Mistake in the config.js and i dont no
11 Posts 4 Posters 10.0k Views 3 Watching
  • T Offline
    Thomas
    I´m a Newbie and a have a problem with the config.js at the Magic Mirror.
    I ´m insert a the third module MMM-Fuel and now a have a error after the boot.
    Here ist my config.js datei.
    can someone help me with this Problem ?
    Many thanks !!
    Thomas
    /* Magic Mirror Config Sample
    • MIT Licensed.
    var config = {
    port: 8080,
    language: 'en',
    timeFormat: 24,
    units: 'metric',
    		module: 'alert',
    		module: 'clock',
    		position: 'top_left'
    		module: 'calendar',
    		module: 'compliments',
    		position: 'lower_third'
    		module: 'currentweather',
    		position: 'top_right',
    			locationID: '',  //ID from http://www.openweathermap.org
    			appid: 'YOUR_OPENWEATHER_API_KEY'
    		module: 'weatherforecast',
    		header: 'Weather Forecast',
    			locationID: '5128581',  //ID from http://www.openweathermap.org
    		module: 'newsfeed',
    		position: 'bottom_bar',
    			feeds: [
    					title: "New York Times",
    			showSourceTitle: true,
    			showPublishDate: true
                        module: "MMM-Fuel",
                            api_key: "e4a59b56-f6c7-4bef-1eb3-456af035d82c",
                            lat: 52.518611,
                            lng: 13.408333,
                            types: ["diesel"],
    if (typeof module !== ‘undefined’) {module.exports = config;}
    B 1 Reply Last reply Dec 27, 2016, 12:35 PM Reply Quote 0
      broberg Project Sponsor @Thomas
      @Thomas
      you are missing { }, around the fuel module
      should look like this
                          module: "MMM-Fuel",
                              api_key: "",
                              lat: 52.518611,
                              lng: 13.408333,
                              types: ["diesel"],
      And btw, don’t give out your API-key, remove it when you post config files
      • T Offline
        Thomas
        @broberg
        Many thanks for your answer.
        Please lock at my config.js again.
        There is a error in it but i dont no.
        Sorry that i request you again !!
        Many thanks ! (you are german ?)
        Thomas
        var config = {
        port: 8080,
        language: 'en',
        timeFormat: 24,
        units: 'metric',
        		module: 'alert',
        		module: 'clock',
        		module: 'calendar',
        		module: 'newsfeed',
        			feeds: [
                            module: "MMM-Fuel",
                                api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                lat: 52.518611,
                                lng: 13.408333,
                                types: ["diesel"],
        B T yawnsY 3 Replies Last reply Dec 27, 2016, 3:27 PM Reply Quote 0
          @Thomas
          try to remove the dots under types: [“diesel”],
          I’m Swedish btw.
          • T Offline
            Thomas @Thomas
            @Thomas
            Good morning and thanks for your answer.
            i delete the points under diesel but it doesn´t work.
            we will see :-)
            Many thanks for your support !
            Best Regards Thomas
            • yawnsY Offline
              yawns Moderator @Thomas
              Please remove this
                	module: 'calendar',
              T 1 Reply Last reply Dec 29, 2016, 10:52 AM Reply Quote 1
              • T Offline
                Thomas @yawns
                @yawns
                Good morning , thanks for the support !
                I delete the entires and now i have no error but a blank screen :-)
                Idont now …it very difficult.
                i think i quit the projekt…its better :-)
                here is my config again …
                Best regards from Germany !
                Thomas
                var config = {
                port: 8080,
                language: 'en',
                timeFormat: 24,
                units: 'metric',
                		module: 'alert',
                		module: 'clock',
                		module: 'newsfeed',
                			feeds: [
                                    module: "MMM-Fuel",
                                        api_key: "xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx",
                                        lat: 52.518611,
                                        lng: 13.408333,
                                        types: ["diesel"],
                • yawnsY Offline
                  yawns Moderator
                  Okay, dann eben auf deutsch.
                  Ich habe deine config Datei komplett kopiert und bei mir eingefügt. Das funktioniert, also kopiere bitte das hier drunter komplett und ersetze deine config Datei dadurch.
                  var config = {
                  	port: 8080,
                  	language: 'de',
                  	timeFormat: 24,
                  	units: 'metric',
                  			module: 'alert',
                  			module: 'clock',
                  			module: 'newsfeed',
                  				feeds: [
                  			module: "MMM-Fuel",
                  				lat: 52.518611,
                  				lng: 13.408333,
                  				types: ["diesel"],
                  Hier fehlen natürlich die Keys für Currentweather/Forecast und MMM-Fuel, aber ich sehe Ausgaben auf dem Bildschirm.
                  Hast du MMM-Fuel auch als Modul bei dir installiert? Oder hast du nur die Einträge in der config Datei gesetzt? Wenn ich nur die Einträge setze, sehe ich einen schwarzen Bildschirm. Wenn ich aber das Modul installiere, dann funktioniert es. Öffne eine Konsole auf dem Raspberry oder nutze eine SSH shell, um auf dem Raspberry zu arbeiten:
                  cd ~/MagicMirror/modules
                  git clone https://github.com/fewieden/MMM-Fuel.git
                  cd MMM-Fuel
                  npm install
                  Danach den MagicMirror neu starten und testen.
                  Grüße aus Solingen, Stefan
                  T 1 Reply Last reply Dec 29, 2016, 4:09 PM Reply Quote 1
                  • T Offline
                    Thomas @yawns
                    @yawns
                    Hallo Stefan,
                    vielen vielen Dank für deine Hilfe.
                    Ich habe alles so gamacht wie Du beschrieben hast und siehe da es lief.
                    Super !
                    Es ist als absoluter Änfänger machmal gar nicht so leicht.
                    Eine Frag zu Abschluss. Kann man die Schriftfarbe der einzelnen Module auch ändern ?
                    Vielleicht hast Du ja da auch eine Lösung parat. :-)
                    Dir und deiner Familie einen guten Rutsch in´s neue Jahr und die besten Wünsche für 2017 !
                    Grüße aus Steinheim /Westf
                    Thomas
                    strawberry 3.141S 1 Reply Last reply Dec 29, 2016, 5:02 PM Reply Quote 0
                    • strawberry 3.141S Offline
                      strawberry 3.141 Project Sponsor Module Developer @Thomas
                      @Thomas you can define your own styling in ~/MagicMirror/css/custom.css, for the most modules this should work
                      .MODULENAME {
                        color: blue;
                      T 1 Reply Last reply Dec 29, 2016, 5:23 PM Reply Quote 1
