    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 42.0k Views 9 Watching
      jmartin1009
      I have MMM-Assistantmk2 and MMM-Hotword installed and the little logo comes up on screen on MM but none of the hotwords activate it for some reason :/ can anyone help me? Not sure what’s wrong
        jmartin1009
        @Sean possible for you to help me? I believe this is your module so you would know best haha
          jmartin1009
          It works when I get my mouse in the right spot and I click the icon, can talk to it and it talks back, just doesn’t pick up the hotwords :/
            jmartin1009
            @sdetweil do you have any knowledge of these modules? You’ve been a great help in my other problems
              sdetweil @jmartin1009
              @jmartin1009 i have not used those modules…
                @jmartin1009 if you start MM in developer mode,
                npm start dev
                and then select the console tab of the dev window
                do you see the notifications being sent?
                and u are not using MMM-Voice at the same time, right? only one module can have the mic at a time
                • ejay-ibmE Offline
                  ejay-ibm Project Sponsor Module Developer
                  seems to be an audio config issue .
                  Please paste your config.js file here
                  and the outputs of the following commands :
                  aplay -l
                  arecord -l
                  Ejay
                    jmartin1009 @sdetweil
                    @sdetweil I’m not using MMM-Voice, I’m using MMM-Assistantmk2 and MMM-Hotword, hotword pics up the word to wake the assistant and assistant takes care of the rest. I’ve been able to talk to the assistant but hotword doesn’t wake when I say the wakeword.
                      jmartin1009 @ejay-ibm
                      @ejay-ibm here is my magicmirror config file:
                      var config = {
                      	port: 8080,
                      	language: "en",
                      	timeFormat: 12,
                      	units: "imperial",
                      			module: "updatenotification",
                      			position: "top_bar"
                      		    module: "MMM-AssistantMk2",
                      		    position: "top_bar",
                      		      record: {
                      		        recordProgram : "arecord",
                      		        device        : "plughw:1, 0",
                      		      notifications: {
                      		        ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                      		        ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                      		    module: "MMM-Hotword",
                      		      record: {
                      		      autostart:true,
                      		      onDetected: {
                      		        notification: function (payload) {
                      		          return "ASSISTANT_ACTIVATE"
                      		        payload: function (payload){
                      		          return {
                      		            profile: payload.hotword
                      			module: "clock",
                      			position: "top_left"
                      			header: "US Holidays",
                      						symbol: "calendar-check",
                      						url: "webcal://www.calendarlabs.com/templates/ical/US-Holidays.ics"
                      			module: "compliments",
                      			position: "lower_third"
                      			module: "currentweather",
                      				locationID: "4854529",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                      				appid: "6730254e02c0f50e5d951db321f6fa33"
                      			module: "weatherforecast",
                      			header: "Weather Forecast",
                      				locationID: "4854529",  //ID from https://openweathermap.org/city
                          			module: "MMM-EARTH",
                          			position: "bottom_right",
                              			mode: "Natural",
                              			rotateInterval: 15000,
                              			MaxWidth: "30%",
                              			MaxHeight: "30%",
                      			module: "newsfeed",
                      			position: "bottom_bar",
                      				feeds: [
                      						title: "New York Times",
                      				showSourceTitle: true,
                      				showPublishDate: true
                          			module: 'MMM-ShairportMetadata',
                          			position: 'bottom_left',
                            			    metadataPipe: "/tmp/shairport-sync-metadata", // location of pipe with shairport-sync metadata
                      	  			alignment: "center",	// Possible values [left|right|center]. Default: center
                      here is the output for aplay -l:
                      pi@raspberrypi:~ $ aplay -l
                      **** List of PLAYBACK Hardware Devices ****
                      card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                        Subdevices: 7/7
                        Subdevice #0: subdevice #0
                        Subdevice #1: subdevice #1
                        Subdevice #2: subdevice #2
                        Subdevice #3: subdevice #3
                        Subdevice #4: subdevice #4
                        Subdevice #5: subdevice #5
                        Subdevice #6: subdevice #6
                      card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                        Subdevices: 1/1
                      I do use PulseAudio because i use the PS3 eye mic, which uses a mic array that alsamixer doesn’t like, but it works when i talk to the assistant, Hotword just doesn’t hear my wakewords.
                      Here is the output for arecord -l
                      pi@raspberrypi:~ $ arecord -l
                      **** List of CAPTURE Hardware Devices ****
                      card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio]
                        Subdevices: 1/1
                      It seems to work whether i use “plughw: 0” and “plughw: 0, 1”.
                        @jmartin1009 I would remove the space in the device name
                        "plughw: 0,1"
                          sdetweil
                          I just installed MMM-Hotword, and used this config
                                      autostart:true,
                                      autorestart: true
                          and it works fine…
                          i did have a little snowboy rebuild work to do but documented in the hotword install doc…
                          J 3 Replies Last reply Reply Quote 0
                            @sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
                              @sdetweil is that your config for magicmirror or in the config file or hotword?
                                @sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
                                  @jmartin1009 just the config for hotword.
                                  • ejay-ibmE Offline
                                    Hello,
                                    I agree with Sam :
                                    You need to remove the space at both places.
                                    1st in MMM-AssistantMk2
                                    		      record: {
                                    		        device        : "plughw:1,0",
                                    And as well in
                                    		      record: {
                                    If that still doesn’t work try just :
                                    plughw:1
                                    As well you should check in the audio properties that your mic have enough gain.
                                    you can check this by typing
                                    alsamixer
                                    in command line
                                    hope this helps
                                    Ejay
                                    J 2 Replies Last reply Reply Quote 0
                                      @ejay-ibm @sdetweil what should I have in the module list in the config.js for the magicmirror program for each module? Not sure if I have the right stuff or too much or what
                                        @ejay-ibm also is there anyway to change the gain or whatever? I went to alsamixer and went to the capture section and the bar doesn’t move or anything when I speak into my mic. Not sure if anything is supposed to happen but it says both L and R capture are the 100, not sure what that means.
                                          jmartin1009
                                          @ejay-ibm I also changed it so the sauce wasn’t there and I made it so it said plughw:1 in all of them, but still nothing
                                          • ejay-ibmE Offline
                                            This is my MMM-Hotword config.js part :
                                                    snowboy: [
                                            						"hotwords": "smartmirror",
                                            						"file": "resources/models/smart_mirror.umdl",
                                            						"sensitivity": "0.5"
                                                        hotwords: "alexa",
                                                        file: "resources/models/alexa.umdl",
                                                        sensitivity: "0.6"
                                                        file: "resources/models/jarvis.umdl",
                                                        sensitivity: "0.6,0.60",
                                                        hotwords: ["jarvis", "jarvis"]
                                                    record: {
                                                      sampleRate: 16000,
                                                      threshold: 0.5,
                                                      thresholdStart: null,
                                                      thresholdEnd: null,
                                                      silence: 1,
                                                      verbose: false,
                                                      recordProgram: "arecord",
                                                      device: "plughw:1"
                                                    autostart: true,
                                                    autorestart: true,
                                                    notifications: {
                                                      PAUSE: "HOTWORD_PAUSE",
                                                      RESUME: "HOTWORD_RESUME",
                                                      LISTENING: "HOTWORD_LISTENING",
                                                      SLEEPING: "HOTWORD_SLEEPING",
                                                      ERROR: "HOTWORD_ERROR"
                                                    onDetected: {
                                                      notification: function(payload) {
                                                        return "ASSISTANT_ACTIVATE";
                                                      payload: function(payload) {
                                                        return {
                                            You can give it a try .
                                            Ejay
                                            • 1 / 3
