    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 37.1k Views 9 Watching
      jmartin1009
      @sdetweil do you have any knowledge of these modules? You’ve been a great help in my other problems
        sdetweil @jmartin1009
        @jmartin1009 i have not used those modules…
          @jmartin1009 if you start MM in developer mode,
          npm start dev
          and then select the console tab of the dev window
          do you see the notifications being sent?
          and u are not using MMM-Voice at the same time, right? only one module can have the mic at a time
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer
            seems to be an audio config issue .
            Please paste your config.js file here
            and the outputs of the following commands :
            aplay -l
            arecord -l
            Ejay
              jmartin1009 @sdetweil
              @sdetweil I’m not using MMM-Voice, I’m using MMM-Assistantmk2 and MMM-Hotword, hotword pics up the word to wake the assistant and assistant takes care of the rest. I’ve been able to talk to the assistant but hotword doesn’t wake when I say the wakeword.
                jmartin1009 @ejay-ibm
                @ejay-ibm here is my magicmirror config file:
                var config = {
                	port: 8080,
                	language: "en",
                	timeFormat: 12,
                	units: "imperial",
                			module: "updatenotification",
                			position: "top_bar"
                		    module: "MMM-AssistantMk2",
                		    position: "top_bar",
                		      record: {
                		        recordProgram : "arecord",
                		        device        : "plughw:1, 0",
                		      notifications: {
                		        ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                		        ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                		    module: "MMM-Hotword",
                		      record: {
                		      autostart:true,
                		      onDetected: {
                		        notification: function (payload) {
                		          return "ASSISTANT_ACTIVATE"
                		        payload: function (payload){
                		          return {
                		            profile: payload.hotword
                			module: "clock",
                			position: "top_left"
                			header: "US Holidays",
                						symbol: "calendar-check",
                			module: "compliments",
                			position: "lower_third"
                			module: "currentweather",
                				locationID: "4854529",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                				appid: "6730254e02c0f50e5d951db321f6fa33"
                			module: "weatherforecast",
                			header: "Weather Forecast",
                				locationID: "4854529",  //ID from https://openweathermap.org/city
                    			module: "MMM-EARTH",
                    			position: "bottom_right",
                        			mode: "Natural",
                        			rotateInterval: 15000,
                        			MaxWidth: "30%",
                        			MaxHeight: "30%",
                			module: "newsfeed",
                			position: "bottom_bar",
                				feeds: [
                						title: "New York Times",
                				showSourceTitle: true,
                				showPublishDate: true
                    			module: 'MMM-ShairportMetadata',
                    			position: 'bottom_left',
                      			    metadataPipe: "/tmp/shairport-sync-metadata", // location of pipe with shairport-sync metadata
                	  			alignment: "center",	// Possible values [left|right|center]. Default: center
                here is the output for aplay -l:
                pi@raspberrypi:~ $ aplay -l
                **** List of PLAYBACK Hardware Devices ****
                card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                  Subdevices: 7/7
                  Subdevice #0: subdevice #0
                  Subdevice #1: subdevice #1
                  Subdevice #2: subdevice #2
                  Subdevice #3: subdevice #3
                  Subdevice #4: subdevice #4
                  Subdevice #5: subdevice #5
                  Subdevice #6: subdevice #6
                card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                  Subdevices: 1/1
                I do use PulseAudio because i use the PS3 eye mic, which uses a mic array that alsamixer doesn’t like, but it works when i talk to the assistant, Hotword just doesn’t hear my wakewords.
                Here is the output for arecord -l
                pi@raspberrypi:~ $ arecord -l
                **** List of CAPTURE Hardware Devices ****
                card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio]
                  Subdevices: 1/1
                It seems to work whether i use “plughw: 0” and “plughw: 0, 1”.
                  @jmartin1009 I would remove the space in the device name
                  "plughw: 0,1"
                    I just installed MMM-Hotword, and used this config
                                autostart:true,
                                autorestart: true
                    and it works fine…
                    i did have a little snowboy rebuild work to do but documented in the hotword install doc…
                    J 3 Replies Last reply Reply Quote 0
                      @sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
                        @sdetweil is that your config for magicmirror or in the config file or hotword?
                        • 1 / 6
