    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 43.6k Views 9 Watching
      jmartin1009 @sdetweil
      @sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
        sdetweil @jmartin1009
        @jmartin1009 just the config for hotword.
        • ejay-ibmE
          ejay-ibm Project Sponsor Module Developer
          I agree with Sam :
          You need to remove the space at both places.
          1st in MMM-AssistantMk2
          module: "MMM-AssistantMk2",
          		    position: "top_bar",
          		      record: {
          		        recordProgram : "arecord",
          		        device        : "plughw:1,0",
          And as well in
          module: "MMM-Hotword",
          		      record: {
          If that still doesn’t work try just :
          plughw:1
          As well you should check in the audio properties that your mic have enough gain.
          you can check this by typing
          alsamixer
          in command line
          hope this helps
          Ejay
          J 2 Replies Last reply
            jmartin1009 @ejay-ibm
            @ejay-ibm @sdetweil what should I have in the module list in the config.js for the magicmirror program for each module? Not sure if I have the right stuff or too much or what
              @ejay-ibm also is there anyway to change the gain or whatever? I went to alsamixer and went to the capture section and the bar doesn’t move or anything when I speak into my mic. Not sure if anything is supposed to happen but it says both L and R capture are the 100, not sure what that means.
                jmartin1009
                @ejay-ibm I also changed it so the sauce wasn’t there and I made it so it said plughw:1 in all of them, but still nothing
                • ejay-ibmE
                  This is my MMM-Hotword config.js part :
                          snowboy: [
                  						"hotwords": "smartmirror",
                  						"file": "resources/models/smart_mirror.umdl",
                  						"sensitivity": "0.5"
                              hotwords: "alexa",
                              file: "resources/models/alexa.umdl",
                              sensitivity: "0.6"
                              file: "resources/models/jarvis.umdl",
                              sensitivity: "0.6,0.60",
                              hotwords: ["jarvis", "jarvis"]
                          record: {
                            sampleRate: 16000,
                            threshold: 0.5,
                            thresholdStart: null,
                            thresholdEnd: null,
                            silence: 1,
                            verbose: false,
                            recordProgram: "arecord",
                            device: "plughw:1"
                          autostart: true,
                          autorestart: true,
                          notifications: {
                            PAUSE: "HOTWORD_PAUSE",
                            RESUME: "HOTWORD_RESUME",
                            LISTENING: "HOTWORD_LISTENING",
                            SLEEPING: "HOTWORD_SLEEPING",
                            ERROR: "HOTWORD_ERROR"
                          onDetected: {
                            notification: function(payload) {
                              return "ASSISTANT_ACTIVATE";
                            payload: function(payload) {
                              return {
                                profile: payload.hotword
                  You can give it a try .
                  Ejay
                  J 1 Reply Last reply
                    @jmartin1009 but, that explains no response from the modules!
                      @ejay-ibm that is for the MM config.js right? Or is that what you have in the MMM-Hotword.js config file?
                        @sdetweil What explains no response from the modules? My mic’s gain in alsamixer? if so how can i fix that? Or should i just get a new mic
                          @jmartin1009 i would get a new mic… clearly this one is having issues… is that the array?
                            @sdetweil yeah it’s the PS3 eye camera microphone, it has a 4 microphone array that alsamixer hates lol
                              costascontis
                              I use the ps3 eye cam mic and its working fine with hotword…
                              • ejay-ibmE
                                install audacity and give a quick test to your mic.
                                you will know if you mic is dead
                                sudo apt-get install audacity
                                B 1 Reply Last reply
                                  sdetweil @costascontis
                                  @costascontis said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                                  yes, but there are lots of reports of individual mics not working… replace and all is ok…
                                    bachoo786 @ejay-ibm
                                    Hi @ejay-ibm
                                    I managed to get assistantmk2 and hotword working and everything is fine. However I will be grateful if you could please help me with the following queries:
                                    1). When i say jarvis or smart mirror, the assistantmk2 module takes 1 to 2 seconds to respond i.e. the ding bell I mean after which I can ask any question. How can I remove this lag and make it instant? I have seen other people dont have this issue.
                                    2). How do I get the assistantmk2 to play youtube videos on my mirror by asking it to play something from youtube?
                                    3). Finally can I change the hotword from “jarvis” to say “ok google”?
                                    Thanks.
                                    This is my config:
                                          deviceLocation: {
                                                            coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                                                            latitude: 51.597442, // -90.0 - +90.0
                                                            longitude: -0.338839, // -180.0 - +180.0
                                          record: {
                                            device        : "default",
                                          play: { // Full values are in `FOR EXPERTS` section.
                                                  playProgram: "mpg321", // recommended.
                                          notifications: {
                                            ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                                            ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                                          record: {
                                            device        : "default",
                                          autostart:true,
                                          onDetected: {
                                            notification: function (payload) {
                                            payload: function (payload){
                                              return {
                                    Also you have notifications in your config, what is it for? can you please explain? thanks.
                                    • ejay-ibmE
                                      1- I would say first to check you CPU charge first , the delay might be due to the load.
                                      2- just say " Jarvis" … " Micheal jackson smooth criminal" it will play the youtube video clip
                                      3- if you want to say " ok google" you have to add your own umdl or umdp file.
                                      Info and new umd* file can be found and created here :
                                      https://snowboy.kitt.ai/
                                      hope this help .
                                      Ejay
                                        bachoo786 @ejay-ibm
                                        @ejay-ibm thanks for the quick reply.
                                        ejay-ibmE 1 Reply Last reply
                                        • ejay-ibmE
                                          ejay-ibm Project Sponsor Module Developer @bachoo786
                                          @bachoo786
                                          The notification allows to the hotword module to receive instruction from the assistant module by notification to pause or resume itself in the right time.
                                          When assistant 'talk it pause the hotword detection
                                          ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
                                          When the assistant is done it restart the hotword detection .
                                          ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
                                          Ejay
                                          • A
                                            AdnanAhmed97
                                            The hotword module should be called outside the assistant module
                                            Add the brackets correctly and change and change device to plughw : 1;
                                            • 2 / 3
