    Screen/Text Size
    17 Posts 2 Posters 3.6k Views 2 Watching
      mrdger
      New to the project, and a beginner with coding.
      When I start MM, it goes full screen, but shows the same thing in each location, and it is cut off as the text is displaying too large. If I hit F11 and resize the window, I start to see the text at a more normal size and can finally see more than one module, but still doesn’t display as intended.
      How do I get it to show at full screen with the right dimensions when I start it?
        sdetweil @mrdger
        @mrdger sorry, not quite sure I understand
        said it goes full screen, yes that is what its supposed to do
        eh? what does that mean? if its full screen then what is location?
        try this , maybe,
        stop magicMirror
        cd ~
        rm -rf .config/electron
        note the . in front of config
        restart MagicMirror
          mrdger @sdetweil
          @sdetweil Thanks for the response. Yes I do want it full screen, my apologies, I just meant that it wasn’t displaying properly when in full screen.
          I followed your instructions, and this is what I am currently getting
            sdetweil @mrdger
            @mrdger what OS is this? on what hardware? PI? is that view on the screen attached to hardware, or over VNC?
            can u do, from the commandline while MM is running
            ps -ef | grep -i magicmirror
            you should get a list of things…
              mrdger @sdetweil
              @sdetweil The screen is attached to the hardware and is intended to be the screen I will be using for the project. It’s a Pi 4
                sdetweil @mrdger
                @mrdger ok, stop MagicMirror again
                and then do
                rm -rf ~/.config/Electron
                then restart mm
                  mrdger @sdetweil
                  Followed your instructions again. This came up. The repeated forecast doesn’t seem to change, but the two bigger texts were popping up and changing.
                    sdetweil @mrdger
                    @mrdger weird…
                    did u get any output from the command? should not have
                    I assume you had a good desktop after boot… with the temples…
                    how did you install MM? manual or scripted?
                      mrdger @sdetweil
                      @sdetweil Correct, didn’t get any output. I did it manually, maybe try reinstalling?
                        sdetweil @mrdger
                        @mrdger rename the MM folder
                        cd  ~
                        mv MagicMirror MagicMirror.old
                        then run my install script , see
                          mrdger @sdetweil
                          Completed the steps you outlined. Moved the directory and then ran the install script your provided. Looks like a similar problem is still popping up. The 2nd image is fullscreen screenshot with the 1st showing an example of how it changes if the size of the window is changed.
                          Here’s the log from the installers folder
                          pm2 setup starting - Tue May 17 12:21:58 EDT 2022
                          using parameter bash
                          system is Linux raspberrypi 5.4.83-v7l+ #1379 SMP Mon Dec 14 13:11:54 GMT 2020 armv7l GNU/Linux
                          the os is Distributor ID: Raspbian Description: Raspbian GNU/Linux 10 (buster) Release: 10 Codename: buster
                          node version v16.5.0
                          force installing latest npm version via npm
                          npm version 8.10.0
                          pm2 installed
                          get the pm2 platform specific startup command
                          startup command = sudo env PATH=$PATH:/usr/local/bin:/bin /usr/local/lib/node_modules/pm2/bin/pm2 startup systemd -u pi --hp /home/pi
                          [PM2] Init System found: systemd
                          Platform systemd
                          Template
                          [Unit]
                          Description=PM2 process manager
                          Documentation=https://pm2.keymetrics.io/
                          After=network.target
                          [Service]
                          Type=forking
                          User=pi
                          LimitNOFILE=infinity
                          LimitNPROC=infinity
                          LimitCORE=infinity
                          Environment=PATH=$PATH:/usr/local/bin:/bin:/bin:/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin
                          Environment=PM2_HOME=/home/pi/.pm2
                          PIDFile=/home/pi/.pm2/pm2.pid
                          Restart=on-failure
                          ExecStart=/usr/local/lib/node_modules/pm2/bin/pm2 resurrect
                          ExecReload=/usr/local/lib/node_modules/pm2/bin/pm2 reload all
                          ExecStop=/usr/local/lib/node_modules/pm2/bin/pm2 kill
                          [Install]
                          WantedBy=multi-user.target
                          Target path
                          /etc/systemd/system/pm2-pi.service
                          Command list
                          [ ‘systemctl enable pm2-pi’ ]
                          [PM2] Writing init configuration in /etc/systemd/system/pm2-pi.service
                          [PM2] Making script booting at startup…
                          Executing: systemctl enable pm2-pi…
                          [PM2] [v] Command successfully executed.
                          [PM2] Freeze a process list on reboot via:
                          $ pm2 save
                          [PM2] Remove init script via:
                          $ pm2 unstartup systemd
                          pm2 startup command done
                          configure the pm2 config file for MagicMirror
                          start MagicMirror via pm2 now
                          save MagicMirror pm2 config now
                          pm2 setup completed - Tue May 17 12:22:06 EDT 2022
                            sdetweil @mrdger
                            @mrdger strange…
                            ok, my guess is a bad cable from pi to display
                            I had seen some flakiness on DVI-D display with an hdmi->DVI adapter…
                            a different adapter had no trouble with the same cable
                              @mrdger did you setup for autostart using the manual procedure?
                              pm2 replaces that… so you should dlete that setup if you did it… (as it looks like with 2 autostarts)
                                mrdger @sdetweil
                                @sdetweil It is on a hdmi to dvi adapter, but I actually have a different cable arriving today, so I’ll attempt again after it gets here. Thank you for all your help so far. The autostart feature asked be during the install if I wanted to use it, a y/N option, and I selected y. Should I change anything about that?
                                  sdetweil @mrdger
                                  @mrdger no… I was only asking about what you did on the manual install
                                  my script does PM2.
                                    mrdger @sdetweil
                                    @sdetweil Got it, I don’t believe it was setup. It wasn’t starting after reboot or after closing the window.
                                      sdetweil @mrdger
                                      @mrdger ok
