    Screen/Text Size
    17 Posts 2 Posters 3.2k Views 2 Watching
      mrdger @sdetweil
      @sdetweil Thanks for the response. Yes I do want it full screen, my apologies, I just meant that it wasn’t displaying properly when in full screen.
      I followed your instructions, and this is what I am currently getting
        sdetweil @mrdger
        @mrdger what OS is this? on what hardware? PI? is that view on the screen attached to hardware, or over VNC?
        can u do, from the commandline while MM is running
        ps -ef | grep -i magicmirror
        you should get a list of things…
          mrdger @sdetweil
          @sdetweil The screen is attached to the hardware and is intended to be the screen I will be using for the project. It’s a Pi 4
            sdetweil @mrdger
            @mrdger ok, stop MagicMirror again
            and then do
            rm -rf ~/.config/Electron
            then restart mm
              mrdger @sdetweil
              Followed your instructions again. This came up. The repeated forecast doesn’t seem to change, but the two bigger texts were popping up and changing.
                sdetweil @mrdger
                @mrdger weird…
                did u get any output from the command? should not have
                I assume you had a good desktop after boot… with the temples…
                how did you install MM? manual or scripted?
                  mrdger @sdetweil
                  @sdetweil Correct, didn’t get any output. I did it manually, maybe try reinstalling?
                    sdetweil @mrdger
                    @mrdger rename the MM folder
                    cd  ~
                    mv MagicMirror MagicMirror.old
                    then run my install script , see
                      mrdger @sdetweil
                      Completed the steps you outlined. Moved the directory and then ran the install script your provided. Looks like a similar problem is still popping up. The 2nd image is fullscreen screenshot with the 1st showing an example of how it changes if the size of the window is changed.
                      Here’s the log from the installers folder
                      pm2 setup starting - Tue May 17 12:21:58 EDT 2022
                      using parameter bash
                      system is Linux raspberrypi 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux
                      the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                      node version v16.5.0
                      force installing latest npm version via npm
                      npm version 8.10.0
                      pm2 installed
                      get the pm2 platform specific startup command
                      startup command = sudo env PATH=$PATH:/usr/local/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                      [PM2] Init System found: systemd
                      Platform systemd
                      Template
                      [Unit]
                      Description=PM2 process manager
                      Documentation=https://pm2.keymetrics.io/
                      After=network.target
                      [Service]
                      Type=forking
                      User=pi
                      LimitNOFILE=infinity
                      LimitNPROC=infinity
                      LimitCORE=infinity
                      Environment=PATH=$PATH:/usr/local/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                      Environment=PM2_HOME=/home/pi/.pm2
                      PIDFile=/home/pi/.pm2/pm2.pid
                      Restart=on-failure
                      ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
                      ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
                      ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
                      [Install]
                      WantedBy=multi-user.target
                      Target path
                      /etc/systemd/system/pm2-pi.service
                      Command list
                      [ ‘systemctl enable pm2-pi’ ]
                      [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                      [PM2] Making script booting at startup…
                      Executing: systemctl enable pm2-pi…
                      [PM2] [v] Command successfully executed.
                      [PM2] Freeze a process list on reboot via:
                      $ pm2 save
                      [PM2] Remove init script via:
                      $ pm2 unstartup systemd
                      pm2 startup command done
                      configure the pm2 config file for MagicMirror
                      start MagicMirror via pm2 now
                      save MagicMirror pm2 config now
                      pm2 setup completed - Tue May 17 12:22:06 EDT 2022
                        sdetweil @mrdger
                        @mrdger strange…
                        ok, my guess is a bad cable from pi to display
                        I had seen some flakiness on DVI-D display with an hdmi->DVI adapter…
                        a different adapter had no trouble with the same cable
