    Can't get MM to start, says it can't find electron, then electron won't start
    49 Posts 5 Posters 36.7k Views 4 Watching
      sdetweil @jmartin1009
      @jmartin1009 ok, from the /home/pi folder lets start again
      cd ~
      rm -rf whatever_the_old_folder_name_is
      rm -rf MagicMirror
      git clone https://github.com/MichMich/MagicMirror.git
      cd MagicMirror
      npm install
        jmartin1009 @sdetweil
        @sdetweil okay I did all of that and it said it cloned and everthing, and then it rebooted during the install, now what? lol
          @jmartin1009 should not reboot
            @sdetweil oh it reboots everytime I install magicmirror, how do I prevent this? because it always reboots like 1/3 of the way through the progress bar and it always did it so I thought it was normal lol can I stop this? I have a pi 3+ btw
              jmartin1009 @jmartin1009
              @jmartin1009 it also does that everytime I try to install electron so maybe that’s why it isn’t working :confused: is there any fix for this?
                sdetweil
                Sorry, I do not know. Mine never reboots.
                How big is your memory card?
                J 2 Replies Last reply Reply Quote 0
                  @sdetweil 32 gb
                    @sdetweil I believe u figured out why it was restarting, a common cause of it is lack of power, and some person had problems with their keyboard drawing too much power so I unplugged it and it went all the way through without rebooting, but I still got some issues, im left with
                    Installing dependencies ...
                    npm WARN deprecated nomnom@1.8.1: Package no longer supported. Contact support@npmjs.com for more info.
                    npm WARN tarball cached data for async@~1.5.2 (sha1-7GphrlZIDAw8skHJVhjiCJL5Zyo=) seems to be corrupted. Refreshing cache.
                    npm WARN grunt-stylelint@0.10.1 requires a peer of stylelint@^9.0.0 but none is installed. You must install peer dependencies yourself.
                    npm WARN acorn-jsx@5.0.1 requires a peer of acorn@^6.0.0 but none is installed. You must install peer dependencies yourself.
                    npm ERR! path /home/pi/MagicMirror/node_modules/coffeescript/bin/coffee
                    npm ERR! code ENOENT
                    npm ERR! errno -2
                    npm ERR! syscall chmod
                    npm ERR! enoent ENOENT: no such file or directory, chmod '/home/pi/MagicMirror/node_modules/coffeescript/bin/coffee'
                    npm ERR! enoent This is related to npm not being able to find a file.
                    npm ERR! enoent
                    npm ERR!     /home/pi/.npm/_logs/2019-02-20T04_31_21_244Z-debug.log
                      @jmartin1009 I think u need to restart the install
                      Erase the node_modules folder, and do it again
                        @sdetweil I erased node_modules and reinstalled magicmirror and got this
                        Cloning MagicMirror Done!
                        npm WARN registry Unexpected warning for https://registry.npmjs.org/: Miscellaneous Warning ENODATA: Cache input stream was empty
                        npm WARN registry Using stale package data from https://registry.npmjs.org/ due to a request error during revalidation.
                        npm ERR! code EINTEGRITY
                        npm ERR! errno EINTEGRITY
                        npm ERR! Invalid response body while trying to fetch https://registry.npmjs.org/feedme: Integrity verification failed for sha512-neorTWnU+xIGoFGw5xKt8oa6Zrp4OIAdLKdTJkmTvESrU1kHYWBEQbxKaFtPAPPX7OiREkBnp0E0/gPN4QnmQg== (/home/pi/.npm/_cacache/content-v2/sha512/9d/ea/2b4d69d4fb1206a051b0e712adf286ba66ba7838801d2ca753264993bc44ab53590761604441bc4a685b4f00f3d7ece891124067a74134fe03cde109e642)
                        npm ERR!     /home/pi/.npm/_logs/2019-02-20T17_49_38_341Z-debug.log
                        What do I do now?
                          sdetweil
                          from the /hom/pi folder do
                          rm -rf .npm
                          cd MagicMirror
                          rm -rf node_modules
                          npm install
                            @sdetweil I am now given this, what do I do next?
                            MagicMirror installation successful!
                            > magicmirror@2.6.0 install-fonts /home/pi/MagicMirror
                            > cd fonts && npm install
                            added 1 package from 1 contributor and audited 1 package in 5.243s
                            found 0 vulnerabilities
                            added 930 packages from 1367 contributors and audited 2433 packages in 160.197s
                            found 23 vulnerabilities (8 low, 14 moderate, 1 high)
                              run `npm audit fix` to fix them, or `npm audit` for details
                              @jmartin1009 if your mirror is not accessible from the internet I would not worry about these vulnerabilities.
                                @sdetweil does that mean I can’t use any modules that use the internet? im using ssh to do these codes and I plan to use alexa and stuff with it so it will require internet use, so what did you mean by that?
                                  @jmartin1009 good point. I would run npm audit to get a list of the issues. These generally end up being challenging to solve completely.
                                    @sdetweil I ran the audit and then I ran the audit fix and I got this:
                                    found 23 vulnerabilities (8 low, 14 moderate, 1 high) in 2433 scanned packages
                                      run `npm audit fix` to fix 13 of them.
                                      8 vulnerabilities require semver-major dependency updates.
                                      2 vulnerabilities require manual review. See the full report for details.
                                    pi@raspberrypi:~/MagicMirror $ npm audit fix
                                    -bash: pm: command not found
                                    + jshint@2.10.1
                                    added 4 packages from 4 contributors, removed 7 packages and updated 13 packages in 39.446s
                                    fixed 13 of 23 vulnerabilities in 2433 scanned packages
                                      2 vulnerabilities required manual review and could not be updated
                                      1 package update for 8 vulns involved breaking changes
                                      (use `npm audit fix --force` to install breaking changes; or refer to `npm audit` for steps to fix these manually)
                                       │       New minor version of npm available! 6.4.1 → 6.8.0       │
                                       │   Changelog: https://github.com/npm/cli/releases/tag/v6.8.0   │
                                       │               Run npm install -g npm to update!               │
                                    what should I do now?
                                      sdetweil
                                      @jmartin1009 I would see what that 1 high priority issue is.
                                      At the bottom it says some breaking changes required to fix one issue. Breaking changes mean other code needs to be changed. So I would stay away from that fix
                                        @sdetweil I ran the audit again and I believe the fix I did fixed it, but it says I still have 11 vulnerabilities, which are:
                                                               === npm audit security report ===
                                        # Run  npm install --save-dev stylelint@9.10.1  to resolve 8 vulnerabilities
                                        SEMVER WARNING: Recommended action is a potentially breaking change
                                        │ Low           │ Regular Expression Denial of Service                         │
                                        │ Package       │ braces                                                       │
                                        │ Dependency of │ stylelint [dev]                                              │
                                        │ Path          │ stylelint > micromatch > braces                              │
                                        │ More info     │ https://nodesecurity.io/advisories/786                       │
                                        │ Moderate      │ Prototype Pollution                                          │
                                        │ Package       │ lodash                                                       │
                                        │ Path          │ stylelint > lodash                                           │
                                        │ More info     │ https://nodesecurity.io/advisories/782                       │
                                        │ Path          │ stylelint > postcss-reporter > lodash                        │
                                        │ Path          │ stylelint > table > lodash                                   │
                                        │ Low           │ Prototype Pollution                                          │
                                        │ More info     │ https://nodesecurity.io/advisories/577                       │
                                        │ Low           │ Cryptographically Weak PRNG                                  │
                                        │ Package       │ randomatic                                                   │
                                        │ Path          │ stylelint > micromatch > braces > expand-range > fill-range  │
                                        │               │ > randomatic                                                 │
                                        │ More info     │ https://nodesecurity.io/advisories/157                       │
                                        # Run  npm update lodash --depth 5  to resolve 1 vulnerability
                                        │ Dependency of │ spectron [dev]                                               │
                                        │ Path          │ spectron > webdriverio > gaze > globule > lodash             │
                                        │                                Manual Review                                 │
                                        │            Some vulnerabilities require your attention to resolve            │
                                        │         Visit https://go.npm.me/audit-guide for additional guidance          │
                                        │ Patched in    │ >=4.17.11                                                    │
                                        │ Dependency of │ express-ipfilter                                             │
                                        │ Path          │ express-ipfilter > lodash                                    │
                                        │ Patched in    │ >=4.17.5                                                     │
                                        found 11 vulnerabilities (6 low, 5 moderate) in 2427 scanned packages
                                          run `npm audit fix` to fix 1 of them.
                                        sorry for it being long, just easiest to copy and paste over from the ssh lol
                                          sdetweil
                                          As they are low or moderate risk, I would not worry about them.
                                            @sdetweil okay, so now should I try to run MagicMirror or is there anything else I have to do yet?
                                            • 2 / 3
