    NPM run start cannot be used
    44 Posts 4 Posters 21.6k Views 4 Watching
      sdetweil @史新瑞
      @史新瑞 I don’t understand ‘API’
      API is the method of getting data… we don’t expose that outside the module.
      of course u could change the code if u know javascript.
      you could certainly use the openeweather source…
      • 史
        史新瑞 @sdetweil
        @sdetweil To tell the truth, I didn’t remember it. Please allow me to check it tomorrow morning and tell you
          sdetweil @史新瑞
          @史新瑞 ok… I am US central time… Sunday Aug 14, 11:30 am .
          史 1 Reply Last reply
          • 史
            史新瑞 @sdetweil
            @sdetweil I mean only the weather API, that is, the key of your openweather. I will come back to you for advice in nine hours, that is, around 8:00 p.m. us time. I hope you have time, and I hope you don’t hate me. Thank you again. I wish you good health and good luck. I’ll be with you all the time
              sdetweil @史新瑞
              @史新瑞 no opinion of you. just working on problems. many new users come and we work thru things…
              see u later
              • 史
                史新瑞 @sdetweil
                Good evening. I just woke up
                /* MagicMirror² Config Sample
                * By Michael Teeuw https://michaelteeuw.nl
                * MIT Licensed.
                * see https://docs.magicmirror.builders/configuration/introduction.html
                * and https://docs.magicmirror.builders/modules/configuration.html
                let config = {
                   address: "localhost", 	// Address to listen on, can be:
                   port: 8080,
                   basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                   ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                   language: "zh-cn",
                   locale: "zh",
                   timeFormat: 24,
                   units: "metric",
                   		module: "alert",
                   		module: "updatenotification",
                   		position: "top_bar"
                   		module: "clock",
                   		position: "top_left"
                   		header: "US Holidays",
                   					symbol: "calendar-check",
                   					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                   //		module: "compliments",
                   //		position: "lower_third"
                   	module: "weather",
                   		weatherProvider:"weatherbit",
                   		weatherEndpoint:"/current/forecast/daily",
                   		apiKey:"aa03f670e4944ac3a086f92482a5e25e",
                   		lat:"40.5",
                   		lon:"116.5",
                   		showSun:"true",
                   		colored:"true",
                   		maxNumberOfDays:"5"
                   	/*  显示图片
                   			module: "MMM-ImagesPhotos",
                   			position: "middle_center",
                   				opacity: 0.5,
                   				animationSpeed: 1000,
                   				updateInterval: 5000,
                   				maxWidth:"500px",
                   				maxHeight:"200px",
                   				backgroundColor: 'grey',  // not used if fill is true
                   				fill: false,   // fill around image with blurred copy of image
                   				blur: 10,   // only used if fill is true
                   	module: "helloworld",
                   	position: "bottom_bar",	// This can be any of the regions.
                   		text: "Hi! May I help you?"
                	module: 'MMM-SimpleText',
                	position: 'bottom_right',
                   		fontURL: {
                   		  'value': 'Tahoma, Geneva, sans-serif'
                   		fontSize: {
                   		  'value': 'small'
                   		fontStyle: {
                   		  'value': 'italic'
                   		color: {
                   		  'value': '#FFFFFF'
                   		refreshMs: {
                   		  'value': '10000'
                   		filePath: {
                   		  'value': '123.txt'
                  sdetweil @史新瑞
                  @史新瑞 remove the weatherEndpoint
                  add
                  type:'current'
                  • 史
                    史新瑞 @sdetweil
                    Is that so?
                      sdetweil @史新瑞
                      @史新瑞 no. in the weather config… that is the issue we are working on
                      make it look like mine, use your apikey
                      and your provider
                      https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873
                      • 史
                        史新瑞 @sdetweil
                        The first or the second?
                          sdetweil @史新瑞
                          @史新瑞 either, both, whatever
                          just trying to get it to work
                          • 史
                            史新瑞 @sdetweil
                            @sdetweil Different weather configurations should be configured in different ways。https://docs.magicmirror.builders/modules/weather.html#configuration-options
                            The way I learned from here
                              sdetweil @史新瑞
                              @史新瑞 there are two options current weather and forecast
                              the new module eliminates having to use a lot of parms…
                              just try it my way, for a test
                              • 史
                                史新瑞 @sdetweil
                                @sdetweil I tried it just now, but it didn’t work. It will always show that it is loading
                                  sdetweil @史新瑞
                                  @史新瑞 ‘loading’ is the default message, until some data arrives.
                                  can u show me what you did
                                  • 史
                                    史新瑞 @sdetweil
                                    			module: "weather",
                                    				type: "current",
                                    				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                    				apiKey: "???"
                                    			module: "weather",
                                    			header: "Weather Forecast",
                                    				type: "forecast",
                                    				apiKey: "???"
                                      sdetweil @史新瑞
                                      @史新瑞
                                      just the weather config
                                      ok, this module is stupid… requires parms, but then doesn’t use them…
                                      			module: "weather",
                                      				updateInterval: 15*1000,
                                      				initialLoadDelay: 2,
                                      				weatherProvider: "weatherbit",
                                      				weatherEndpoint:"/forecast/daily",
                                      				type: "forecast",
                                      				lat: 30.4548443,
                                      				lon: -97.6222674,
                                      				apiKey: "67f41759a9c74d8a917ac984155286f0",
                                      also, forecast has a long old bug , make sure to set
                                      and a short interval for testing
                                      you can use this apikey… I will kill it in an hour or so…
                                      I opened this issue
                                      https://github.com/MichMich/MagicMirror/issues/2899
                                      type: current (default) worked on with my apikey
                                      • 史
                                        史新瑞 @sdetweil
                                        1.png Using NPM run start will:
                                          sdetweil @史新瑞
                                          @史新瑞 open the developers window.
                                          ctrl-shift-i on the keyboard
                                          select the console tab and enter weath
                                          in the filter field
                                          • 史
                                            史新瑞 @sdetweil
                                            @sdetweil I don’t know how to open the developer window.
                                            • 2 / 3
