    MMM-AI
    Scheduled Pinned Locked Moved Fun & Games
    19 Posts 7 Posters 10.7k Views 10 Watching
    • ejay-ibmE Offline
      ejay-ibm Project Sponsor Module Developer
      Hello guys,
      This is my first module !
      Well I give most of the credit to @sean who created the code as i’m not a dev at all .
      What I did is taking MMM-TriggerNotification and MMM-HTMLBox, and merge those 2 modules in one to create mine based on the idea I had.
      https://github.com/ejay-ibm/MMM-AI
      MMM-AI
      MMM-AI is a simple module based on a mix of MMM-NotificationTrigger & MMM-HTMLBOX from eouia that allow to have animation of ‘AI’ kind when the assistant ( Alexa / MMM-Mk2assistant ) is in standby mode ( waiting for user instruction) or talking mode ( when assistant is replying ) triggered by Notification sent by these modules.
      Screenshot
          Standby animation                     Talking animation
      Full gif here :
      https://github.com/ejay-ibm/MMM-AI/blob/master/jarvis-standby2.gif
      https://github.com/ejay-ibm/MMM-AI/blob/master/jarvis-talk2.gif
      alt text
      Installation
      In the MagicMirror/modules directory run :
      git clone https://github.com/ejay-ibm/MMM-AI.git
      Configuration Sample
            module: "MMM-AI",
            position: "top_center",
              width: "300px",
              height: "300px",
              refresh_interval_sec: 0, // you should not refresh, because content will be back to default value.
              content: `<img id="MY_ANIMATION" src="modules/MMM-AI/jarvis-standby2.gif"/>`,
              triggers: [
                  trigger: "HOTWORD_RESUME", // HOTWORD_LISTENING if you use MMM-HOTWORD  or HOTWORD_RESUME if you use MMM-AssistantMk2
                  fires: [
                      fire: "standby_Image",
                      payload: payload => {
                        var img = document.getElementById("MY_ANIMATION");
                        img.src = "modules/MMM-AI/jarvis-standby2.gif";
                        return payload;
                  trigger: "ASSISTANT_UNDERSTOOD", // HOTWORD_SLEEPING if you use MMM-HOTWORD  or HOTWORD_PAUSE if you use MMM-AssistantMk2
                  fires: [
                      fire: "Talk_Image",
                        img.src = "modules/MMM-AI/jarvis-talk2.gif";
                        return payload;
      Additional Info
      please make sure you are up to date on the Mk2 assistant module for this module to work as expected
      All other configuration sample from https://github.com/eouia/MMM-HTMLBOX & https://github.com/eouia/MMM-NotificationTrigger are applicable to this module.
      Thanks again to Sean : https://github.com/eouia/ who have created this code that I have merged for this module purpose.
      Animated images are created by me using crazy talk and Photoshop I will work to create additional ones.
      justjim1220J 1 Reply Last reply Reply Quote 3
      • ejay-ibmE Offline
        If you have any idea on standby/talk animation I can create for this module feel free to propose them !
        I’m planning to make an ‘HAL’ one
        based on this image :
        0_1551897653917_merlin_135847308_098289a6-90ee-461b-88e2-20920469f96a-articleLarge.jpg
        Ejay
        T justjim1220J 3 Replies Last reply Reply Quote 2
        • T Offline
          teitlebot @ejay-ibm
          @ejay-ibm great job. its working with GA on my mirror.
          waiting to hear if you get it updated to start moving only on response.
          ejay-ibmE 1 Reply Last reply Reply Quote 0
          • ejay-ibmE Offline
            ejay-ibm Project Sponsor Module Developer @teitlebot
            @teitlebot Hey the feature has been implemented,
            Sorry i’m crawling under work and forgot to update ( I’ll update my repo in the week . )
            You just need to update your Mk2 assisant ( Git Pull from MMM-Assistant folder)
            @Sean the developer gently added new notification called ASSISTANT_UNDERSTOOD . Use that one to trigger the talking effect .
            That is my config.js sample :
            module: "MMM-AI",
                    width: "300px",
                    height: "400px",
                    triggers: [
                        fires: [
                              return payload;
                        trigger: "HOTWORD_PAUSE",
                        fires: [
                            fire: "VOLUME_STORE",
                            //fire: "VOLUME_MUTE",
                            exec: "amixer set Master 10% -q"
                        fires: [
                            fire: "VOLUME_RESTORE",
                              return payload;
            Ejay
            T 1 Reply Last reply Reply Quote 2
            • justjim1220J Offline
              justjim1220 Module Developer @ejay-ibm
              @ejay-ibm
              Would it be possible for the user to change the avatar to their personal likeness?
              For example, be able to use a family member’s face, or an actor/actress, a cartoon character, etc. ?
              Or like the HAL2000, maybe the Alexa bar or circle animations?
              Jim Hallock - 1995
                @ejay-ibm
                I would be interested in Max Headroom, with his tourette-style glitches included!!!
                Jim Hallock - 1995
                  @ejay-ibm
                  You might be interested in the following links:
                  https://avatarsdk.com/?_ga=2.125796682.1526809898.1553040863-987282811.1553040863
                  https://api.avatarsdk.com/samples/web/#
                  Jim Hallock - 1995
                  ejay-ibmE T 2 Replies Last reply Reply Quote 0
                  • ejay-ibmE Offline
                    ejay-ibm Project Sponsor Module Developer @justjim1220
                    @justjim1220
                    Yes everything is possible .
                    It’s just different gif ani .
                    So you can make gif with your family members from a video and convert it to gif .
                    I’m using crazy head to transform a static picture into a moving / talking avatar .
                    Then some photoshop to finalize the gif.
                    Ejay
                    • T Offline
                      teitlebot @ejay-ibm
                      @ejay-ibm Thanks
                      I would like to implement it a bit different.
                      I would like no image unless the mirror is called.
                      I found a trigger “ASSISTANT_RESPONSE_END : this notification will be bursted when Assistant’s voice responsing is ended.”
                      I just dont know what code I need to put to make the image not appear other than putting a blank gif file. I assume there is a proper code.
                      • T Offline
                        teitlebot @justjim1220
                        @justjim1220 This is amazing
                        I was able to use the sample and also make an account but I cant figure how to get a gif from it to use in Magic Mirror. Any ideas?
