    MMM-Fitbit2
    Scheduled Pinned Locked Moved Health
    fitbithealthfitnesshealthywaterfoodtrackingactivity tracker
    98 Posts 21 Posters 177.1k Views 19 Watching
      Dresch360 Project Sponsor
      Also - attempted to authorize and obtain token directly from the Fitbit site using their token authenticator from the “OAuth 2.0 tutorial page” and I received the error message below:
      404 Not Found
      Missing parameters: state
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 54, in call
      return self.callable(*self.args, **self.kwargs)
      TypeError: index() missing 1 required positional argument: ‘state’
      During handling of the above exception, another exception occurred:
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 628, in respond
      self._do_respond(path_info)
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cprequest.py”, line 687, in _do_respond
      response.body = self.handler()
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/lib/encoding.py”, line 219, in call
      self.body = self.oldhandler(*args, **kwargs)
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 60, in call
      raise sys.exc_info()[1]
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 58, in call
      test_callable_spec(self.callable, self.args, self.kwargs)
      File “/usr/local/lib/python3.7/dist-packages/cherrypy/_cpdispatch.py”, line 157, in test_callable_spec
      raise cherrypy.HTTPError(404, message=message)
      cherrypy._cperror.HTTPError: (404, ‘Missing parameters: state’)
        sdetweil @Dresch360
        @dresch360 looks like something changed in the api requirements, but the library version hasnt
          @sdetweil - Thanks for your reply. So does this mean that no new tokens can be created?
            richmp95
            any chance of this being revived and updated?
            S V 2 Replies Last reply
              sdetweil @richmp95
              @richmp95 you’d have to post in an issue in the module GitHub repo
              • V
                Vizulize Module Developer @richmp95
                @richmp95 - last I checked, this still works. Why does it need ‘reviving’?
                If you would like to have extra features, I am open to suggestions and contributions.
                R 1 Reply Last reply
                • L
                  Layton
                  Is there anyway to remove the goal tracking widget underneath each resource?
                  I have been trying to play around with removing it myself, but every time I touch something it breaks the whole module.
                  Any ideas!?
                  V 1 Reply Last reply
                  • V
                    Vizulize Module Developer @Layton
                    @Layton
                    I haven’t tried this and I haven’t looked at the code in a while, but I think you can just comment out this line to hide the progress bars:
                    https://github.com/m-roberts/MMM-Fitbit2/blob/430d35056ceecfe612476a7d0307903b376ed6c0/MMM-Fitbit2.js#L242
                    L 1 Reply Last reply
                    • L
                      Layton @Vizulize
                      @Vizulize That worked! Thank you :)
                        richmp95 @Vizulize
                        @Vizulize i am still having issues with this module. all it says is loading. any help with this i would appreciate it
                        • V
                          @richmp95 I’m afraid I can’t do much to help without error logs.
                          • MeidlmarkusM
                            Meidlmarkus
                            Hi, updated MM and now Google-Fit can no longer be installed, so I gave MMM-Fitbit2 a go.
                            Thanks @Vizulize for your work, I’d really like to get it running.
                            I have the same error that is reported in the github:
                            npm ERR! must provide string spec
                            To reproduce, just try to install it on an updated MM system.
                            It happens when calling ./init.sh as per your instructions on github
                            Have you/has anybody figured out a way to initialize the module?
                            Markus
                              sdetweil @Meidlmarkus
                              @Meidlmarkus said in MMM-Fitbit2:
                              MMM-Fitbit2
                              remove these lines from package.json
                                    "Requires this version to work",
                                    "https://github.com/SVendittelli/MMM-fitbit/issues/23#issuecomment-464319931"
                              • MeidlmarkusM
                                Meidlmarkus
                                Thanks, Sam!
                                Had it googled in the meantime, had renamed the package-lock.json und run npm init
                                It braught no further error, I called auth.sh and that’s where I’m stuck now.
                                After entering the credentials, no browser dialog opens and I’m not quite sure where to search it.
                                Am logged in over ssh and in addition have a browser open to :8080
                                Neither on the mirror, nor on the pc, there is any dialog appearing.
                                I guess I’ll start from scratch, remove the module folder, clone new from git, and try your suggested method with the original package.json?
                                Thanks again
                                Markus
                                  @Meidlmarkus yeh, can’t help on the auth part
                                  MeidlmarkusM 1 Reply Last reply
                                  • MeidlmarkusM
                                    Meidlmarkus @sdetweil
                                    @sdetweil yeah, so I renamed MMM-Fitbit2, cloned fresh.
                                    In the package.json there is no such a line that you mentioned (I guess @Vizulize must have fixed it already)
                                    Did npm init, then ./init seemingly went through.
                                    With ./auth.sh same thing as before - no dialog showing up.
                                    I hope @Vizulize sees it and helps out :-)
                                    Markus
                                      @Meidlmarkus I just checked again
                                      still has those lines
                                      don’t see another author choice in google search
                                      • MeidlmarkusM
                                        Meidlmarkus
                                        Yes, right.
                                        Must have looked into the package.json after doing the npm init - my bad. Did another git clone and it is as you said.
                                        Meanwhile it turned out I had pip not installed. After installing pip and running ./init.sh again (after npm init) libraries were installed, and also auth.sh was able to start (only saw it when I called the python script directly rather than from auth.sh)
                                        So auth.sh was now able to “Open a Web browser” (at least according to its logs), I just don’t see any dialog.
                                        Anyway, will now try init with the modified package.json and see if it makes a difference - will report back.
                                        Thanks so far
                                        Markus
                                        • MeidlmarkusM
                                          Meidlmarkus
                                          So, quick update:
                                          I tried inist.sh with the modified package.json
                                          The result was just the same - I don’t see any input dialog open.
                                          I believe the module is installed properly and the dependencies are ok.
                                          Markus
                                          • V
                                            Vizulize Module Developer @Meidlmarkus
                                            @Meidlmarkus It’s been a while since I worked on this. From memory, doing this over SSH has extra complexity (probably to do with the DISPLAY environment variable). Honestly, I’ve wanted to rework this to be headless for a while but haven’t had the capacity to do so.
                                            My advice would be to try and run it locally if possible.
                                            Also if anyone can verify that the modification to package.json is a fix, then I will merge this in: https://github.com/m-roberts/MMM-Fitbit2/pull/10/files
                                            • 5 / 5
