    Volvo on Call
    34 Posts 4 Posters 14.3k Views 4 Watching
    • MZ-BERM
      MZ-BER @JerryP
      @jerryp is it working for you without the map function? I’m actually not interested in it.
      JerryPJ 1 Reply Last reply
      • JerryPJ
        JerryP @MZ-BER
        @mz-ber
        Yes but i have put the api key in the config. I dont have try it whitout the key
        MZ-BERM 1 Reply Last reply
        • MZ-BERM
          MZ-BER @JerryP
          @jerryp Would you do me a favor and test it without the key or a wrong key? Just wondering if that is the issue
          • JerryPJ
            JerryP @MZ-BER
            @mz-ber
            yes it’s working like above whit out api key
            • MZ-BERM
              MZ-BER @JerryP
              @jerryp Hi Jerry - thank you for checking! I still stuck and I dont know where I’m doing something wrong. I dont want to give up because I know it is still working for you.
              The weird thing is that the API works perfect. I can pull all informations from my car via voc dashborad.
              Only the module is telling me: No vehicle found
              That is my current config:
              	  module: "MMM-VolvoOnCall",
              	  disabled: false,
              	  debug: true,
              		scanInterval: 1000 * 60 * 30,
              		units: "metric",
              		timestampFormat: "MMM D. HH:mm:ss",
              		durationFormat: "HH:mm",
              		display: {
              					info: true,
              					position: true,
              					status: true,
              					notice: true,
              					trip: true,
              It is setup correctly I guess.
              I’m wondering where in this node_helper.js is the voc pulled from? I’m not good in JavaScript :-(
              const exec = require('child_process').exec
              const spawn = require('child_process').spawn
              const moment = require("moment")
              var NodeHelper = require("node_helper")
                start: function() {
                  this.config = null
                  this.carInfo = []
                socketNotificationReceived: function(noti, payload) {
                  if (noti == "SCAN") {
                    this.scan()
                    this.trip()
                  if (noti == "INIT") {
                    this.config = payload
                    this.list()
                list: function() {
                  exec("voc list", (e, sdo, sde)=>{
                    if (e) {
                      console.log("[VOC] ERROR(>list):", e.toString())
                    } else {
                      this.listResult(sdo)
                listResult: function(output) {
                  var re = /^([^ ]+)\s\(([^\)]+)\)\s([^ ]+)$/gm
                  var matches = null
                  var result = []
                  while (matches = re.exec(output)) {
                    this.carInfo.push({
                      type: matches[2],
                      vin: matches[3]
                  if (this.carInfo.length > 0) {
                    this.sendSocketNotification("INITIALIZED", this.carInfo)
                  } else {
                    console.log("[VOC] ERROR: No vehicle found. Check your account. Module stopped.")
                scan: function() {
                  exec("voc dashboard", (e, sdo, sde)=> {
                    if (e) {
                      console.log("[VOC] ERROR:", e.toString())
                    } else {
                      this.scanResult(sdo)
                      //this.sendSocketNotification("RESULT", sdo)
                scanResult: function(output) {
                  var carIndex = this.carInfo.map((value, index, array)=>{
                    return value.id
                  var result = []
                  var re = /^([^\s]+)\s([\w\s]+)\:\s(.+)$/gm
                  var matches = null
                    var idx = carIndex.indexOf(matches[1])
                    var key = matches[2].trim()
                    var value = this.reformValue(key, matches[3].trim())
                    if (typeof result[idx] == 'undefined') {
                      result[idx] = []
                    result[idx].push({
                      key: key,
                      value: value
                  if (Object.keys(result).length == 0) {
                    console.log("[VOC] ERROR: No information could be retrieved.")
                    console.log(output)
                  } else {
                    this.sendSocketNotification("SCAN_RESULT", result)
                reformValue: function(key, value) {
                  if (key == "Position") {
                    var re = /([0-9\.\-]+)\,\s([0-9\.\-]+),\s\'([^\']+)\'/
                    var matches = re.exec(value)
                    if (matches) {
                      return {
                        lat: matches[1],
                        long: matches[2],
                        time: moment(matches[3]).format("X")
                    } else {
                      return null
                  if (key == "Fuel level") {
                    return value.replace(/\s/, "")
                  if (key == "Fuel amount" || key == "Range" || key == "Odometer" || key == "Average speed") {
                    return value.replace(/[^0-9\.]+/g, '')
                  if (key == "Fuel consumption") {
                    var re = /^([0-9\.]+)/g
                    if (matches) {
                      return matches[1]
                  return value
                trip: function() {
                  for(var i = 0; i < this.carInfo.length; i++) {
                    try {
                      carId = this.carInfo[i].id
                      var sdo = ""
                      var result = spawn('voc', [
                        '-i', carId,
                        '--json', 'trips'
                      result.stdout.on('data', (data)=>{
                        sdo += data
                      result.on('close', (killcode)=>{
                        this.tripResult(carId, JSON.parse(sdo))
                    } catch (e) {
                tripResult: function(carId, obj) {
                  if (Array.isArray(obj) && obj.length > 0) {
                    var trip = obj[0]
                    var detail = trip.tripDetails[0]
                    var ret = {
                      title: trip.name,
                      category: trip.category,
                      note: trip.userNotes,
                      fuelConsumption : detail.fuelConsumption,
                      electricalConsumption : detail.electricalConsumption,
                      electricalRegeneration: detail.electricalRegeneration,
                      distance: detail.distance,
                      startTime: moment(detail.startTime).format("X"),
                      startPosition: detail.startPosition,
                      endTime: moment(detail.endTime).format("X"),
                      endPosition: detail.endPosition,
                    this.sendSocketNotification("TRIP_RESULT", {id:carId, data:ret})
                  } else {
                    return
                sdetweil @MZ-BER
                @mz-ber
                list: function() {
                      if (e) {
                      } else {
                then the good results are parsed in listResult()
                • MZ-BERM
                  MZ-BER @sdetweil
                  @sdetweil Thank you Sam! Can you please tell me what the letters in the bracket mean? (e, sdo, sde)
                  • MZ-BERM
                    MZ-BER @MZ-BER
                    @mz-ber Oh I guess I understand. If the function is not getting the right details than -> e if everything is okay than -> sdo
                      sdetweil @MZ-BER
                      @mz-ber exec(“voc list”, (e, sdo, sde)=
                      execs the command “voc list”
                      and the exec function returns
                      error (e)
                      stdout (sdo)
                      and stderr(sde)
                      so if no error (e is null)
                      it sends the command output to the listResults function
                      • MZ-BERM
                        MZ-BER @sdetweil
                        @sdetweil Thank you for the explanation. Is the function executing voc list in the terminal? If I’m doing manually voc list I’m getting a result.
                        Is there a way to see what the script is getting back in detail?
                        Again, thank you very much!
                          sdetweil @MZ-BER
                          @mz-ber yes executing just like on console
                          nothing built in to show results.
                          but you could add a
                          console.log(sdo)
                          before the call to listResults()
                          and see it where u start mm
                          npm start
                          it should be the same outout
                          • MZ-BERM
                            MZ-BER @sdetweil
                            @sdetweil Alright, I added the console.log before the call listResult() and it is getting the details from my car. I feel sooo close to get this running but I dont know where it is stuck. :anguished_face:
                            Is maybe the regex search not getting the details viewed?
                              sdetweil @MZ-BER
                              @mz-ber so the regular expression isn’t finding your text
                              I use this for building and testing rejects
                              https://regex101.com/
                              • MZ-BERM
                                MZ-BER @sdetweil
                                @sdetweil Yes, I also checked that with regex101. Can I just parse in the details I have?
                                    var re = B-PY 186 (V90) XVASS123345
                                S 2 Replies Last reply
                                  sdetweil @MZ-BER
                                  @mz-ber the regex returns an array of matched things
                                    sdetweil @MZ-BER
                                    @mz-ber i think the regex is not expecting the 186
                                    try ths one
                                    /^([^ ]+)\s.*\(([^\/]+)\/([^\)]+)\)$/gm
                                    start of string ^
                                    capture up to the 1st space ([^ ]+)
                                    skip everything to (and including) the open paren \s.*(
                                    get the two things in the parens, separated by /, not including the parens
                                    capture up to the slash ([^/]+)
                                    skip the slash /
                                    capture up to the close pareen ([^)]+)
                                    skip the close paren )
                                    end of string $
                                    • MZ-BERM
                                      MZ-BER @sdetweil
                                      @sdetweil Your one is not working. Here are the details I try to get:
                                      B-PY 186 (V90/2019) YV1PWAKUDK1XXXXXX
                                      I also played a bit with the expression and removed the white space:
                                      before:
                                      after:
                                          var re = /^([^]+)\s\(([^\)]+)\)\s([^]+)$/gm
                                      That is working based on regex101 and I dont get the error anymore. But nothing is loaded into the MM
                                        sdetweil @MZ-BER
                                        @mz-ber the regex has to return 3 items
                                        • MZ-BERM
                                          MZ-BER @sdetweil
                                          @sdetweil Right! And I guess it is doing so? Or am I wrong? b5cae454-af0f-4887-abbb-bd6117d3fe82-image.png
                                            sdetweil @MZ-BER
                                            @mz-ber i do not know what the module is expecting or its process
                                            it also does a voc dashboard…
                                            and parses that…
