    MMM-Assistantmk2 and MMM-Hotword not picking up
    54 Posts 9 Posters 41.9k Views 9 Watching
      sdetweil @jmartin1009
      @jmartin1009 i have not used those modules…
        @jmartin1009 if you start MM in developer mode,
        npm start dev
        and then select the console tab of the dev window
        do you see the notifications being sent?
        and u are not using MMM-Voice at the same time, right? only one module can have the mic at a time
        • ejay-ibmE Offline
          ejay-ibm Project Sponsor Module Developer
          seems to be an audio config issue .
          Please paste your config.js file here
          and the outputs of the following commands :
          aplay -l
          arecord -l
          Ejay
            jmartin1009 @sdetweil
            @sdetweil I’m not using MMM-Voice, I’m using MMM-Assistantmk2 and MMM-Hotword, hotword pics up the word to wake the assistant and assistant takes care of the rest. I’ve been able to talk to the assistant but hotword doesn’t wake when I say the wakeword.
              jmartin1009 @ejay-ibm
              @ejay-ibm here is my magicmirror config file:
              var config = {
              	port: 8080,
              	language: "en",
              	timeFormat: 12,
              	units: "imperial",
              			module: "updatenotification",
              			position: "top_bar"
              		    module: "MMM-AssistantMk2",
              		    position: "top_bar",
              		      record: {
              		        recordProgram : "arecord",
              		        device        : "plughw:1, 0",
              		      notifications: {
              		        ASSISTANT_ACTIVATED: "HOTWORD_PAUSE",
              		        ASSISTANT_DEACTIVATED: "HOTWORD_RESUME",
              		    module: "MMM-Hotword",
              		      record: {
              		      autostart:true,
              		      onDetected: {
              		        notification: function (payload) {
              		          return "ASSISTANT_ACTIVATE"
              		        payload: function (payload){
              		          return {
              		            profile: payload.hotword
              			module: "clock",
              			position: "top_left"
              			header: "US Holidays",
              						symbol: "calendar-check",
              			module: "compliments",
              			position: "lower_third"
              			module: "currentweather",
              				locationID: "4854529",  //ID from http://bulk.openweathermap.org/sample/; unzip the gz file and find your city
              				appid: "6730254e02c0f50e5d951db321f6fa33"
              			module: "weatherforecast",
              			header: "Weather Forecast",
              				locationID: "4854529",  //ID from https://openweathermap.org/city
                  			module: "MMM-EARTH",
                  			position: "bottom_right",
                      			mode: "Natural",
                      			rotateInterval: 15000,
                      			MaxWidth: "30%",
                      			MaxHeight: "30%",
              			module: "newsfeed",
              			position: "bottom_bar",
              				feeds: [
              						title: "New York Times",
              				showSourceTitle: true,
              				showPublishDate: true
                  			module: 'MMM-ShairportMetadata',
                  			position: 'bottom_left',
                    			    metadataPipe: "/tmp/shairport-sync-metadata", // location of pipe with shairport-sync metadata
              	  			alignment: "center",	// Possible values [left|right|center]. Default: center
              here is the output for aplay -l:
              pi@raspberrypi:~ $ aplay -l
              **** List of PLAYBACK Hardware Devices ****
              card 0: ALSA [bcm2835 ALSA], device 0: bcm2835 ALSA [bcm2835 ALSA]
                Subdevices: 7/7
                Subdevice #0: subdevice #0
                Subdevice #1: subdevice #1
                Subdevice #2: subdevice #2
                Subdevice #3: subdevice #3
                Subdevice #4: subdevice #4
                Subdevice #5: subdevice #5
                Subdevice #6: subdevice #6
              card 0: ALSA [bcm2835 ALSA], device 1: bcm2835 ALSA [bcm2835 IEC958/HDMI]
                Subdevices: 1/1
              I do use PulseAudio because i use the PS3 eye mic, which uses a mic array that alsamixer doesn’t like, but it works when i talk to the assistant, Hotword just doesn’t hear my wakewords.
              Here is the output for arecord -l
              pi@raspberrypi:~ $ arecord -l
              **** List of CAPTURE Hardware Devices ****
              card 1: CameraB409241 [USB Camera-B4.09.24.1], device 0: USB Audio [USB Audio]
                Subdevices: 1/1
              It seems to work whether i use “plughw: 0” and “plughw: 0, 1”.
                @jmartin1009 I would remove the space in the device name
                "plughw: 0,1"
                  I just installed MMM-Hotword, and used this config
                              autostart:true,
                              autorestart: true
                  and it works fine…
                  i did have a little snowboy rebuild work to do but documented in the hotword install doc…
                  J 3 Replies Last reply Reply Quote 0
                    @sdetweil I can try removing the space and hope to works, and I had to do the snowboy rebuild already as it said I had an error when I tried to start magicmirror, so that should be okay, so I’ll try deleting the space and if it doesn’t work I will try to rebuild snowboy and try again and I’ll get back to you. Thanks!!
                      @sdetweil is that your config for magicmirror or in the config file or hotword?
                        @sdetweil I tried getting rid of the space, I tried adding autorestart=true on both configs, and still no luck :/
                          @jmartin1009 just the config for hotword.
                          • ejay-ibmE Offline
                            I agree with Sam :
                            You need to remove the space at both places.
                            1st in MMM-AssistantMk2
                            		      record: {
                            		        device        : "plughw:1,0",
                            And as well in
                            		      record: {
                            If that still doesn’t work try just :
                            plughw:1
                            As well you should check in the audio properties that your mic have enough gain.
                            you can check this by typing
                            alsamixer
                            in command line
                            hope this helps
                            Ejay
                              @ejay-ibm @sdetweil what should I have in the module list in the config.js for the magicmirror program for each module? Not sure if I have the right stuff or too much or what
                                @ejay-ibm also is there anyway to change the gain or whatever? I went to alsamixer and went to the capture section and the bar doesn’t move or anything when I speak into my mic. Not sure if anything is supposed to happen but it says both L and R capture are the 100, not sure what that means.
                                  jmartin1009
                                  @ejay-ibm I also changed it so the sauce wasn’t there and I made it so it said plughw:1 in all of them, but still nothing
                                  • ejay-ibmE Offline
                                    This is my MMM-Hotword config.js part :
                                            snowboy: [
                                    						"hotwords": "smartmirror",
                                    						"file": "resources/models/smart_mirror.umdl",
                                    						"sensitivity": "0.5"
                                                hotwords: "alexa",
                                                file: "resources/models/alexa.umdl",
                                                sensitivity: "0.6"
                                                file: "resources/models/jarvis.umdl",
                                                sensitivity: "0.6,0.60",
                                                hotwords: ["jarvis", "jarvis"]
                                            record: {
                                              sampleRate: 16000,
                                              threshold: 0.5,
                                              thresholdStart: null,
                                              thresholdEnd: null,
                                              silence: 1,
                                              verbose: false,
                                              recordProgram: "arecord",
                                              device: "plughw:1"
                                            autostart: true,
                                            autorestart: true,
                                            notifications: {
                                              PAUSE: "HOTWORD_PAUSE",
                                              RESUME: "HOTWORD_RESUME",
                                              LISTENING: "HOTWORD_LISTENING",
                                              SLEEPING: "HOTWORD_SLEEPING",
                                              ERROR: "HOTWORD_ERROR"
                                            onDetected: {
                                              notification: function(payload) {
                                                return "ASSISTANT_ACTIVATE";
                                              payload: function(payload) {
                                                return {
                                    You can give it a try .
                                    Ejay
                                      @jmartin1009 but, that explains no response from the modules!
                                        @ejay-ibm that is for the MM config.js right? Or is that what you have in the MMM-Hotword.js config file?
                                          @sdetweil What explains no response from the modules? My mic’s gain in alsamixer? if so how can i fix that? Or should i just get a new mic
                                            @jmartin1009 i would get a new mic… clearly this one is having issues… is that the array?
