    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 41.3k Views 9 Watching
      I just installed MMM-Hotword, and used this config
                module: "MMM-Hotword",
                  autostart:true,
                  autorestart: true
      and it works fine…
      i did have a little snowboy rebuild work to do but documented in the hotword install doc…
      J 3 Replies Last reply Reply Quote 0
        jmartin1009 @sdetweil
        @sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
          @sdetweil is that your config for magicmirror or in the config file or hotword?
            @sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
              sdetweil @jmartin1009
              @jmartin1009 just the config for hotword.
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer
                I agree with Sam :
                You need to remove the space at both places.
                1st in MMM-AssistantMk2
                module: "MMM-AssistantMk2",
                		    position: "top_bar",
                		      record: {
                		        recordProgram : "arecord",
                		        device        : "plughw:1,0",
                And as well in
                		      record: {
                If that still doesn’t work try just :
                plughw:1
                As well you should check in the audio properties that your mic have enough gain.
                you can check this by typing
                alsamixer
                in command line
                hope this helps
                Ejay
                  jmartin1009 @ejay-ibm
                  @ejay-ibm @sdetweil what should I have in the module list in the config.js for the magicmirror program for each module? Not sure if I have the right stuff or too much or what
                    @ejay-ibm also is there anyway to change the gain or whatever? I went to alsamixer and went to the capture section and the bar doesn’t move or anything when I speak into my mic. Not sure if anything is supposed to happen but it says both L and R capture are the 100, not sure what that means.
                      jmartin1009
                      @ejay-ibm I also changed it so the sauce wasn’t there and I made it so it said plughw:1 in all of them, but still nothing
                      • ejay-ibmE Offline
                        This is my MMM-Hotword config.js part :
                                snowboy: [
                        						"hotwords": "smartmirror",
                        						"file": "resources/models/smart_mirror.umdl",
                        						"sensitivity": "0.5"
                                    hotwords: "alexa",
                                    file: "resources/models/alexa.umdl",
                                    sensitivity: "0.6"
                                    file: "resources/models/jarvis.umdl",
                                    sensitivity: "0.6,0.60",
                                    hotwords: ["jarvis", "jarvis"]
                                record: {
                                  sampleRate: 16000,
                                  threshold: 0.5,
                                  thresholdStart: null,
                                  thresholdEnd: null,
                                  silence: 1,
                                  verbose: false,
                                  recordProgram: "arecord",
                                  device: "plughw:1"
                                autostart: true,
                                autorestart: true,
                                notifications: {
                                  PAUSE: "HOTWORD_PAUSE",
                                  RESUME: "HOTWORD_RESUME",
                                  LISTENING: "HOTWORD_LISTENING",
                                  SLEEPING: "HOTWORD_SLEEPING",
                                  ERROR: "HOTWORD_ERROR"
                                onDetected: {
                                  notification: function(payload) {
                                    return "ASSISTANT_ACTIVATE";
                                  payload: function(payload) {
                                    return {
                                      profile: payload.hotword
                        You can give it a try .
                        Ejay
                          @jmartin1009 but, that explains no response from the modules!
                            @ejay-ibm that is for the MM config.js right? Or is that what you have in the MMM-Hotword.js config file?
                              @sdetweil What explains no response from the modules? My mic’s gain in alsamixer? if so how can i fix that? Or should i just get a new mic
                                @jmartin1009 i would get a new mic… clearly this one is having issues… is that the array?
                                  @sdetweil yeah it’s the PS3 eye camera microphone, it has a 4 microphone array that alsamixer hates lol
                                    costascontis
                                    I use the ps3 eye cam mic and its working fine with hotword…
                                    • ejay-ibmE Offline
                                      install audacity and give a quick test to your mic.
                                      you will know if you mic is dead
                                      sudo apt-get install audacity
                                        sdetweil @costascontis
                                        @costascontis said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                                        yes, but there are lots of reports of individual mics not working… replace and all is ok…
                                          bachoo786 @ejay-ibm
                                          Hi @ejay-ibm
                                          I managed to get assistantmk2 and hotword working and everything is fine. However I will be grateful if you could please help me with the following queries:
                                          1). When i say jarvis or smart mirror, the assistantmk2 module takes 1 to 2 seconds to respond i.e. the ding bell I mean after which I can ask any question. How can I remove this lag and make it instant? I have seen other people dont have this issue.
                                          2). How do I get the assistantmk2 to play youtube videos on my mirror by asking it to play something from youtube?
                                          3). Finally can I change the hotword from “jarvis” to say “ok google”?
                                          Thanks.
                                          This is my config:
                                                deviceLocation: {
        coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
        latitude: 51.597442, // -90.0 - +90.0
        longitude: -0.338839, // -180.0 - +180.0
                                                record: {
                                                  device        : "default",
                                                play: { // Full values are in `FOR EXPERTS` section.
                                                        playProgram: "mpg321", // recommended.
                                                notifications: {
                                                  ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                                  ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                                record: {
                                                  device        : "default",
                                                autostart:true,
                                                onDetected: {
                                                  notification: function (payload) {
                                                  payload: function (payload){
                                                    return {
                                          Also you have notifications in your config, what is it for? can you please explain? thanks.
                                          • ejay-ibmE Offline
                                            1- I would say first to check you CPU charge first , the delay might be due to the load.
                                            2- just say " Jarvis" … " Micheal jackson smooth criminal" it will play the youtube video clip
                                            3- if you want to say " ok google" you have to add your own umdl or umdp file.
                                            Info and new umd* file can be found and created here :
                                            https://snowboy.kitt.ai/
                                            hope this help .
                                            Ejay
