    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 42.1k Views 9 Watching
      jmartin1009
      @Sean possible for you to help me? I believe this is your module so you would know best haha
        jmartin1009
        It works when I get my mouse in the right spot and I click the icon, can talk to it and it talks back, just doesn’t pick up the hotwords :/
          jmartin1009
          @sdetweil do you have any knowledge of these modules? You’ve been a great help in my other problems
            sdetweil @jmartin1009
            @jmartin1009 i have not used those modules…
              @jmartin1009 if you start MM in developer mode,
              npm start dev
              and then select the console tab of the dev window
              do you see the notifications being sent?
              and u are not using MMM-Voice at the same time, right? only one module can have the mic at a time
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer
                seems to be an audio config issue .
                Please paste your config.js file here
                and the outputs of the following commands :
                aplay -l
                arecord -l
                Ejay
                  jmartin1009 @sdetweil
                  @sdetweil I’m not using MMM-Voice, I’m using MMM-Assistantmk2 and MMM-Hotword, hotword pics up the word to wake the assistant and assistant takes care of the rest. I’ve been able to talk to the assistant but hotword doesn’t wake when I say the wakeword.
                    jmartin1009 @ejay-ibm
                    @ejay-ibm here is my magicmirror config file:
                    var config = {
                    	port: 8080,
                    	language: "en",
                    	timeFormat: 12,
                    	units: "imperial",
                    			module: "updatenotification",
                    			position: "top_bar"
                    		    module: "MMM-AssistantMk2",
                    		    position: "top_bar",
                    		      record: {
                    		        recordProgram : "arecord",
                    		        device        : "plughw:1, 0",
                    		      notifications: {
                    		        ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
                    		        ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
                    		    module: "MMM-Hotword",
                    		      record: {
                    		      autostart:true,
                    		      onDetected: {
                    		        notification: function (payload) {
                    		          return "ASSISTANT_ACTIVATE"
                    		        payload: function (payload){
                    		          return {
                    		            profile: payload.hotword
                    			module: "clock",
                    			position: "top_left"
                    			header: "US Holidays",
                    						symbol: "calendar-check",
                    			module: "compliments",
                    			position: "lower_third"
                    			module: "currentweather",
                    				locationID: "4854529",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
                    				appid: "6730254e02c0f50e5d951db321f6fa33"
                    			module: "weatherforecast",
                    			header: "Weather Forecast",
                    				locationID: "4854529",  //ID from https://openweathermap.org/city
                        			module: "MMM-EARTH",
                        			position: "bottom_right",
                            			mode: "Natural",
                            			rotateInterval: 15000,
                            			MaxWidth: "30%",
                            			MaxHeight: "30%",
                    			module: "newsfeed",
                    			position: "bottom_bar",
                    				feeds: [
                    						title: "New York Times",
                    				showSourceTitle: true,
                    				showPublishDate: true
                        			module: 'MMM-ShairportMetadata',
                        			position: 'bottom_left',
                          			    metadataPipe: "/tmp/shairport-sync-metadata", // location of pipe with shairport-sync metadata
                    	  			alignment: "center",	// Possible values [left|right|center]. Default: center
                    here is the output for aplay -l:
                    pi@raspberrypi:~ $ aplay -l
                    **** List of PLAYBACK Hardware Devices ****
                    card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                      Subdevices: 7/7
                      Subdevice #0: subdevice #0
                      Subdevice #1: subdevice #1
                      Subdevice #2: subdevice #2
                      Subdevice #3: subdevice #3
                      Subdevice #4: subdevice #4
                      Subdevice #5: subdevice #5
                      Subdevice #6: subdevice #6
                    card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                      Subdevices: 1/1
                    I do use PulseAudio because i use the PS3 eye mic, which uses a mic array that alsamixer doesn’t like, but it works when i talk to the assistant, Hotword just doesn’t hear my wakewords.
                    Here is the output for arecord -l
                    pi@raspberrypi:~ $ arecord -l
                    **** List of CAPTURE Hardware Devices ****
                    card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio]
                      Subdevices: 1/1
                    It seems to work whether i use “plughw: 0” and “plughw: 0, 1”.
                      @jmartin1009 I would remove the space in the device name
                      "plughw: 0,1"
                        I just installed MMM-Hotword, and used this config
                                    autostart:true,
                                    autorestart: true
                        and it works fine…
                        i did have a little snowboy rebuild work to do but documented in the hotword install doc…
                        J 3 Replies Last reply Reply Quote 0
                          @sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
                            @sdetweil is that your config for magicmirror or in the config file or hotword?
                              @sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
                                @jmartin1009 just the config for hotword.
                                • ejay-ibmE Offline
                                  I agree with Sam :
                                  You need to remove the space at both places.
                                  1st in MMM-AssistantMk2
                                  		      record: {
                                  		        device        : "plughw:1,0",
                                  And as well in
                                  		      record: {
                                  If that still doesn’t work try just :
                                  plughw:1
                                  As well you should check in the audio properties that your mic have enough gain.
                                  you can check this by typing
                                  alsamixer
                                  in command line
                                  hope this helps
                                  Ejay
                                    @ejay-ibm @sdetweil what should I have in the module list in the config.js for the magicmirror program for each module? Not sure if I have the right stuff or too much or what
                                      @ejay-ibm also is there anyway to change the gain or whatever? I went to alsamixer and went to the capture section and the bar doesn’t move or anything when I speak into my mic. Not sure if anything is supposed to happen but it says both L and R capture are the 100, not sure what that means.
                                        jmartin1009
                                        @ejay-ibm I also changed it so the sauce wasn’t there and I made it so it said plughw:1 in all of them, but still nothing
                                        • ejay-ibmE Offline
                                          This is my MMM-Hotword config.js part :
                                                  snowboy: [
                                          						"hotwords": "smartmirror",
                                          						"file": "resources/models/smart_mirror.umdl",
                                          						"sensitivity": "0.5"
                                                      hotwords: "alexa",
                                                      file: "resources/models/alexa.umdl",
                                                      sensitivity: "0.6"
                                                      file: "resources/models/jarvis.umdl",
                                                      sensitivity: "0.6,0.60",
                                                      hotwords: ["jarvis", "jarvis"]
                                                  record: {
                                                    sampleRate: 16000,
                                                    threshold: 0.5,
                                                    thresholdStart: null,
                                                    thresholdEnd: null,
                                                    silence: 1,
                                                    verbose: false,
                                                    recordProgram: "arecord",
                                                    device: "plughw:1"
                                                  autostart: true,
                                                  autorestart: true,
                                                  notifications: {
                                                    PAUSE: "HOTWORD_PAUSE",
                                                    RESUME: "HOTWORD_RESUME",
                                                    LISTENING: "HOTWORD_LISTENING",
                                                    SLEEPING: "HOTWORD_SLEEPING",
                                                    ERROR: "HOTWORD_ERROR"
                                                  onDetected: {
                                                    notification: function(payload) {
                                                      return "ASSISTANT_ACTIVATE";
                                                    payload: function(payload) {
                                                      return {
                                          You can give it a try .
                                          Ejay
                                            @jmartin1009 but, that explains no response from the modules!
