    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 43.0k Views 9 Watching
      sdetweil @jmartin1009
      @jmartin1009 but, that explains no response from the modules!
        jmartin1009 @ejay-ibm
        @ejay-ibm that is for the MM config.js right? Or is that what you have in the MMM-Hotword.js config file?
          jmartin1009 @sdetweil
          @sdetweil What explains no response from the modules? My mic’s gain in alsamixer? if so how can i fix that? Or should i just get a new mic
            @jmartin1009 i would get a new mic… clearly this one is having issues… is that the array?
              @sdetweil yeah it’s the PS3 eye camera microphone, it has a 4 microphone array that alsamixer hates lol
                costascontis
                I use the ps3 eye cam mic and its working fine with hotword…
                • ejay-ibmE
                  ejay-ibm Project Sponsor Module Developer
                  install audacity and give a quick test to your mic.
                  you will know if you mic is dead
                  sudo apt-get install audacity
                    sdetweil @costascontis
                    @costascontis said in MMM-Assistantmk2 and MMM-Hotword not picking up:
                    yes, but there are lots of reports of individual mics not working… replace and all is ok…
                      bachoo786 @ejay-ibm
                      Hi @ejay-ibm
                      I managed to get assistantmk2 and hotword working and everything is fine. However I will be grateful if you could please help me with the following queries:
                      1). When i say jarvis or smart mirror, the assistantmk2 module takes 1 to 2 seconds to respond i.e. the ding bell I mean after which I can ask any question. How can I remove this lag and make it instant? I have seen other people dont have this issue.
                      2). How do I get the assistantmk2 to play youtube videos on my mirror by asking it to play something from youtube?
                      3). Finally can I change the hotword from “jarvis” to say “ok google”?
                      Thanks.
                      This is my config:
                          module: "MMM-AssistantMk2",
                            deviceLocation: {
                                              coordinates: { // set the latitude and longitude of the device to get localized information like weather or time. (ref. mygeoposition.com)
                                              latitude: 51.597442, // -90.0 - +90.0
                                              longitude: -0.338839, // -180.0 - +180.0
                            record: {
                              recordProgram : "arecord",
                              device        : "default",
                            play: { // Full values are in `FOR EXPERTS` section.
                                    playProgram: "mpg321", // recommended.
                            notifications: {
                              ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                              ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                          module: "MMM-Hotword",
                            record: {
                              device        : "default",
                            autostart:true,
                            onDetected: {
                              notification: function (payload) {
                                return "ASSISTANT_ACTIVATE"
                              payload: function (payload){
                                return {
                                  profile: payload.hotword
                      Also you have notifications in your config, what is it for? can you please explain? thanks.
                      • ejay-ibmE
                        1- I would say first to check you CPU charge first , the delay might be due to the load.
                        2- just say " Jarvis" … " Micheal jackson smooth criminal" it will play the youtube video clip
                        3- if you want to say " ok google" you have to add your own umdl or umdp file.
                        Info and new umd* file can be found and created here :
                        https://snowboy.kitt.ai/
                        hope this help .
                        Ejay
                          bachoo786 @ejay-ibm
                          @ejay-ibm thanks for the quick reply.
                          ejay-ibmE 1 Reply Last reply Reply Quote 0
                          • ejay-ibmE
                            ejay-ibm Project Sponsor Module Developer @bachoo786
                            @bachoo786
                            The notification allows to the hotword module to receive instruction from the assistant module by notification to pause or resume itself in the right time.
                            When assistant 'talk it pause the hotword detection
                            ASSISTANT_ACTIVATED: “HOTWORD_PAUSE”,
                            When the assistant is done it restart the hotword detection .
                            ASSISTANT_DEACTIVATED: “HOTWORD_RESUME”,
                            Ejay
                            • A
                              AdnanAhmed97
                              The hotword module should be called outside the assistant module
                              Add the brackets correctly and change and change device to plughw : 1;
                                bachoo786 @AdnanAhmed97
                                @AdnanAhmed97 what do you mean?
                                  jmartin1009
                                  @sdetweil @ejay-ibm well i got a new mic and i tried it out, still no detection for MMM-Hotword. It works for GoogleAssistantMk2 when i click the button on the screen, but no hotword detection. I worried that it may be because of snowboy failing to install properly the first time for some reason, so i went into the module in the console and did npm install and got this:
                                  pi@raspberrypi:~/MagicMirror/modules/MMM-Hotword $ npm install
                                  npm WARN deprecated hoek@2.16.3: This version is no longer maintained. Please upgrade to the latest version.
                                  npm WARN deprecated boom@2.10.1: This version is no longer maintained. Please upgrade to the latest version.
                                  npm WARN deprecated cryptiles@2.0.5: This version is no longer maintained. Please upgrade to the latest version.
                                  npm ERR! path /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy
                                  npm ERR! code EISGIT
                                  npm ERR! git /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy: Appears to be a git repo or submodule.
                                  npm ERR! git Refusing to remove it. Update manually,
                                  npm ERR! git or move it out of the way first.
                                  npm ERR!     /home/pi/.npm/_logs/2019-03-18T22_16_00_319Z-debug.log
                                  any idea how i can fix this?
                                  J ? 2 Replies Last reply Reply Quote 0
                                    jmartin1009 @jmartin1009
                                    @jmartin1009 this is possible it’s saying this because it’s already there, but i wasn’t sure i figured i’d give it another go. Let me know if there’s anything i should change or try, but i know this mic does work, as it shows up in
                                    arecord -l
                                    and it comes up and i can select it in alsamixer and everything, just can’t get hotword to hear me.
                                      A Former User @jmartin1009
                                      @jmartin1009
                                      rm -rf /home/pi/MagicMirror/modules/MMM-Hotword/node_modules/snowboy/.git
                                      Then try again
                                        raedonlpa
                                        Hi, why?
                                        When I change the activation word, it doesn’t work for me?,
                                        I want to change it to another word, like alexa, jarvis, etc, and it doesn’t work for me.
                                        I have copied the parameters of @ejay-ibm and nothing.
                                        language: "es",
                                        timeFormat: 24,
                                        units: "metric",
                                        		module: "alert",
                                        		module: "updatenotification",
                                        		position: "top_bar"
                                        		module: "clock",
                                        		position: "top_left"
                                        		header: "Calendario",
                                        					symbol: "calendar-check",
                                        					url: "https://www.calendarlabs.com/ical-calendar/ics/70/Spain_Holidays.ics"
                                        					symbol: "MyCalendar",
                                        					url: "https://calendar.google.com/calendar/ical/............/public/basic.ics"
                                        		module: "compliments",
                                        		position: "lower_third"
                                        		module: "currentweather",
                                        			locationID: "",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                        		module: "weatherforecast",
                                        		header: "Weather Forecast",
                                        			locationID: "2521570",  //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                        			appid: "..........................."
                                            		module: 'currentweather',
                                            		position: 'top_right',
                                        		        locationID: '2521570', //ID from bulk.openweather.org/sample/
                                        		        appid:" .............................'',
                                        		        updateInterval: '3600000',
                                        		        onlyTemp: true
                                        		module: "newsfeed",
                                        		position: "bottom_bar",
                                        			feeds: [
                                        					title: "Canarias7",
                                        					url: "https://www.canarias7.es/rss/portada.xml"
                                        			showSourceTitle: true,
                                        			showPublishDate: true,
                                        			broadcastNewsFeeds: true,
                                        			broadcastNewsUpdates: true
                                        			chimeOnFinish: null,
                                        			mic: {
                                        				recordProgram: "arecord",
                                        				device: "plughw:1"
                                        			models: [
                                        					hotwords    : "Smart_mirror",
                                        					file        : "smart_mirror.umdl",
                                        					sensitivity : "0.5",
                                        			commands: {
                                        				"smart_mirror": {
                                        					notificationExec: {
                                        						notification: "ASSISTANT_ACTIVATE",
                                        						payload: (detected, afterRecord) => {
                                        							return {profile:"default"}
                                        					restart:false,
                                        					afterRecordLimit:0
                                        			deviceLocation: {
                                        				coordinates: {
                                        					latitude: 28.969593, // -90.0 - +90.0
                                        					longitude: -13.556344, // -180.0 - +180.0
                                        			record: {
                                        				device        : "plughw:1",
                                        			notifications: {
                                        			useWelcomeMessage: "brief today",
                                        			profiles: {
                                        				"default" : {
                                        					lang: "es-ES"
                                          sdetweil @raedonlpa
                                          @raedonlpa can u edit your post, and put three back-tics (shifted, left of 1) before the 1st line, and after the last line.
                                          1 Reply Last reply Reply Quote -1
                                            raedonlpa
                                            @sdetweil Better this way, I’m sorry I use google traslator
                                            • 2 / 3
