    Temperature probe for living room
    5 Posts 2 Posters 4.3k Views 2 Watching
    • F Offline
      fragator
      Hello all, and bravo for your work.
      I am French, and I discuss with you via a translator, so sorry you do not understand everything.
      I will find a way to have the temperature of the living room or it finds my magicmirror, via a sensor plug on the raspberry, and therefore have a module for ca.
      Do you think this is possible ??
      I am a novice, and I am unfortunately not able to do it myself.
      • Y Offline
        yawns Moderator
        Sure. Is your magicmirror in the living room as well? Then you could simply add a small temperature sensor like DS18B20 or a temperature/humidity sensor like DHT11 & DHT22 to your mirror frame, use 3 wires (5v, ground, data) to GPIO ports or your raspberry and add a small module to display the data
        • F Offline
          fragator
          Yes, that’s exactly it. I do not have the skills to create the module.
          one of you will get the temp and the patience to do it, it’ll be very nice.
          For the connection, I will find a tutorial that will explain how to do.
          • Y Offline
            yawns Moderator
            This was already completed …
            DHT11/DHT22 sensors:
            https://forum.magicmirror.builders/topic/726/mmm-temperature-humidity-module-dht11-dht22-and-am2302-sensors by @psk
            https://forum.magicmirror.builders/topic/738/mmm-dht22-humidity-and-temperature-module by @Bangee
            DS18B20 sensor:
            https://forum.magicmirror.builders/topic/887/mmm-temp-ds18b20 by @Thlb0
            Choose one :)
            • F Offline
              fragator
              Super, thank you, I had not seen these modules.
              Difficult to understand everything with the translator,
              In all that, thanks again for your work and explanation, all this really helps me a lot.
              1 Reply Last reply Reply Quote 4
