    [ERROR] Moment Timezone has no data for Customized Time Zone
    4 Posts 2 Posters 1.3k Views 2 Watching
    • spitzlbergerjS
      spitzlbergerj Project Sponsor Module Developer
      I just updated to 2.19.0 and since then the logfile is flooded every 10th of a second with the above error messages.
      how can I stop these errors?
      I have already read this thread . Does this also apply to version 2.19.0 @sdetweil ?
      Thanks in advance
      Greetings
      Sepp
      Regards
      Josef
      http://www.spitzlberger.de/smartmirror, https://github.com/spitzlbergerj/MMM-TeslaLogger, https://github.com/spitzlbergerj/CaravanPi, https://www.la-gondola-barocca.de
        sdetweil @spitzlbergerj
        @spitzlbergerj no way to stop them unfortunately. a lower library is emitting the error cause the timezone value is unexpected.
        this is usually caused by a Microsoft 365 calendar where they create custom timezones which none else in the world uses.
        spitzlbergerjS 1 Reply Last reply Reply Quote 0
        • spitzlbergerjS
          spitzlbergerj Project Sponsor Module Developer @sdetweil
          Thanks a lot @sdetweil
          ok, then i have to erase the log files often, so that the file system doesn’t crash … :-)
          Regards
          Josef
            @spitzlbergerj the errors should only be when we fetch the ics file, once every 10 or 15 minutes (for each such entry to process)
