    Calendar module - var location
    3 Posts 2 Posters 2.9k Views 2 Watching
    • T
      tidus5
      Hello
      is it possible to found a VAR with the location in the default calendar module of magic mirror?
      I want to use it with the module of localtransport to generate a dynamical search
      • strawberry 3.141S
        strawberry 3.141 Project Sponsor Module Developer @tidus5
        @tidus5 the calendar events get broadcasted by the calendar module, you can listen to this module and check for destinations like this module https://github.com/RedNax67/MMM-TrafficCal
        EDIT: this feature is currently only in the develop branch of MagicMirror available
        • T
          tidus5 @strawberry 3.141
          @strawberry-3.141 thanks :-) yes was a bit lost in the code to found the broadcast
