    Volvo on Call
    34 Posts 4 Posters 14.3k Views 4 Watching
    • MZ-BERM
      MZ-BER @JerryP
      Hey @jerryp - I’m getting the output as soon as I write voc list. So that seems to work.
      My config:
        module: "MMM-VolvoOnCall",
      	scanInterval: 1000 * 60 * 30,
              units: "metric",
              timestampFormat: "MMM D. HH:mm:ss",
      	durationFormat: "HH:mm",
      @JerryP Can you please share your config? I’m not sure what I’m doing wrong.
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @MZ-BER
        @mz-ber
        yes but now you miss the data in the config
        			disabled: false, //false, true
        			position: "bottom_left",
        			units: "metric",
        			mapConfig: {
        				apiKey: "",  // Your Google Map API Key
        			display: { // You can control which section will be displayed or not.
        				info: false,
        				position: false,
        				status: true,
        				notice: true,
        				trip: false,
        MZ-BERM 1 Reply Last reply
        • MZ-BERM
          MZ-BER @JerryP
          @jerryp Okay, do I need an api key from google maps?
          • JerryPJ
            JerryP @MZ-BER
            @mz-ber
            yes i’f you use the map function. I have add the api and it’s working fine
            • MZ-BERM
              MZ-BER @JerryP
              @jerryp is it working for you without the map function? I’m actually not interested in it.
              • JerryPJ
                JerryP @MZ-BER
                @mz-ber
                Yes but i have put the api key in the config. I dont have try it whitout the key
                • MZ-BERM
                  MZ-BER @JerryP
                  @jerryp Would you do me a favor and test it without the key or a wrong key? Just wondering if that is the issue
                  • JerryPJ
                    JerryP @MZ-BER
                    @mz-ber
                    yes it’s working like above whit out api key
                    • MZ-BERM
                      MZ-BER @JerryP
                      @jerryp Hi Jerry - thank you for checking! I still stuck and I dont know where I’m doing something wrong. I dont want to give up because I know it is still working for you.
                      The weird thing is that the API works perfect. I can pull all informations from my car via voc dashborad.
                      Only the module is telling me: No vehicle found
                      That is my current config:
                      	  disabled: false,
                      	  debug: true,
                      		units: "metric",
                      		display: {
                      					info: true,
                      					position: true,
                      					status: true,
                      					notice: true,
                      					trip: true,
                      It is setup correctly I guess.
                      I’m wondering where in this node_helper.js is the voc pulled from? I’m not good in JavaScript :-(
                      const exec = require('child_process').exec
                      const spawn = require('child_process').spawn
                      const moment = require("moment")
                      var NodeHelper = require("node_helper")
                        start: function() {
                          this.config = null
                          this.carInfo = []
                        socketNotificationReceived: function(noti, payload) {
                          if (noti == "SCAN") {
                            this.scan()
                            this.trip()
                          if (noti == "INIT") {
                            this.config = payload
                            this.list()
                        list: function() {
                          exec("voc list", (e, sdo, sde)=>{
                            if (e) {
                              console.log("[VOC] ERROR(>list):", e.toString())
                            } else {
                              this.listResult(sdo)
                        listResult: function(output) {
                          var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
                          var matches = null
                          var result = []
                          while (matches = re.exec(output)) {
                            this.carInfo.push({
                              type: matches[2],
                              vin: matches[3]
                          if (this.carInfo.length > 0) {
                            this.sendSocketNotification("INITIALIZED", this.carInfo)
                          } else {
                            console.log("[VOC] ERROR: No vehicle found. Check your account. Module stopped.")
                        scan: function() {
                          exec("voc dashboard", (e, sdo, sde)=> {
                            if (e) {
                              console.log("[VOC] ERROR:", e.toString())
                            } else {
                              this.scanResult(sdo)
                              //this.sendSocketNotification("RESULT", sdo)
                        scanResult: function(output) {
                          var carIndex = this.carInfo.map((value, index, array)=>{
                            return value.id
                          var result = []
                          var re = /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm
                          var matches = null
                            var idx = carIndex.indexOf(matches[1])
                            var key = matches[2].trim()
                            var value = this.reformValue(key, matches[3].trim())
                            if (typeof result[idx] == 'undefined') {
                              result[idx] = []
                            result[idx].push({
                              key: key,
                              value: value
                          if (Object.keys(result).length == 0) {
                            console.log("[VOC] ERROR: No information could be retrieved.")
                            console.log(output)
                          } else {
                            this.sendSocketNotification("SCAN_RESULT", result)
                        reformValue: function(key, value) {
                          if (key == "Position") {
                            var re = /([0-9\.\-]+)\,\s([0-9\.\-]+),\s\'([^\']+)\'/
                            var matches = re.exec(value)
                            if (matches) {
                              return {
                                lat: matches[1],
                                long: matches[2],
                                time: moment(matches[3]).format("X")
                            } else {
                              return null
                          if (key == "Fuel level") {
                            return value.replace(/\s/, "")
                          if (key == "Fuel amount" || key == "Range" || key == "Odometer" || key == "Average speed") {
                            return value.replace(/[^0-9\.]+/g, '')
                          if (key == "Fuel consumption") {
                            var re = /^([0-9\.]+)/g
                            if (matches) {
                              return matches[1]
                          return value
                        trip: function() {
                          for(var i = 0; i < this.carInfo.length; i++) {
                            try {
                              carId = this.carInfo[i].id
                              var sdo = ""
                              var result = spawn('voc', [
                                '-i', carId,
                                '--json', 'trips'
                              result.stdout.on('data', (data)=>{
                                sdo += data
                              result.on('close', (killcode)=>{
                                this.tripResult(carId, JSON.parse(sdo))
                            } catch (e) {
                        tripResult: function(carId, obj) {
                          if (Array.isArray(obj) && obj.length > 0) {
                            var trip = obj[0]
                            var detail = trip.tripDetails[0]
                            var ret = {
                              title: trip.name,
                              category: trip.category,
                              note: trip.userNotes,
                              fuelConsumption : detail.fuelConsumption,
                              electricalConsumption : detail.electricalConsumption,
                              electricalRegeneration: detail.electricalRegeneration,
                              distance: detail.distance,
                              startTime: moment(detail.startTime).format("X"),
                              startPosition: detail.startPosition,
                              endTime: moment(detail.endTime).format("X"),
                              endPosition: detail.endPosition,
                            this.sendSocketNotification("TRIP_RESULT", {id:carId, data:ret})
                          } else {
                            return
                        sdetweil @MZ-BER
                        @mz-ber
                        list: function() {
                              if (e) {
                              } else {
                        then the good results are parsed in listResult()
                        • MZ-BERM
                          MZ-BER @sdetweil
                          @sdetweil Thank you Sam! Can you please tell me what the letters in the bracket mean? (e, sdo, sde)
                          • MZ-BERM
                            MZ-BER @MZ-BER
                            @mz-ber Oh I guess I understand. If the function is not getting the right details than -> e if everything is okay than -> sdo
                              sdetweil @MZ-BER
                              @mz-ber exec(“voc list”, (e, sdo, sde)=
                              execs the command “voc list”
                              and the exec function returns
                              error (e)
                              stdout (sdo)
                              and stderr(sde)
                              so if no error (e is null)
                              it sends the command output to the listResults function
                              • MZ-BERM
                                MZ-BER @sdetweil
                                @sdetweil Thank you for the explanation. Is the function executing voc list in the terminal? If I’m doing manually voc list I’m getting a result.
                                Is there a way to see what the script is getting back in detail?
                                Again, thank you very much!
                                  sdetweil @MZ-BER
                                  @mz-ber yes executing just like on console
                                  nothing built in to show results.
                                  but you could add a
                                  console.log(sdo)
                                  before the call to listResults()
                                  and see it where u start mm
                                  npm start
                                  it should be the same outout
                                  • MZ-BERM
                                    MZ-BER @sdetweil
                                    @sdetweil Alright, I added the console.log before the call listResult() and it is getting the details from my car. I feel sooo close to get this running but I dont know where it is stuck. :anguished_face:
                                    Is maybe the regex search not getting the details viewed?
                                      sdetweil @MZ-BER
                                      @mz-ber so the regular expression isn’t finding your text
                                      I use this for building and testing rejects
                                      https://regex101.com/
                                      • MZ-BERM
                                        MZ-BER @sdetweil
                                        @sdetweil Yes, I also checked that with regex101. Can I just parse in the details I have?
                                            var re = B-PY 186 (V90) XVASS123345
                                        S 2 Replies Last reply
                                          sdetweil @MZ-BER
                                          @mz-ber the regex returns an array of matched things
                                            sdetweil @MZ-BER
                                            @mz-ber i think the regex is not expecting the 186
                                            try ths one
                                            /^([^ ]+)\s.*\(([^\/]+)\/([^\)]+)\)$/gm
                                            start of string ^
                                            capture up to the 1st space ([^ ]+)
                                            skip everything to (and including) the open paren \s.*(
                                            get the two things in the parens, separated by /, not including the parens
                                            capture up to the slash ([^/]+)
                                            skip the slash /
                                            capture up to the close pareen ([^)]+)
                                            skip the close paren )
                                            end of string $
