    ipWhitelist doesn't work for me
    8 Posts 6 Posters 4.8k Views 6 Watching
    • BehB Offline
      Beh
      I just updated my mirror to 2.1.0 and tried to add some IPs to the whitelist, but it doesn’t work. I am not able to access the mirror from an IP added to the ipWhitelist array.
      The array in my config looks like this:
      ipWhitelist: ["10.0.0.55", "192.168.178.77", "127.0.0.1", "::ffff:127.0.0.1", "::1"]
      Do you have any idea, why this does not work?
      /cc @Jopyth and @MichMich
      • BehB Offline
        Beh
        OK, after some trying, I think this related to the IPv6 configuration of my network and/or the Pi.
        When I add "::ffff:192.168.178.77" to the list, I can access the Mirror via browser by entering the IPv4 address of the mirror into the browser’s address field.
          MikeColes @Beh
          @Beh , I ran into the same problem with the same solution. A /24 CIDR didn’t work, probably because of the IPv6 format.
          Has anyone played around with getting a correct network format in use?
          • mochmanM Offline
            mochman Module Developer
            I got it to work using "::ffff:192.168.1.1/24".
            • MichMichM Offline
              MichMich Admin
              If you check your node console output, It should show the blocked IP.
              lolobyteL 1 Reply Last reply Reply Quote 0
              • lolobyteL Offline
                lolobyte @MichMich
                @MichMich
                how to check this?
                  DazDavid
                  @mochman Thanks for the hint. That is also working for a whole range like “::ffff:192.168.2.0/24”
                  mochmanM 1 Reply Last reply Reply Quote 1
                  • mochmanM Offline
                    mochman Module Developer @DazDavid
                    @DazDavid Yeah, I messed up with the CIDR notation for IPv6. The reason why “/24” works is because that gives you practically every IP (especially every IP4 address). If you want to just have 192.168.X.0 - 192.168.X.255 whitelisted, you should use "::ffff:192.168.X.1/120".
                    I added a HOWTO guide here to help out everyone.
