    MMM-MealViewer
    48 Posts 6 Posters 34.5k Views 6 Watching
      @htilburgs and the number of films in the array would be
      json_data.film.length
      using the developers window you can put a code stop on the line after the xml2json
      and then u can explore the conversion…
      you can also use console.log(JSON.stringify(some_object)) and it will dump the structure in json format
      • htilburgsH Offline
        htilburgs
        Mmmm… not working yet…
        My current node_helper.js:
        const NodeHelper = require('node_helper');
        const request = require('request');
            start: function() {
                console.log("Starting node_helper for: " + this.name);
        	// Changes XML to JSON
        	xmlToJson: function(xml) {
        		// Create the return object
        		var obj = {};
        		if (xml.nodeType == 1) { // element
        			// do attributes
        			if (xml.attributes.length > 0) {
        			obj["@attributes"] = {};
        				for (var j = 0; j < xml.attributes.length; j++) {
        					var attribute = xml.attributes.item(j);
        					obj["@attributes"][attribute.nodeName] = attribute.nodeValue;
        		} else if (xml.nodeType == 3) { // text
        			obj = xml.nodeValue;
        		// do children
        		if (xml.hasChildNodes()) {
        			for(var i = 0; i < xml.childNodes.length; i++) {
        				var item = xml.childNodes.item(i);
        				var nodeName = item.nodeName;
        				if (typeof(obj[nodeName]) == "undefined") {
        					obj[nodeName] = xmlToJson(item);
        				} else {
        					if (typeof(obj[nodeName].push) == "undefined") {
        						var old = obj[nodeName];
        						obj[nodeName] = [];
        						obj[nodeName].push(old);
        					obj[nodeName].push(xmlToJson(item));
        		return obj;
        	getMTVM: function(url) {
        		request(url, function(err, res, body) {
        		// if no error and server was happy
        			if(err == null && res.statusCode ==200){
        			console.log(body);
        			var json_data = this.xmlToJson(body)
        			console.log("Text is " + json_data.film[0].titel)
                if (notification === 'GET_MTVM') {
                    this.getMTVM(payload);
        In the dev console I get an error:
        TypeError: this.xmlToJson is not a function
        (still trying to learn JS, but not afraid to ask and AI is my best friend) ☺
          sdetweil @htilburgs
          @htilburgs ah the fun of ‘this’…
                         let self=this
          			   console.log(body);
          			   var json_data = self.xmlToJson(body)
          htilburgsH 1 Reply Last reply Reply Quote 0
            htilburgs @sdetweil
            @sdetweil Yeah! That part is working. Now I’ve an other error which has something to do with the xmlToJson function:
            TypeError: xml.hasChildNodes is not a function
            Any idea?
              sdetweil @htilburgs
              @htilburgs yeh, tricky crap… they had a special runtime that supported that… sorry…
              have to use one of the libs…
              in your module folder do
              npm install xml2js
              then in your code
              const xml2js = require('xml2js');
              then
                             let self=this
              			   console.log(body);
              			   xml2js.parseString(body,function (err,result) {
              			       let json_data = result // not needed but may make more clear
                htilburgs @sdetweil
                @sdetweil Almost there I think ;-)
                TypeError: Cannot read property '0' of undefined
                    at /home/pi/MagicMirror/modules/MMM-MyTVMovies/node_helper.js:28:47
                    at Parser.<anonymous> (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:306:18)
                    at Parser.emit (events.js:182:13)
                    at SAXParser.onclosetag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:264:26)
                    at emit (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:624:35)
                    at emitNode (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:629:5)
                    at closeTag (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:889:7)
                    at SAXParser.write (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/sax/lib/sax.js:1436:13)
                    at Parser.exports.Parser.Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:325:31)
                    at Parser.parseString (/home/pi/MagicMirror/modules/MMM-MyTVMovies/node_modules/xml2js/lib/parser.js:5:59)
                Has this something to do with the json_data.film[0].titel ??
                Or is it something else?
                When I remove .film[0].titel I got:
                Text is [object Object]
                200[object Object]
                  sdetweil @htilburgs
                  @htilburgs u should look at the data format
                                 let self=this
                  			   console.log(body);
                  			       console.log(JSON.stringify(json_data))
                    htilburgs @sdetweil
                    @sdetweil JSON is perfect:
                    Thanks for the help so far!! Now I have my data I can play around with it.
                    • 3 / 3
