    How to turn off Raspberry Pi LEDs
    9 Posts 6 Posters 8.8k Views 6 Watching
    • G Offline
      GuestMirror
      Hello, I have a question.
      I am using the Raspberry Pi 4B and tried turning the power led and other status leds off configuring the boot/config.txt file and using the “echo 0 | sudo tee /sys/class/leds/led{1,0}/brightness” command. However, they didn’t change anything. I think this is due to the pm2 and the boot/config.txt somehow gets skipped when booting.
      Does anyone have suggestions how I can turn them off or run the boot/config.txt file?
      Thank you very much for your help!
      S FoziF evroomE 4 Replies Last reply Reply Quote 0
        sdetweil @GuestMirror
        @GuestMirror never heard of any option to turn off the LEDs except on pi0w.
          @GuestMirror boot/config.txt is processed long before pm2 is started…
          • FoziF Offline
            Fozi Project Sponsor @GuestMirror
            @GuestMirror Try this in bootconfig.txt
            # Turn off PWR LED
            dtparam=pwr_led_trigger=none
            dtparam=pwr_led_activelow=off
            # Turn off ACT LED
            dtparam=act_led_trigger=none
            dtparam=act_led_activelow=off
            # Turn off Ethernet ACT LED
            dtparam=eth_led0=4
            # Turn off Ethernet LNK LED
            dtparam=eth_led1=4
            G plainbrokeP 2 Replies Last reply Reply Quote 0
            • G Offline
              GuestMirror @sdetweil
              @sdetweil Is there a way to see if the boot/config.txt loads properly? I tried troubleshooting it by setting different things in there like rotating the display etc. however, even with all my other changes commented out nothing changes when booting.
              • G Offline
                GuestMirror @Fozi
                @Fozi I already tried that but it won’t work for some reason.
                • plainbrokeP Offline
                  plainbroke @Fozi
                  @Fozi @GuestMirror
                  Works on my RPi 4
                  I just copied and pasted to the bottom of the config.txt did a PM2 stop all and then sudo reboot and when it came backup they where on for a few seconds and then went off. @GuestMirror are you in the /boot/config.txt?
                  @Fozi said in How to turn off Raspberry Pi LEDs:
                  # Turn off PWR LED
                  # Turn off ACT LED
                  dtparam=eth_led0=4
                  dtparam=eth_led1=4
                  • evroomE Online
                    evroom @GuestMirror
                    @GuestMirror
                    I do not have a Pi 4 but on my Pi 3 Model B I have this:
                    sudo nano /boot/config.txt
                    # Disable the PWR LED
                    # Disable the Activity LED
                    crontab -e
                    @reboot echo 0 | sudo tee /sys/class/leds/led1/brightness
                    You can try this to see if the above cron entry works (before rebooting):
                    Perhaps some stuff does not work or does the same, but both the power LED and activity LED on my Pi are off in the end.
                    Btw, on my Pi 3 Model B Plus, only the /root/config.txt line are needed.
                    Concerning the LAN LED’s I found following:
                    # Disable LAN-LEDs on Raspberry Pi 3B+
                    dtparam=eth_led0=14
                    dtparam=eth_led1=14
                    # Disable LAN-LEDs on Raspberry Pi 4
                    dtparam=eth_led0=4
                    dtparam=eth_led1=4
                    Good luck!
                    MagicMirror version: 2.36.0
                    • H Offline
                      harney
                      here are the amendments to boot/config.txt file. For BULLSEYE, you have to use different parameters to make them work
                      these work for pi3 and pi 4
                      Pre BULLSEYE
                      • Disable the PWR LED
                      • Disable the Activity LED
                      • Disable ethernet port LEDs
                        dtparam=eth_led0=4
                        dtparam=eth_led1=4
                      BULLSEYE ONLY
                        dtparam=pwr_led_trigger=default-on
                      • Disable Ethernet port LEDs
                        dtparam=eth_led0=4
                        dtparam=eth_led1=4
