    HC-SR04 to play radio with MMM-RadioDe
    5 Posts 4 Posters 2.1k Views 4 Watching
    • E Offline
      efrag
      Hello, I’m trying to make the MMM-RadioDe module to start playing only if a SR04 ultrasonic sensor measure an object’s distance (hand) for example, less than 20 cm, and if the user after some time put an object (or hand) at the same distance again the radio should stop. Any ideas how to do it?
      Thank you all
      PS. I can’t figure out how to make this happen :
      This module will use the sendNotification(notification, payload) to send:
      notification = 'MOVEMENT'
      payload = 'Swipe Left' or 'Swipe Right'
      Please use as appropriate in your module using notificationReceived(notification, payload, sender)
        stuartiannaylor
        MMM-Pages I guess just change the page for on / off
        • wishmaster270W Online
          wishmaster270 Module Developer
          i wanted to suggest to use the https://github.com/Trekky12/MMM-ModuleToggle module in combination with in example my https://github.com/Tom-Hirschberger/MMM-Serial-Notifications module.
          The problem is that the MMM-RadioDe does not work. There are open issues as from 2017.
          I tried to do a quick fix but can’t get it run at the moment.
          • E Offline
            efrag @wishmaster270
            @wishmaster270 Thank you, I’ll try that now.
            • StoffbeuteluweS Offline
              Stoffbeuteluwe Project Sponsor
              MMM-RadioDe works well for me…
