    increase brightness of magic mirror
    8 Posts 4 Posters 7.6k Views 4 Watching
      dstoneham
      I need to adjust the brightness of a HDMI monitor running raspberry pi desktop, when I run magic mirror its very dark and hard to see in daylight the monitor is full brightness can I adjust the brightness from the raspberry with a software install, any ideas from someone would be great thanks
        j.e.f.f Project Sponsor Module Developer @dstoneham
        @dstoneham brightness is usually adjusted by controls on the monitor itself, or a TV remote control if you’re using a TV.
        I’m assuming you’re finding it dimmer than usual behind your two-way glass mirror correct? This is to be expected given the nature of how two-way glass works. If you can’t get your screen bright enough, you have three options:
        • move your mirror to a location that doesn’t get direct light shining on it. This will likely make a drastic difference, and it’s free!
        • use a different monitor that is capable of getting much brighter
        • use two-way glass that offers more transmittance. Lots of opinions on here as to what the right level is… some say 50% reflective, 50% transmittive. I personally went with 70% reflective, 30% transmittive and I find it adequate but in direct sunlight the screen is hard to read.
          dstoneham @j.e.f.f
          @j-e-f-f Thanks was hoping for some software to increase the display
            robiv8
            are you use the module remote-control?
            control the brightness in the control menu
            Was always set to 50% with me although I did not enter anything.
              dstoneham
              hi thanks I did try remote control and yes you are right its 50% but does not always save the settings have to keep going back and change to 100% every few days don’t know why it saves but the dims again, so was looking for anything else people had used.
                @dstoneham some monitors have an “eco” mode or something named similar tat automatically adjusts the brightness based on ambient light. See if your monitor has a similar setting, and try turning it off.
                  dstoneham
                  Yep checked monitor at full brightness no eco settings shame as must be something to increase brightness will keep looking thanks anyway
                    MadScientist @dstoneham
                    @dstoneham Do you have a screen with CCFL or LED backlight. If CCFL you could try to replace with a LED strip and see how that works. You can those very cheap already. I did that with an old 17" LCD which had 4 CCFL tubes. Now it has 2 LED strips instead and the brightness increased.
