    MMM-AI
    Scheduled Pinned Locked Moved Fun & Games
    19 Posts 7 Posters 12.0k Views 10 Watching
    • justjim1220J Offline
      justjim1220 Module Developer @ejay-ibm
      @ejay-ibm
      I would be interested in Max Headroom, with his tourette-style glitches included!!!
      "Life's Too Short To Dance With Ugly People"
      Jim Hallock - 1995
        @ejay-ibm
        You might be interested in the following links:
        https://avatarsdk.com/?_ga=2.125796682.1526809898.1553040863-987282811.1553040863
        https://api.avatarsdk.com/samples/web/#
        Jim Hallock - 1995
        ejay-ibmE T 2 Replies Last reply Reply Quote 0
        • ejay-ibmE Offline
          ejay-ibm Project Sponsor Module Developer @justjim1220
          @justjim1220
          Yes everything is possible .
          It’s just different gif ani .
          So you can make gif with your family members from a video and convert it to gif .
          I’m using crazy head to transform a static picture into a moving / talking avatar .
          Then some photoshop to finalize the gif.
          Ejay
          • T Offline
            teitlebot @ejay-ibm
            @ejay-ibm Thanks
            I would like to implement it a bit different.
            I would like no image unless the mirror is called.
            I found a trigger “ASSISTANT_RESPONSE_END : this notification will be bursted when Assistant’s voice responsing is ended.”
            I just dont know what code I need to put to make the image not appear other than putting a blank gif file. I assume there is a proper code.
            ejay-ibmE 1 Reply Last reply Reply Quote 0
            • T Offline
              teitlebot @justjim1220
              @justjim1220 This is amazing
              I was able to use the sample and also make an account but I cant figure how to get a gif from it to use in Magic Mirror. Any ideas?
              • ejay-ibmE Offline
                ejay-ibm Project Sponsor Module Developer @teitlebot
                @teitlebot You need to export as a movie, Then make an import as frame in photoshop
                This will give you an idea
                https://graphicdesign.stackexchange.com/questions/46656/how-to-convert-a-video-file-into-an-animated-gif-in-photoshop
                Ejay
                • ejay-ibmE Offline
                  @teitlebot I would use a black pixel image as no image
                  you can find all you need here
                  https://github.com/aureooms/pixels
                  Ejay
                  • T Offline
                    teitlebot @ejay-ibm
                    @ejay-ibm thanks. I figured there was a proper way to code a picture to be gone but this will work I guess. Thanks
                    • T Offline
                      teitlebot @teitlebot
                      @teitlebot @Sean Any idea how I can get it to fade the face on and off from the black pixel?
                      • ejay-ibmE Offline
                        @teitlebot Hi would do it from photophop as part of the animation . But their’s maybe a way to do it in javascript but that would need some additional implementation in the modules .
                        Working with the gif is more flexible in my taste .
                        Ejay
