    Best bet for those not technically inclined?
    8 Posts 5 Posters 2.0k Views 5 Watching
    • sifuhallS Offline
      sifuhall
      I’m building a Magic Mirror for a family that is not technically inclined and I want to proactively minimize the tech support they will need to keep this going.
      What are my best bets?
      Maybe write a script that updates all modules as was as magic mirror on every reboot?
      Maybe run a client and setup a server in my home and point the client to that?
      S B FoziF 3 Replies Last reply Reply Quote 0
        sdetweil @sifuhall
        @sifuhall you live there?
        turn off the notifications module
        disabled:true
        then maybe create a script that will check for module updates. altho if it’s working I would leave it alone.
        I have an updates script for the base.
        see
        but again you f it’s working don’t fiddle w it.
        no reason to remote the system, it’s the same stuff either way. no point having two of them to deal with.
        backup, backup , backup
        test it once… at least
        sifuhallS 1 Reply Last reply Reply Quote 0
        • sifuhallS Offline
          sifuhall @sdetweil
          Thanks for the reply.
          I don’t live there, and I will take your advice and leave it alone if it is working.
            bhepler Module Developer @sifuhall
            @sifuhall - What I do for the mirrors I give as gifts is I set up a reverse SSH connection to a URL that I control. Whenever I need to connect to the mirrors, I start up a cloud VM and have that VM change the DNS entry for that URL to point to itself. Alternately, you could set up a dynamic DNS entry to your home and have the mirror connect directly to your house.
            With the cloud VMs, this allows me to spin up a machine, wait 5 minutes for the mirrors to connect to it, then SSH to the machine and then down to each mirror. At that point, I can change the config.js or run updates as necessary.
            • FoziF Offline
              Fozi Project Sponsor @sifuhall
              @sifuhall I’d second @sdetweil’s recommendation. If it works, it works. But I still would prepare some kind of remote access, just in case.
              What I would add, too, is a cronjob that reboots the mirror once a day at night. Depending on number and sort of modules, you might get into RAM issues or crashes, which decreases the user experience.
                sdetweil @Fozi
                @Fozi SD cards are not suited to all the disk writes caused by daily reboot…
                no more than weekly…
                I don’t reboot mine months on end.
                admittedly I don’t have lots of modules
                  MMRIZE
                  I recommend dataplicity (https://www.dataplicity.com/). Easy to connect remotely without DDNS or Portforwarding setup.
                  • FoziF Offline
                    Fozi Project Sponsor @sdetweil
                    @sdetweil Yeah, I totally agree with that.
                    But it really depends on the modules. Thus, some sort of endurance test might be useful before shipping the mirror.
