    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 175.1k Views 19 Watching
      sdetweil @JJW
      @jjw what folder are u supposed to be in when u run that command?
        JJW @sdetweil
        @sdetweil Unfortunately it doesn’t say so I’ve just tried running in and out of the Fitbit directory.
        https://github.com/m-roberts/MMM-Fitbit2
        redirects you to this webpage
        https://pypi.org/project/fitbit/0.3.1/
        and I can’t see anywhere it says what folder to install it into.
        • V
          Vizulize Module Developer @JJW
          @jjw Running init.sh inside the MMM-Fitbit2 folder should take care of installing the dependencies for you.
            JJW @Vizulize
            @vizulize I’ve done that, unfortunately still just have loading.
              Dresch360 Project Sponsor
              Entered all of the required information in the Fitbit application registry.
              At the ./auth.sh process, entered correct “Client ID” and “Client Secret” and I get the following after Allowing full access during authentication process:
              **Fitbit
              The app you’re trying to connect did not provide valid information to Fitbit. Please report this issue to them.
              Developer information: invalid_request - Missing parameters: client_id**
              Any help would be greatly appreciated!
                Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
                404 Not Found
                Missing parameters: state
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
                return self.callable(*self.args, **self.kwargs)
                TypeError: index() missing 1 required positional argument: ‘state’
                During handling of the above exception, another exception occurred:
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
                self._do_respond(path_info)
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
                response.body = self.handler()
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
                self.body = self.oldhandler(*args, **kwargs)
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
                raise sys.exc_info()[1]
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
                test_callable_spec(self.callable, self.args, self.kwargs)
                File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
                raise cherrypy.HTTPError(404, message=message)
                cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
                  sdetweil @Dresch360
                  @dresch360 looks like something changed in the api requirements, but the library version hasnt
                    @sdetweil - Thanks for your reply. So does this mean that no new tokens can be created?
                      richmp95
                      any chance of this being revived and updated?
                      S V 2 Replies Last reply Reply Quote 0
                        sdetweil @richmp95
                        @richmp95 you’d have to post in an issue in the module GitHub repo
                        • V
                          Vizulize Module Developer @richmp95
                          @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
                          If you would like to have extra features, I am open to suggestions and contributions.
                          • L
                            Layton
                            Is there anyway to remove the goal tracking widget underneath each resource?
                            I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
                            Any ideas!?
                            • V
                              Vizulize Module Developer @Layton
                              @Layton
                              I haven’t tried this and I haven’t looked at the code in a while, but I think you can just comment out this line to hide the progress bars:
                              https://github.com/m-roberts/MMM-Fitbit2/blob/430d35056ceecfe612476a7d0307903b376ed6c0/MMM-Fitbit2.js#L242
                              • L
                                Layton @Vizulize
                                @Vizulize That worked! Thank you :)
                                  richmp95 @Vizulize
                                  @Vizulize i am still having issues with this module. all it says is loading. any help with this i would appreciate it
                                  • V
                                    @richmp95 I’m afraid I can’t do much to help without error logs.
                                    • MeidlmarkusM
                                      Meidlmarkus
                                      Hi, updated MM and now Google-Fit can no longer be installed, so I gave MMM-Fitbit2 a go.
                                      Thanks @Vizulize for your work, I’d really like to get it running.
                                      I have the same error that is reported in the github:
                                      npm ERR! must provide string spec
                                      To reproduce, just try to install it on an updated MM system.
                                      It happens when calling ./init.sh as per your instructions on github
                                      Have you/has anybody figured out a way to initialize the module?
                                      Markus
                                        sdetweil @Meidlmarkus
                                        @Meidlmarkus said in MMM-Fitbit2:
                                        MMM-Fitbit2
                                        remove these lines from package.json
                                              "Requires this version to work",
                                              "https://github.com/SVendittelli/MMM-fitbit/issues/23#issuecomment-464319931"
                                        • MeidlmarkusM
                                          Meidlmarkus
                                          Thanks, Sam!
                                          Had it googled in the meantime, had renamed the package-lock.json und run npm init
                                          It braught no further error, I called auth.sh and that’s where I’m stuck now.
                                          After entering the credentials, no browser dialog opens and I’m not quite sure where to search it.
                                          Am logged in over ssh and in addition have a browser open to :8080
                                          Neither on the mirror, nor on the pc, there is any dialog appearing.
                                          I guess I’ll start from scratch, remove the module folder, clone new from git, and try your suggested method with the original package.json?
                                          Thanks again
                                          Markus
                                            @Meidlmarkus yeh, can’t help on the auth part
                                            MeidlmarkusM 1 Reply Last reply Reply Quote 0
                                            • 5 / 5
