    NPM run start cannot be used
    44 Posts 4 Posters 21.6k Views 4 Watching
    • 史
      史新瑞
      After the third-party module is installed, NPM Run Server is normal, but NPM Run Start cannot be used
      S kayakbabeK 2 Replies Last reply
        sdetweil @史新瑞
        @史新瑞 eh?
        please explain more
        what problem occurs?
        show messages
        史 1 Reply Last reply
        • kayakbabeK
          kayakbabe @史新瑞
          @史新瑞
          Did you run /home/pi/Magicmirror/npm run check:config
          to verify your config.js?
          • 史
            史新瑞 @sdetweil
            Then it’s full screen darkness
            • 史
              史新瑞 @kayakbabe
              @kayakbabe > magicmirror@2.20.0 start
              /home/pi/MagicMirror/node_modules/electron/index.js:17
              throw new Error(‘Electron failed to install correctly, please delete node_modules/electron and try installing again’);
              Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
              at getElectronPath (/home/pi/MagicMirror/node_modules/electron/index.js:17:11)
              at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:21:18)
              at Module._compile (node:internal/modules/cjs/loader:1105:14)
              at Object.Module._extensions…js (node:internal/modules/cjs/loader:1159:10)
              at Module.load (node:internal/modules/cjs/loader:981:32)
              at Function.Module._load (node:internal/modules/cjs/loader:822:12)
              at Module.require (node:internal/modules/cjs/loader:1005:19)
              at require (node:internal/modules/cjs/helpers:102:18)
              at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:18)
                @史新瑞
                npm install electron@19.0.6
                for the other black screen
                see https://forum.magicmirror.builders/topic/15778/fix-for-black-screen-in-2-16-and-later/
                • 史
                  史新瑞 @sdetweil
                  @sdetweil Thank you. NPM can now be used to run and start, but the weather module cannot be displayed, as shown below
                  • 史
                    史新瑞 @史新瑞
                    @史新瑞 This is the same config.js file under two different operating modes
                      sdetweil @史新瑞
                      @史新瑞 show any messages
                      • 史
                        史新瑞 @sdetweil
                        @sdetweil There is no error message
                          sdetweil @史新瑞
                          @史新瑞 the messages where mm is started
                          npm start or
                          pm2 logs
                          • 史
                            史新瑞 @sdetweil
                            @sdetweil What is described here is my latest problem. Sorry, I didn’t make it clear
                            S 2 Replies Last reply
                              sdetweil @史新瑞
                              @史新瑞 is it current or forecast mode? which provider?
                                sdetweil @史新瑞
                                @史新瑞 I just added my openweather api key to the starting config.js
                                			module: "weather",
                                				type: "current",
                                				locationID: "5128581", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
                                				apiKey: "a6bf9feaa86bc2677df1e5fsdasdasd46bd79d"
                                			module: "weather",
                                			header: "Weather Forecast",
                                				type: "forecast",
                                				apiKey: "a6bf9feaa86bc2677df1e5f46bd79dsdasd"
                                and both worked (the apikeys are mangled here so won’t work anywhere else)
                                史 2 Replies Last reply
                                • 史
                                  史新瑞 @sdetweil
                                  @sdetweil I don’t use the same API as you, and your last reply revealed your key which is not good
                                    sdetweil @史新瑞
                                    @史新瑞 my key was mangled, so not useable… just wanted it to be clear for you…
                                    default provider is openweather
                                    I asked you what provider and type… (current or forecast)
                                    I can get api keys to test too
                                    • 史
                                      史新瑞 @sdetweil
                                      @sdetweil If possible, I would like to try your API tomorrow, but this is only a test, and this is based on your consent. Generally, I will not use your API, I will continue to use my own API, I hope you can agree
                                        sdetweil @史新瑞
                                        @史新瑞 I don’t understand ‘API’
                                        API is the method of getting data… we don’t expose that outside the module.
                                        of course u could change the code if u know javascript.
                                        you could certainly use the openeweather source…
                                        • 史
                                          史新瑞 @sdetweil
                                          @sdetweil To tell the truth, I didn’t remember it. Please allow me to check it tomorrow morning and tell you
                                            sdetweil @史新瑞
                                            @史新瑞 ok… I am US central time… Sunday Aug 14, 11:30 am .
