [1] via signal [SIGINT]
                      I tried the complete guide with creating an .sh-File and so on. But unfortenately with the same effect.
                      lavolp3L 1 Reply Last reply Reply Quote 1
                      • lavolp3L Offline
                        lavolp3 Module Developer @Klinge
                        @klinge can you first do
                        pm2 stop all
                        and then
                        cd ~/MagicMirror
                        npm start dev
                        Maybe you can see what happens there.
                        It seems that pm2 is running the magicmirror start script but MagicMirror won’t start
