    MagicMirror v2.1.0 Update error
    31 Posts 12 Posters 26.6k Views 12 Watching
    • lolobyteL Offline
      lolobyte
      How can i fix that?
      pi@raspi3-MM2:~/MagicMirror $ sudo git pull
      Aktualisiere b8167f8…8010e62
      error: Your local changes to the following files would be overwritten by merge:
      css/main.css
      modules/default/clock/clock.js
      modules/default/compliments/compliments.js
      modules/default/currentweather/currentweather.css
      modules/default/currentweather/currentweather.js
      package.json
      Please, commit your changes or stash them before you can merge.
      Aborting
      • yawnsY Offline
        yawns Moderator
        So you modified the original files which you should not do.
        Look at the first answer here to see your possibilities: http://stackoverflow.com/questions/15745045/how-do-i-resolve-git-saying-commit-your-changes-or-stash-them-before-you-can-me
        lolobyteL schlachtkreuzer6S 2 Replies Last reply Reply Quote 0
        • lolobyteL Offline
          lolobyte @yawns
          @yawns
          Thank u.
          Now i have this error!
          npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
          • lolobyteL Offline
            lolobyte
            I can’t insert my ip from my laptop.
            I want to access MagicMirror from laptop with Remote Control, but it’s not possible now with this update.
            Where i have to insert my ip address in the white-list?
              PindaPower
              If the original this is:
              Blockquote ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”],
              Then I guess that the modifed can look like this:
              Blockquote ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “192.168.0.1”, “192.168.250.250”],
              If you dont get the “::ffff:127.0.0.1” lookup “ipv4 to ipv6 translation” on google.
              lolobyteL 1 Reply Last reply Reply Quote 0
              • lolobyteL Offline
                lolobyte @PindaPower
                @PindaPower
                at this position i must insert my ip from the notebook?
                ipWhitelist: [“127.0.0.1”, “::ffff:127.0.0.1”, “::1”, “XXX.XXX.XXX.XXX”, “192.168.250.250”],
                And how to declare a range?
                • lolobyteL Offline
                  lolobyte
                  nobody can help.
                  I going to be crazy soon with this damn IP’s
                  Can somebody put a example of a running ip address with a virtual IP like 192.168.123.123 to give access to remote control module ?
                  • SnilleS Offline
                    Snille Module Developer
                    This should do it. :)
                    For a B-network (192.168.x.x)
                    The last two “x”:es change.
                    ipWhitelist: [
                    	"127.0.0.1",
                    	"::ffff:127.0.0.1",
                    	"::1",
                    	"::ffff:192.168.0.1/16"
                    Or for a C-network (192.168.123.x)
                    Only the last “x” change.
                    ipWhitelist: [
                    	"127.0.0.1",
                    	"::ffff:127.0.0.1",
                    	"::1",
                    	"::ffff:192.168.123.1/24"
                    Good luck. :)
                    If you cant find it, make it and share it!
                    Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                    • SteffS Offline
                      Steff
                      • schlachtkreuzer6S Offline
                        schlachtkreuzer6 @yawns
                        @yawns so how do i change the comments if i should´t change the comments.js ? ^^
                        • 1 / 4
