    MMM-GooglePhotos
    294 Posts 56 Posters 382.3k Views 59 Watching
    • G Offline
      gonzonia
      New error now that I’ve increased logging. Not sure it’s related but it does seem more specific.
      Error: getaddrinfo EAI_AGAIN photoslibrary.googleapis.com
      Which could be this. https://github.com/googleapis/google-api-nodejs-client/issues/761
      Popping up at this line (I have a log entry directly before that shows up, and one after that doesn’t)
                  		var response = await this.request(token, 'mediaItems:search', 'post', null, data)
        sdetweil @gonzonia
        @gonzonia said in MMM-GooglePhotos:
        that means your network failed… are u using a pihole for connection security?
        seen lots of failures thru pihole…
        G 2 Replies Last reply Reply Quote 0
        • G Offline
          gonzonia @sdetweil
          @sdetweil I do but I thought I’d switched the DNS on there to not use it. Apparently not. This new error was likely the result of the update to pihole v5 (need to figure that out separately). Thanks for pointing me in the right direction!
          • G Offline
            gonzonia @sdetweil
            @sdetweil It’s interesting. I’m seeing this error now instead of the socket disconnected error. I’ve changed the DNS on the MM to not use the pihole (it’s using Google DNS).
            I don’t know why I’m seeing this vs. the other error all of a sudden. I still think it’s hard to blame the network exclusively. I have other modules too that all run fine at the exact same time.
            I’ve tried to figure out how to catch the error but I don’t think I can. From what I can tell it’s making the async call and then while waiting for a response it loses the connection for some reason. I’m not skilled enough to re-write try the async queue method referenced in the github post I linked to previously. I’m just hopeful someone who has the same problem might have the skills to fix it or at least catch it better so that the module doesn’t fail completely. (Meanwhile I’ll keep trying to identify what the problem is).
              sdetweil @gonzonia
              @gonzonia i don’t think the referenced issue is the problem, but there is a bunch of work needed to improve error recovery. I don’t KNOW for sure what the problem IS, but looking at the code there is no recovery from it.
                megagprime
                anybody have any issues with the photos stop changing after a while? i cant figure it out my post
                • soubhik-khanS Offline
                  soubhik-khan
                  I noticed this module is using huge data. Almost downloading more than 3gb/day. My refresh rate is 1.5min per photo. Anyone else noticed this? How can we reduce the data usage? Probably show photos from the cached data instead of downloading every time?
                    sdetweil @soubhik-khan
                    @soubhik-khan I went over the code last month for some not refreshing problem. and it does build and use a local cache.
                    how big are the pictures? and how many are there?
                    at 1 mb each for 960 pics, it could be 1gb in a day
                    soubhik-khanS 1 Reply Last reply Reply Quote 0
                      soubhik-khan @sdetweil
                      @sdetweil yes you are right, I think I found the issue. Its not this module. There is something else on the pi hijacking my bandwidth! its insane ~ 24GB is last 24 hours!
                      I was about the do a clean install but then I thought I will just remove the unused folders first! I guess its from pocketshhinx or sphinxbase, I had installed some of those voice assistant modules! I removed those two folders and looks like now the data usage is back to normal. Will monitor for a day, if this doesnt help, will need to do a clean install
                        celliott
                        I am currently using this module to display one album that has 5 photos in it. I have it set to change the photo every 15 seconds. For some reason once it gets to the 5th photo, it only displays for barely 1 second and then starts from the beginning again. Any suggestions on how to fix this so that the last photo will display as long as the others?
                          sdetweil @celliott
                          @celliott I don’t know for sure but there is debugging info available
                          edit the node_helper.js
                          and add
                                 debug:true,
                          between these two lines
                            start: function()
                          then stop mm, pm2 stop all if using pm2
                          then
                          npm start >somefile.txt
                          wait til u see the error
                          then ctrl-c on the mm terminal window
                          (alt-spacebar, n to.minimize mm screen if you didn’t use ssh)
                          • O Offline
                            orayoflighto Project Sponsor
                            For those just joining, I was able to get this to work using the Google OAuth desktop option and the V2 token generator that hermanho made at the link below
                            https://github.com/aneaville/MMM-GooglePhotos/issues/145
                            M 2 Replies Last reply Reply Quote 1
                              megagprime @orayoflighto
                              @orayoflighto awesome thanks guys but some of us are really dumb and I can’t figure this out. No new get token no matter how hard I try and I don’t know how to do it on my local pc… If I copy the file over I get the following ![alt text](image url)
                                @orayoflighto i tried to do this but i am too dumb, how do i clone on local pc ? and when i do put v2 in folder and node i get this error 9fdb2fe4-798b-4de7-90fd-ea673cdfbd7f-image.png
                                  sdetweil @megagprime
                                  @megagprime to get a pull request
                                  in the existing module folder do
                                  git fetch origin pull/#/head:local_branch_name
                                  replace # w 146
                                  and pick a name for branch name
                                  the when that completes (no message)
                                  do
                                  git checkout whatever name u used
                                  now your photos module is using the pull request version
                                  then the normal instructions should work
                                  edit : shows what u get for not checking and trusting some ‘now old’ post on the internet!
                                    megagprime @sdetweil
                                    @sdetweil admin@raspberrypi:~/MagicMirror/modules/MMM-GooglePhotos $ pull/<145>/head:< g2 >
                                    bash: syntax error near unexpected token `145’
                                      @megagprime no <>
                                      • L Offline
                                        Lilleberg
                                        I have just installed MagicMirror on my RaspberryPi and are now playing around trying to tweak my screen to my needs. Just now I want to show a slideshow of one of my albums in the top region of the screen. I have my screen vertically.
                                        So the photo should show cover the whole top region from edge to edge, and maybe 1/3 down from the top edge. Trying to use the top_bar position, but the photos then are shown with a padding on the left side and in the top, and are not resized to fit inside the region. Anybody that can show how this can be done? Maybe in the css file?
                                          bhepler Module Developer @Lilleberg
                                          @Lilleberg Try using the upper_third position for your pictures. That may be closer to what you want.
                                          • 1 Offline
                                            1a2a3a
                                            hi, does anyone know how to configure the sizing of the gphoto?
                                            im trying to make the photo not full screen, but to perhaps just the top portion of the mirror or to some size of the mirror (havent really decided on the location) but having trouble sizing them.
                                            i changed the showWidth and showHeight but while they make the picture smaller, the quality seems to be reduce?
                                            i have also added #GPHOTO in CSS with width and height at 50% but it still feel like its showing full screen…
                                            • 11
                                            • 12
                                            • 13
                                            • 14
                                            • 15
                                            • 14 / 15
