Calendar does not appear
Hey everyone,
I’m trying to fix an issue with my outlook calendar.
I’ve got the.icslink and put it into theconfig.js, everything fine.But when I start the mirror it only says:
Loading...Other
.ics(google, holidays…) works fine for me, it’s only this one that refuses.Is there any known problem with the outlook-calendar?
Thanks,
ehNorm -
Can you check the console output, see if it’s throwing an error?
Hey,
sorry what do you mean by checking the console output?
When should I check it and how?Many thanks!
Okay, I didn’t use pm2 but I installed it and I added the log files.
I can’t see any error for the calendar…
Rather then opening the log files in an editor (nano), can you just run
'pm2 logs <YOUR_PROCESS_NAME>'then highlight and paste what you see into a new post (with the proper markdown)? It’s a bit hard to decipher what’s being shown in that text file you uploaded. -
Kalender-0 (out): No helper found for module: alert. Kalender-0 (out): No helper found for module: clock. Kalender-0 (out): Initializing new module helper ... Kalender-0 (out): No helper found for module: currentweather. Kalender-0 (out): No helper found for module: weatherforecast. Kalender-0 (out): Initializing new module helper ... Kalender-0 (out): All module helpers loaded. Kalender-0 (out): Starting server op port 8080 ... Kalender-0 (out): Server started ... Kalender-0 (out): Connecting socket for: calendar Kalender-0 (out): Starting node helper for: calendar Kalender-0 (out): Connecting socket for: newsfeed Kalender-0 (out): Starting module: newsfeed Kalender-0 (out): Sockets connected & modules started ... Kalender-0 (out): Launching application. Kalender-0 (out): Create new calendar fetcher for url: webcals://sharing.calendar.live.com/calendar/private/SOME-NUMBERS/calendar.ics - Interval: 300000 Kalender-0 (out): Create new news fetcher for url: http://feeds.feedburner.com/blogspot/rkEL - Interval: 300000 Kalender-0 (out): Whoops! There was an uncaught exception... Kalender-0 (out): MagicMirror will not quit, but it might be a good idea to chec k why this happened. Maybe no internet connection? Kalender-0 (out): If you think this really is an issue, please open an issue on GitHub: https://github.com/MichMich/MagicMirror/issues Kalender-0 (err): { [Error: listen EADDRINUSE :::8080] Kalender-0 (err): code: 'EADDRINUSE', Kalender-0 (err): errno: 'EADDRINUSE', Kalender-0 (err): syscall: 'listen', Kalender-0 (err): address: '::', Kalender-0 (err): port: 8080 } Kalender-0 (err): /usr/bin/unclutter: someone created a sub-window to my sub-win dow! giving up Kalender-0 (err): /usr/bin/unclutter: someone created a sub-window to my sub-win dow! giving up Kalender-0 (err): X Error of failed request: BadWindow (invalid Window paramete r) Kalender-0 (err): Major opcode of failed request: 20 (X_GetProperty) Kalender-0 (err): Resource id in failed request: 0x2000001 Kalender-0 (err): Serial number of failed request: 46 Kalender-0 (err): Current serial number in output stream: 46 Kalender-0 (err): { [Error: getaddrinfo EAI_AGAIN feeds.feedburner.com:80] Kalender-0 (err): code: 'EAI_AGAIN', Kalender-0 (err): errno: 'EAI_AGAIN', Kalender-0 (err): syscall: 'getaddrinfo', Kalender-0 (err): hostname: 'feeds.feedburner.com', Kalender-0 (err): host: 'feeds.feedburner.com', Kalender-0 (err): port: 80 }That way?
Note from admin: Please use Markdown on code and shell output snippets so it is easier to read!
