    MMM-Remote-control all working except for monitor on and off
    12 Posts 3 Posters 5.8k Views 3 Watching
      diemen112
      i made a fresh install with MMos because i bricked my SD card.
      but now i installed Remote-control everything works except monitor off and on.
      when i manually type the command “vcgencmd display_power 0” by SSH it works fine.
      i tried removing the module and installing again but that was no help.
      • karsten13K Offline
        karsten13
        @diemen112 said in MMM-Remote-control all working except for monitor on and off:
        MMos
        if you refer to https://github.com/guysoft/MagicMirrorOS you must be aware of that this setup uses a docker container. This has some restrictions, not all commands from the pi are available from inside the docker container. E.g. rebooting or shutting down the pi will not work and there is no simple workaround to get this running.
        But adding vcgencmd is no problem, so I updated the docker setup by adding a new volume mount. For getting the update:
        Please cd into ~/magicmirror/run and execute:
        git pull
        cp rpi.yml docker-compose.yml:
        After that execute docker-compose up -d in the same folder.
        If you did own changes to docker-compose.yml don’t
        forget to save it before executing the above cp command …
          diemen112
          @karsten13 said in MMM-Remote-control all working except for monitor on and off:
          thank you!, that works.
          i only run the command first ‘cp rpi.yml docker-compose.yml’ without the ‘:’.
          can i run in trouble now? it looks like everything works fine.
          kind regards
            karsten13
            everything o.k., the : was a typo here …
              diemen112
              I had to reinstall my MM but now i have the same problem again.
              but the last time solution doesn’t help.
              I have the same error as the previous printscreen.
              and when i run vcgencmd in the terminal it works fine.
                karsten13 @diemen112
                @diemen112
                are there any errors in the logs?
                Output of docker logs mm?
                  diemen112 @karsten13
                  docker logs mm
                  this is the logs output of the error
                  [05.07.2022 14:31.43.589] [LOG] Error: Command failed: vcgencmd display_power 0
                  vcgencmd: error while loading shared libraries: libvchiq_arm.so.0: cannot open shared object file: No such file or directory
                  at ChildProcess.exithandler (node:child_process:408:12)
                  at ChildProcess.emit (node:events:526:28)
                  at maybeClose (node:internal/child_process:1092:16)
                  at Socket.<anonymous> (node:internal/child_process:451:11)
                  at Socket.emit (node:events:526:28)
                  at Pipe.<anonymous> (node:net:687:12) {
                  killed: false,
                  code: 127,
                  signal: null,
                  cmd: ‘vcgencmd display_power 0’
                    @diemen112
                    I can’t test this myself at the moment because I have no pi left for a fresh install.
                    what does this mean exactly? Did you setup MM-OS from scratch?
                      @karsten13
                      yes completely from scratch, i used the latest MM-OS version:
                      (2022-03-08_2022-01-28-magicmirroros-bullseye-armhf-lite-0.3.0)
                      and reinstalled all the modules on a RP3b+
                        @diemen112
                        you are using a nightly build which is not an official release.
                        I was not aware of a bullseye version and this setup was never tested with bullseye.
                        So I recommend to use a buster version.
                          @karsten13
                          ah thank you for your help
                          • T Offline
                            thobach @diemen112
                            @diemen112 @karsten13 For bullseye I needed to change the display driver to the fake kms one (dtoverlay=vc4-fkms-v3d in /boot/config.txt) to have any effect of vcgencmd.
                            Afterwards vcgencmd only worked from the host, but not from @karsten13’s docker container. There I ran into the same problem with my MMM-Gestures module:
                            [09.10.2022 17:54.49.927] [LOG]   Sun Oct 09 2022 17:54:49 GMT+0200 (Central European Summer Time): exec error: Error: Command failed: vcgencmd display_power 0
                            I fixed it by mounting two more files from the host, my volume mounts now are:
                                volumes:
                                  - ../mounts/config:/opt/magic_mirror/config
                                  - ../mounts/modules:/opt/magic_mirror/modules
                                  - ../mounts/css:/opt/magic_mirror/css
                                  - /tmp/.X11-unix:/tmp/.X11-unix
                                  - /opt/vc:/opt/vc/:ro
                                  - /usr/bin/vcgencmd:/usr/bin/vcgencmd
                                  - /usr/lib/arm-linux-gnueabihf/libvchiq_arm.so.0:/usr/lib/arm-linux-gnueabihf/libvchiq_arm.so.0
                                  - /usr/lib/arm-linux-gnueabihf/libvcos.so.0:/usr/lib/arm-linux-gnueabihf/libvcos.so.0
                                  - /var/run/dbus/system_bus_socket:/var/run/dbus/system_bus_socket
