    YAPi0 Installer Stretch Lite
    118 Posts 4 Posters 114.5k Views 3 Watching
      bdream
      that’s great :grinning_face:
      at the beginning it asks that’s not an Raspberry 2 or 3… continue?
      So I try with Raspberry Zerro again.
      hope it will work now as I will be off next 2-3 weeks.
      cheers, bdream
        sdetweil @bdream
        @bdream correct, just hit enter to continue
          bdream
          it’s running now.:crossed_fingers_medium-light_skin_tone:
          cheers, bdream
            bdream
            Just get following warnings similar to my post 3 days ago
            npm WARN npm npm does not support Node.js v10.15.2
            npm WARN npm You should probably upgrade to a newer version of node as we
            npm WARN npm can't make promises that npm will work with this version.
            npm WARN npm Supported releases of Node.js are the latest releases of 4, 6, 7, 8, 9.
            npm WARN npm You can find the latest version at https://nodejs.org/
            /usr/local/bin/npm -> /usr/local/lib/node_modules/npm/bin/npm-cli.js
            /usr/local/bin/npx -> /usr/local/lib/node_modules/npm/bin/npx-cli.js
            + npm@6.11.3
            added 430 packages from 833 contributors in 299.269s
            npm installation Done!
            cheers, bdream
              bdream
              also this warning
              Installing dependencies ...
              cheers, bdream
                sdetweil @bdream
                @bdream so far so good… ignore warnings… 1st upgraded npm to latest
                  bdream
                  < magicmirror2.8.0 install /home/pi/MagicMirror
                  > cd vendor && npm install
                  npm WARN optional SKIPPING OPTIONAL DEPENDENCY: fsevents@1.2.4 (node_modules/fsevents):
                  npm WARN notsup SKIPPING OPTIONAL DEPENDENCY: Unsupported platform for fsevents@1.2.4: wanted {"os":"darwin","arch":"any"} (current: ("os":"linux","arch":"arm")
                  cheers, bdream
                    sdetweil @bdream
                      bdream
                      npm WARN grunt-stylelint@0.11.1 requires a peer of stylelint@^10.0.0 but none is installed. You must install peer dependencies yourself.
                      cheers, bdream
                        sdetweil @bdream
                        @bdream still good
                          bdream
                          now the question if I want to use pm2 for autostart MM I will state YES
                          cheers, bdream
                            sdetweil @bdream
                            @bdream correct, reply yes or y
                              bdream
                              [PM2][WARN] Application MagicMirror not running, starting...
                              [PM2] App [MagicMirror] launched (1 instances)
                              App name | id | version | node | pid | status | restart | uptime | cpu | mem | user | watching
                              MagicMirror | 0 | 2.8.0 | fork | 4835 | online | 0 | 3s | 0% | 2.5 MB | pi | enabled
                              use 'pm2 show <id|name>' to get more details about an app
                              I used pm2 show mm and got [PM2][WARN] mm doesn’t exist
                              cheers, bdream
                                sdetweil @bdream
                                @bdream said in YAPi0 Installer Stretch Lite:
                                pm2 show mm
                                correct,
                                its called MagicMirror
                                says its running…
                                show me pm2 logs
                                you can also use the id, instead of the name
                                pm2 start 0,
                                pm2 stop 0,
                                pm2 show 0…
                                etc
                                  bdream
                                  here you are
                                  last 3 rows coming multiple times
                                  cheers, bdream
                                    sdetweil @bdream
                                    @bdream ok, there are two logs… error and out…
                                    maybe best to do
                                    cd ~/MagicMirror
                                    pm2 stop 0
                                    npm start
                                      bdream
                                      pi@RasPiZeroW:~ $ cd ~/MagicMirror/
                                      pi@RasPiZeroW:~/MagicMirror $ pm2 stop 0
                                      [PM2] Applying action stopProcessId on app [0](ids: 0)
                                      [PM2] [MagicMirror](0) ✓
                                      │ App name    │ id │ version │ mode │ pid │ status  │ restart │ uptime │ cpu │ mem    │ user │ watching │
                                      │ MagicMirror │ 0  │ 2.8.0   │ fork │ 0   │ stopped │ 31      │ 0      │ 0%  │ 0 B    │ pi   │ disabled │
                                       Use `pm2 show <id|name>` to get more details about an app
                                      pi@RasPiZeroW:~/MagicMirror $ npm start
                                      > magicmirror@2.8.0 start /home/pi/MagicMirror
                                      > sh run-start.sh
                                      /home/pi/MagicMirror/node_modules/electron/dist/electron: error while loading shared libraries: libgtk-3.so.0: cannot open shared object file: No such file or directory
                                      npm ERR! code ELIFECYCLE
                                      npm ERR! syscall spawn
                                      npm ERR! file sh
                                      npm ERR! errno ENOENT
                                      npm ERR! magicmirror@2.8.0 start: `sh run-start.sh`
                                      npm ERR! spawn ENOENT
                                      npm ERR!
                                      npm ERR! Failed at the magicmirror@2.8.0 start script.
                                      npm ERR!     /home/pi/.npm/_logs/2019-09-25T17_26_03_649Z-debug.log
                                      cheers, bdream
                                        sdetweil @bdream
                                        @bdream
                                        you MUST install the graphical UI desktop on the pi, right? MM uses graphics to display the screen.
                                          bdream
                                          hmm, I guess I have to investigate about this in a few weeks.
                                          So far many thanks for your help here. Will have a look later today and see what can I handle. Otherwise later. I have to run for a meeting now.
                                          cheers, bdream
                                            bdream
                                            @sdetweil said in YAPi0 Installer Stretch Lite:
                                            I wonder. I understood Pi0 don’t need to have UI installed. therefor I installed the light raspbian image - maybe I’m wrong :confounded_face:
                                            Do I have to install lightdm or other?
                                            And then I assume use raspi-config to boot to desktop?
                                            cheers, bdream
                                            • 6
                                            • 3 / 6
