    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 175.1k Views 19 Watching
      Dresch360 Project Sponsor
      Entered all of the required information in the Fitbit application registry.
      At the ./auth.sh process, entered correct “Client ID” and “Client Secret” and I get the following after Allowing full access during authentication process:
      **Fitbit
      The app you’re trying to connect did not provide valid information to Fitbit. Please report this issue to them.
      Developer information: invalid_request - Missing parameters: client_id**
      Any help would be greatly appreciated!
        Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
        404 Not Found
        Missing parameters: state
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
        return self.callable(*self.args, **self.kwargs)
        TypeError: index() missing 1 required positional argument: ‘state’
        During handling of the above exception, another exception occurred:
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
        self._do_respond(path_info)
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
        response.body = self.handler()
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
        self.body = self.oldhandler(*args, **kwargs)
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
        raise sys.exc_info()[1]
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
        test_callable_spec(self.callable, self.args, self.kwargs)
        File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
        raise cherrypy.HTTPError(404, message=message)
        cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
          sdetweil @Dresch360
          @dresch360 looks like something changed in the api requirements, but the library version hasnt
            @sdetweil - Thanks for your reply. So does this mean that no new tokens can be created?
              richmp95
              any chance of this being revived and updated?
              S V 2 Replies Last reply Reply Quote 0
                sdetweil @richmp95
                @richmp95 you’d have to post in an issue in the module GitHub repo
                • V
                  Vizulize Module Developer @richmp95
                  @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
                  If you would like to have extra features, I am open to suggestions and contributions.
                  • L
                    Layton
                    Is there anyway to remove the goal tracking widget underneath each resource?
                    I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
                    Any ideas!?
                    • V
                      Vizulize Module Developer @Layton
                      @Layton
                      I haven’t tried this and I haven’t looked at the code in a while, but I think you can just comment out this line to hide the progress bars:
                      https://github.com/m-roberts/MMM-Fitbit2/blob/430d35056ceecfe612476a7d0307903b376ed6c0/MMM-Fitbit2.js#L242
                      • L
                        Layton @Vizulize
                        @Vizulize That worked! Thank you :)
                          richmp95 @Vizulize
                          @Vizulize i am still having issues with this module. all it says is loading. any help with this i would appreciate it
                          • V
                            @richmp95 I’m afraid I can’t do much to help without error logs.
                            • MeidlmarkusM
                              Meidlmarkus
                              Hi, updated MM and now Google-Fit can no longer be installed, so I gave MMM-Fitbit2 a go.
                              Thanks @Vizulize for your work, I’d really like to get it running.
                              I have the same error that is reported in the github:
                              npm ERR! must provide string spec
                              To reproduce, just try to install it on an updated MM system.
                              It happens when calling ./init.sh as per your instructions on github
                              Have you/has anybody figured out a way to initialize the module?
                              Markus
                                sdetweil @Meidlmarkus
                                @Meidlmarkus said in MMM-Fitbit2:
                                MMM-Fitbit2
                                remove these lines from package.json
                                      "Requires this version to work",
                                      "https://github.com/SVendittelli/MMM-fitbit/issues/23#issuecomment-464319931"
                                • MeidlmarkusM
                                  Meidlmarkus
                                  Thanks, Sam!
                                  Had it googled in the meantime, had renamed the package-lock.json und run npm init
                                  It braught no further error, I called auth.sh and that’s where I’m stuck now.
                                  After entering the credentials, no browser dialog opens and I’m not quite sure where to search it.
                                  Am logged in over ssh and in addition have a browser open to :8080
                                  Neither on the mirror, nor on the pc, there is any dialog appearing.
                                  I guess I’ll start from scratch, remove the module folder, clone new from git, and try your suggested method with the original package.json?
                                  Thanks again
                                  Markus
                                    @Meidlmarkus yeh, can’t help on the auth part
                                    MeidlmarkusM 1 Reply Last reply Reply Quote 0
                                    • MeidlmarkusM
                                      Meidlmarkus @sdetweil
                                      @sdetweil yeah, so I renamed MMM-Fitbit2, cloned fresh.
                                      In the package.json there is no such a line that you mentioned (I guess @Vizulize must have fixed it already)
                                      Did npm init, then ./init seemingly went through.
                                      With ./auth.sh same thing as before - no dialog showing up.
                                      I hope @Vizulize sees it and helps out :-)
                                      Markus
                                        @Meidlmarkus I just checked again
                                        still has those lines
                                        don’t see another author choice in google search
                                        • MeidlmarkusM
                                          Meidlmarkus
                                          Yes, right.
                                          Must have looked into the package.json after doing the npm init - my bad. Did another git clone and it is as you said.
                                          Meanwhile it turned out I had pip not installed. After installing pip and running ./init.sh again (after npm init) libraries were installed, and also auth.sh was able to start (only saw it when I called the python script directly rather than from auth.sh)
                                          So auth.sh was now able to “Open a Web browser” (at least according to its logs), I just don’t see any dialog.
                                          Anyway, will now try init with the modified package.json and see if it makes a difference - will report back.
                                          Thanks so far
                                          Markus
                                          • MeidlmarkusM
                                            Meidlmarkus
                                            So, quick update:
                                            I tried inist.sh with the modified package.json
                                            The result was just the same - I don’t see any input dialog open.
                                            I believe the module is installed properly and the dependencies are ok.
                                            Markus
                                            • 5 / 5
