    Mistake in the config.js and i dont no
    11 Posts 4 Posters 11.4k Views 3 Watching
    • brobergB Offline
      broberg Project Sponsor @Thomas
      @Thomas
      try to remove the dots under types: [“diesel”],
      I’m Swedish btw.
      • T Offline
        Thomas @Thomas
        @Thomas
        Good morning and thanks for your answer.
        i delete the points under diesel but it doesn´t work.
        we will see :-)
        Many thanks for your support !
        Best Regards Thomas
        • yawnsY Offline
          yawns Moderator @Thomas
          Please remove this
            	module: 'calendar',
          • T Offline
            Thomas @yawns
            @yawns
            Good morning , thanks for the support !
            I delete the entires and now i have no error but a blank screen :-)
            Idont now …it very difficult.
            i think i quit the projekt…its better :-)
            here is my config again …
            Best regards from Germany !
            Thomas
            var config = {
            port: 8080,
            language: 'en',
            timeFormat: 24,
            units: 'metric',
            		module: 'alert',
            		module: 'clock',
            		position: 'top_left'
            		module: 'compliments',
            		position: 'lower_third'
            		module: 'currentweather',
            		position: 'top_right',
            			locationID: '',  //ID from http://www.openweathermap.org
            			appid: 'YOUR_OPENWEATHER_API_KEY'
            		module: 'weatherforecast',
            		header: 'Weather Forecast',
            			locationID: '5128581',  //ID from http://www.openweathermap.org
            		module: 'newsfeed',
            		position: 'bottom_bar',
            			feeds: [
            					title: "New York Times",
            			showSourceTitle: true,
            			showPublishDate: true
                                module: "MMM-Fuel",
                                    api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                    lat: 52.518611,
                                    lng: 13.408333,
                                    types: ["diesel"],
            if (typeof module !== ‘undefined’) {module.exports = config;}
            • yawnsY Offline
              yawns Moderator
              Okay, dann eben auf deutsch.
              Ich habe deine config Datei komplett kopiert und bei mir eingefügt. Das funktioniert, also kopiere bitte das hier drunter komplett und ersetze deine config Datei dadurch.
              var config = {
              	port: 8080,
              	language: 'de',
              	timeFormat: 24,
              	units: 'metric',
              			module: 'alert',
              			module: 'clock',
              			module: 'newsfeed',
              				feeds: [
              			module: "MMM-Fuel",
              				lat: 52.518611,
              				lng: 13.408333,
              				types: ["diesel"],
              Hier fehlen natürlich die Keys für Currentweather/Forecast und MMM-Fuel, aber ich sehe Ausgaben auf dem Bildschirm.
              Hast du MMM-Fuel auch als Modul bei dir installiert? Oder hast du nur die Einträge in der config Datei gesetzt? Wenn ich nur die Einträge setze, sehe ich einen schwarzen Bildschirm. Wenn ich aber das Modul installiere, dann funktioniert es. Öffne eine Konsole auf dem Raspberry oder nutze eine SSH shell, um auf dem Raspberry zu arbeiten:
              cd ~/MagicMirror/modules
              git clone https://github.com/fewieden/MMM-Fuel.git
              cd MMM-Fuel
              npm install
              Danach den MagicMirror neu starten und testen.
              Grüße aus Solingen, Stefan
              • T Offline
                Thomas @yawns
                @yawns
                Hallo Stefan,
                vielen vielen Dank für deine Hilfe.
                Ich habe alles so gamacht wie Du beschrieben hast und siehe da es lief.
                Super !
                Es ist als absoluter Änfänger machmal gar nicht so leicht.
                Eine Frag zu Abschluss. Kann man die Schriftfarbe der einzelnen Module auch ändern ?
                Vielleicht hast Du ja da auch eine Lösung parat. :-)
                Dir und deiner Familie einen guten Rutsch in´s neue Jahr und die besten Wünsche für 2017 !
                Grüße aus Steinheim /Westf
                Thomas
                • strawberry 3.141S Offline
                  strawberry 3.141 Project Sponsor Module Developer @Thomas
                  @Thomas you can define your own styling in ~/MagicMirror/css/custom.css, for the most modules this should work
                  .MODULENAME {
                    color: blue;
                  • T Offline
                    Thomas @strawberry 3.141
                    @strawberry-3.141
                    Thanks a lot ! It works !
                    Thomas
