    NPM run start cannot be used
    44 Posts 4 Posters 19.4k Views 4 Watching
      sdetweil @史新瑞
      @史新瑞 the messages where mm is started
      npm start or
      pm2 logs
      史 1 Reply Last reply Reply Quote 0
      • 史 Offline
        史新瑞 @sdetweil
        @sdetweil What is described here is my latest problem. Sorry, I didn’t make it clear
          sdetweil @史新瑞
          @史新瑞 is it current or forecast mode? which provider?
            sdetweil @史新瑞
            @史新瑞 I just added my openweather api key to the starting config.js
            			module: "weather",
            				type: "current",
            				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
            				apiKey: "a6bf9feaa86bc2677df1e5fsdasdasd46bd79d"
            			module: "weather",
            			header: "Weather Forecast",
            				type: "forecast",
            				apiKey: "a6bf9feaa86bc2677df1e5f46bd79dsdasd"
            and both worked (the apikeys are mangled here so won’t work anywhere else)
            史 2 Replies Last reply Reply Quote 0
            • 史 Offline
              史新瑞 @sdetweil
              @sdetweil I don’t use the same API as you, and your last reply revealed your key which is not good
                sdetweil @史新瑞
                @史新瑞 my key was mangled, so not useable… just wanted it to be clear for you…
                default provider is openweather
                I asked you what provider and type… (current or forecast)
                I can get api keys to test too
                • 史 Offline
                  史新瑞 @sdetweil
                  @sdetweil If possible, I would like to try your API tomorrow, but this is only a test, and this is based on your consent. Generally, I will not use your API, I will continue to use my own API, I hope you can agree
                    sdetweil @史新瑞
                    @史新瑞 I don’t understand ‘API’
                    API is the method of getting data… we don’t expose that outside the module.
                    of course u could change the code if u know javascript.
                    you could certainly use the openeweather source…
                    • 史 Offline
                      史新瑞 @sdetweil
                      @sdetweil To tell the truth, I didn’t remember it. Please allow me to check it tomorrow morning and tell you
                        sdetweil @史新瑞
                        @史新瑞 ok… I am US central time… Sunday Aug 14, 11:30 am .
                        • 史 Offline
                          史新瑞 @sdetweil
                          @sdetweil I mean only the weather API, that is, the key of your openweather. I will come back to you for advice in nine hours, that is, around 8:00 p.m. us time. I hope you have time, and I hope you don’t hate me. Thank you again. I wish you good health and good luck. I’ll be with you all the time
                            sdetweil @史新瑞
                            @史新瑞 no opinion of you. just working on problems. many new users come and we work thru things…
                            see u later
                            • 史 Offline
                              史新瑞 @sdetweil
                              Good evening. I just woke up
                              /* MagicMirror² Config Sample
                              * By Michael Teeuw https://michaelteeuw.nl
                              * MIT Licensed.
                              * see https://docs.magicmirror.builders/configuration/introduction.html
                              * and https://docs.magicmirror.builders/modules/configuration.html
                              let config = {
                                 address: "localhost", 	// Address to listen on, can be:
                                 port: 8080,
                                 basePath: "/", 	// The URL path where MagicMirror² is hosted. If you are using a Reverse proxy
                                 ipWhitelist: ["127.0.0.1", "::ffff:127.0.0.1", "::1"], 	// Set [] to allow all IP addresses
                                 language: "zh-cn",
                                 locale: "zh",
                                 timeFormat: 24,
                                 units: "metric",
                                 		module: "alert",
                                 		module: "updatenotification",
                                 		position: "top_bar"
                                 		module: "clock",
                                 		position: "top_left"
                                 		header: "US Holidays",
                                 					symbol: "calendar-check",
                                 					url: "webcal://www.calendarlabs.com/ical-calendar/ics/76/US_Holidays.ics"
                                 //		module: "compliments",
                                 //		position: "lower_third"
                                 	module: "weather",
                                 		weatherProvider:"weatherbit",
                                 		weatherEndpoint:"/current/forecast/daily",
                                 		apiKey:"aa03f670e4944ac3a086f92482a5e25e",
                                 		lat:"40.5",
                                 		lon:"116.5",
                                 		showSun:"true",
                                 		colored:"true",
                                 		maxNumberOfDays:"5"
                                 	/*  显示图片
                                 			module: "MMM-ImagesPhotos",
                                 			position: "middle_center",
                                 				opacity: 0.5,
                                 				animationSpeed: 1000,
                                 				updateInterval: 5000,
                                 				maxWidth:"500px",
                                 				maxHeight:"200px",
                                 				backgroundColor: 'grey',  // not used if fill is true
                                 				fill: false,   // fill around image with blurred copy of image
                                 				blur: 10,   // only used if fill is true
                                 	module: "helloworld",
                                 	position: "bottom_bar",	// This can be any of the regions.
                                 		text: "Hi! May I help you?"
                              	module: 'MMM-SimpleText',
                              	position: 'bottom_right',
                                 		fontURL: {
                                 		  'value': 'Tahoma, Geneva, sans-serif'
                                 		fontSize: {
                                 		  'value': 'small'
                                 		fontStyle: {
                                 		  'value': 'italic'
                                 		color: {
                                 		  'value': '#FFFFFF'
                                 		refreshMs: {
                                 		  'value': '10000'
                                 		filePath: {
                                 		  'value': '123.txt'
                                sdetweil @史新瑞
                                @史新瑞 remove the weatherEndpoint
                                add
                                type:'current'
                                • 史 Offline
                                  史新瑞 @sdetweil
                                  Is that so?
                                    sdetweil @史新瑞
                                    @史新瑞 no. in the weather config… that is the issue we are working on
                                    make it look like mine, use your apikey
                                    and your provider
                                    https://forum.magicmirror.builders/topic/17093/npm-run-start-cannot-be-used/14?_=1660526689873
                                    • 史 Offline
                                      史新瑞 @sdetweil
                                      The first or the second?
                                        sdetweil @史新瑞
                                        @史新瑞 either, both, whatever
                                        just trying to get it to work
                                        • 史 Offline
                                          史新瑞 @sdetweil
                                          @sdetweil Different weather configurations should be configured in different ways。https://docs.magicmirror.builders/modules/weather.html#configuration-options
                                          The way I learned from here
                                            sdetweil @史新瑞
                                            @史新瑞 there are two options current weather and forecast
                                            the new module eliminates having to use a lot of parms…
                                            just try it my way, for a test
