    Calendar does not appear
    7 Posts 3 Posters 3.5k Views 2 Watching
    • E Offline
      ehNorm
      Hey everyone,
      I’m trying to fix an issue with my outlook calendar.
      I’ve got the .ics link and put it into the config.js, everything fine.
      But when I start the mirror it only says:
      Loading...
      Other .ics (google, holidays…) works fine for me, it’s only this one that refuses.
      Is there any known problem with the outlook-calendar?
      Thanks,
      ehNorm
      • KirAsh4K Offline
        KirAsh4 Moderator
        Can you check the console output, see if it’s throwing an error?
        • E Offline
          ehNorm
          Hey,
          sorry what do you mean by checking the console output?
          When should I check it and how?
          Many thanks!
            jtyle6 @ehNorm
            @ehNorm
            It’s all right here.
            • E Offline
              ehNorm
              Okay, I didn’t use pm2 but I installed it and I added the log files.
              I can’t see any error for the calendar…
              0_1463996547833_pm2 info.txt
              • KirAsh4K Offline
                KirAsh4 Moderator
                Rather then opening the log files in an editor (nano), can you just run 'pm2 logs <YOUR_PROCESS_NAME>' then highlight and paste what you see into a new post (with the proper markdown)? It’s a bit hard to decipher what’s being shown in that text file you uploaded.
                • E Offline
                  ehNorm
                  Kalender-0 (out): No helper found for module: alert.
                  Kalender-0 (out): No helper found for module: clock.
                  Kalender-0 (out): Initializing new module helper ...
                  Kalender-0 (out): No helper found for module: currentweather.
                  Kalender-0 (out): No helper found for module: weatherforecast.
                  Kalender-0 (out): All module helpers loaded.
                  Kalender-0 (out): Starting server op port 8080 ...
                  Kalender-0 (out): Server started ...
                  Kalender-0 (out): Connecting socket for: calendar
                  Kalender-0 (out): Starting node helper for: calendar
                  Kalender-0 (out): Connecting socket for: newsfeed
                  Kalender-0 (out): Starting module: newsfeed
                  Kalender-0 (out): Sockets connected & modules started ...
                  Kalender-0 (out): Launching application.
                  Kalender-0 (out): Create new calendar fetcher for url: webcals://sharing.calendar.live.com/calendar/private/SOME-NUMBERS/calendar.ics - Interval: 300000
                  Kalender-0 (out): Create new news fetcher for url: http://feeds.feedburner.com/blogspot/rkEL - Interval: 300000
                  Kalender-0 (out): Whoops! There was an uncaught exception...
                  Kalender-0 (out): MagicMirror will not quit, but it might be a good idea to chec        k why this happened. Maybe no internet connection?
                  Kalender-0 (out): If you think this really is an issue, please open an issue on        GitHub: https://github.com/MichMich/MagicMirror/issues
                  Kalender-0 (err): { [Error: listen EADDRINUSE :::8080]
                  Kalender-0 (err):   code: 'EADDRINUSE',
                  Kalender-0 (err):   errno: 'EADDRINUSE',
                  Kalender-0 (err):   syscall: 'listen',
                  Kalender-0 (err):   address: '::',
                  Kalender-0 (err):   port: 8080 }
                  Kalender-0 (err): /usr/bin/unclutter: someone created a sub-window to my sub-win        dow! giving up
                  Kalender-0 (err): X Error of failed request:  BadWindow (invalid Window paramete        r)
                  Kalender-0 (err):   Major opcode of failed request:  20 (X_GetProperty)
                  Kalender-0 (err):   Resource id in failed request:  0x2000001
                  Kalender-0 (err):   Serial number of failed request:  46
                  Kalender-0 (err):   Current serial number in output stream:  46
                  Kalender-0 (err): { [Error: getaddrinfo EAI_AGAIN feeds.feedburner.com:80]
                  Kalender-0 (err):   code: 'EAI_AGAIN',
                  Kalender-0 (err):   errno: 'EAI_AGAIN',
                  Kalender-0 (err):   syscall: 'getaddrinfo',
                  Kalender-0 (err):   hostname: 'feeds.feedburner.com',
                  Kalender-0 (err):   host: 'feeds.feedburner.com',
                  Kalender-0 (err):   port: 80 }
                  That way?
                  Note from admin: Please use Markdown on code and shell output snippets so it is easier to read!
