    Screen/Text Size
    17 Posts 2 Posters 3.6k Views 2 Watching
      mrdger @sdetweil
      Followed your instructions again. This came up. The repeated forecast doesn’t seem to change, but the two bigger texts were popping up and changing.
        sdetweil @mrdger
        @mrdger weird…
        did u get any output from the command? should not have
        I assume you had a good desktop after boot… with the temples…
        how did you install MM? manual or scripted?
          mrdger @sdetweil
          @sdetweil Correct, didn’t get any output. I did it manually, maybe try reinstalling?
            sdetweil @mrdger
            @mrdger rename the MM folder
            cd  ~
            mv MagicMirror MagicMirror.old
            then run my install script , see
              mrdger @sdetweil
              Completed the steps you outlined. Moved the directory and then ran the install script your provided. Looks like a similar problem is still popping up. The 2nd image is fullscreen screenshot with the 1st showing an example of how it changes if the size of the window is changed.
              Here’s the log from the installers folder
              pm2 setup starting - Tue May 17 12:21:58 EDT 2022
              using parameter bash
              system is Linux raspberrypi 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux
              the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
              node version v16.5.0
              force installing latest npm version via npm
              npm version 8.10.0
              pm2 installed
              get the pm2 platform specific startup command
              startup command = sudo env PATH=$PATH:/usr/local/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
              [PM2] Init System found: systemd
              Platform systemd
              Template
              [Unit]
              Description=PM2 process manager
              Documentation=https://pm2.keymetrics.io/
              After=network.target
              [Service]
              Type=forking
              User=pi
              LimitNOFILE=infinity
              LimitNPROC=infinity
              LimitCORE=infinity
              Environment=PATH=$PATH:/usr/local/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
              Environment=PM2_HOME=/home/pi/.pm2
              PIDFile=/home/pi/.pm2/pm2.pid
              Restart=on-failure
              ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
              ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
              ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
              [Install]
              WantedBy=multi-user.target
              Target path
              /etc/systemd/system/pm2-pi.service
              Command list
              [ ‘systemctl enable pm2-pi’ ]
              [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
              [PM2] Making script booting at startup…
              Executing: systemctl enable pm2-pi…
              [PM2] [v] Command successfully executed.
              [PM2] Freeze a process list on reboot via:
              $ pm2 save
              [PM2] Remove init script via:
              $ pm2 unstartup systemd
              pm2 startup command done
              configure the pm2 config file for MagicMirror
              start MagicMirror via pm2 now
              save MagicMirror pm2 config now
              pm2 setup completed - Tue May 17 12:22:06 EDT 2022
                sdetweil @mrdger
                @mrdger strange…
                ok, my guess is a bad cable from pi to display
                I had seen some flakiness on DVI-D display with an hdmi->DVI adapter…
                a different adapter had no trouble with the same cable
                  @mrdger did you setup for autostart using the manual procedure?
                  pm2 replaces that… so you should dlete that setup if you did it… (as it looks like with 2 autostarts)
                    mrdger @sdetweil
                    @sdetweil It is on a hdmi to dvi adapter, but I actually have a different cable arriving today, so I’ll attempt again after it gets here. Thank you for all your help so far. The autostart feature asked be during the install if I wanted to use it, a y/N option, and I selected y. Should I change anything about that?
                      sdetweil @mrdger
                      @mrdger no… I was only asking about what you did on the manual install
                      my script does PM2.
                        mrdger @sdetweil
                        @sdetweil Got it, I don’t believe it was setup. It wasn’t starting after reboot or after closing the window.
                          sdetweil @mrdger
                          @mrdger ok
